Author Topic: Switch Case Menu Problem  (Read 1280 times)
I´m building a menu system for a timer I am working on.  Its my first proper project and I am trying to do as much of it as I can on my own, but i´m stumped by one particular problem.
What I am trying to is have a main menu with several sub-menus where you change options, etc.  So far I have got to the first option ("logs") and while the main menu and sub menu work, the last option in the sub menu ("back") doesn´t work.  What it should do when you press SW2 (a push button) is go back to the main menu, but instead it reverts back to the first option in "logs" menu.
Here is the relevant code,
void mainmenu(){
      switch (menuLV1){
            case 0: //LOGS
                  LCDmsgNo = 5;
                  LCD2msgNo = 1;
                  if (SW1State == LOW && SW2State == HIGH && SW2PrevState == LOW){
                  logsMenu = 1;
                  break;
            case 1: //Settings
                  LCDmsgNo = 6;
                  LCD2msgNo = 1;
                  break;
            case 2: //Information
                  LCDmsgNo = 14;
                  LCD2msgNo = 1;
                  break;
            case 3: //Advanced Settings
                  LCDmsgNo = 7;
                  LCD2msgNo = 1;
                  break;
      // Cycle through Menu Options
      if (SW1State == HIGH && SW2State == LOW && SW1PrevState == LOW){
      menuLV1++;
      // Loop back to begining of menu
      if (securityLvL == 0 && menuLV1 > 2){ //normal user
        menuLV1 = 0;
      if (securityLvL == 1 && menuLV1 > 3){ //Engineer
        menuLV1 = 0;
      ////////// LOGS MENU /////////////
      if (logsMenu > 0){ // Only Run if logsMenu is Activated
            if (logsMenu > 4){  //returns menu cycle back to beginning
            logsMenu = 1;
            switch (logsMenu){
                  case 1: // Total Credit
                        LCDmsgNo = 9;
                        LCD2msgNo = 4;
                        if (SW1State == HIGH && SW1PrevState == LOW) {
                        logsMenu ++;
                        break;
                  case 2:  // Credit in Coin Box
                        LCDmsgNo = 10;
                        LCD2msgNo = 5;
                        logsMenu ++;
                        break;
                  case 3: //Total Power Consumption
                        LCDmsgNo = 11;
                        LCD2msgNo = 6;
                        logsMenu ++;
                        break;
                  case 4: //Back
                        LCDmsgNo = 12;
                        LCD2msgNo = 1;
                        logsMenu = 1;
                        if (SW2State == HIGH && SW2PrevState == LOW) {
                        menuLV1 = 1;
                        logsMenu = 0;
                        break;
I can post the rest of the code if required, but I think the problem lies somewhere here.  Either I have misunderstood the use of Switch Case or I´m doing something dumb.
Thanks for any help you can give.
Dallas
Online Online
Shannon Member
Nothing jumps out at me.
enums would be a nice replacement for the the integer constants.
Seattle, WA USA
Online Online
Seattle, WA USA
Use some Serial.print() statements to confirm that the switch states are what you expect them to be, and to see what path is actually taken through the code.
Ok I tried with the serial.print (very good idea BTW) and found that selecting the back option change the logsmenu value to 1 not 0 like it should do.  The thing is I´ve no idea why, the way I see the code it should be 0.
Seattle, WA USA
Online Online
Seattle, WA USA
Print out more stuff, then, like menuLV1, SW1PrevState, SW2PrevState, etc.
You may need to post all of your code.
Where are you reading the switch states? Are you debouncing the switches?
After a bit more searching with the serial monitor I have discovered that I was geting a double press of any button.  However, I have just tried it again to get a print out for this post and I am no longer getting the double push thing, but the menu is still not working.
Here is how I am doing the switches,
void SWstates () { //Sets the switch States
      SW1CurrentState = digitalRead(SW1);  //Get Current State of SW1
      SW2CurrentState = digitalRead(SW2);  //Get Current State of SW2
      SW3CurrentState = digitalRead(SW3);  //Get Current State of SW3
      SW4CurrentState = digitalRead(SW4);  //Get Current State of SW4
      //Sets SW1 State and debounces
      if (SW1CurrentState != SW1PrevState) {
            SW1DebounceTime = millis();  // reset the debouncing timer
      if ((millis() - SW1DebounceTime) > debounceDelay) {
        SW1State = SW1CurrentState;
        if (SW1PrevState == HIGH && SW1CurrentState == HIGH && (millis() - SW1DebounceTime) > 3000) {
        SW1StateHeld = 1;
      else {
      SW1StateHeld = 0;
      SW1PrevState = SW1CurrentState;
        //repeats if statements for the other buttons
The debounce delay is 50ms.
I think I need to look at a different way to do this bit, which I will do when I get home.
Yorkshire England
Arduino good init
You can get IC's for debouching switches i think so you don't have to do it in software
UK
Online Online
But ICs cost money.
I'm a little surprised that someone from Yorkshire missed that.
I'm guessing you're not a native.
« Last Edit: January 21, 2011, 12:43:40 pm by AWOL » Logged
