Greece
Offline
Newbie
Arduino rocks
« on: January 29, 2010, 05:47:35 pm » |
Hi. I bought cheap nunchuck from China and it would not work whatever i do. :-[ Firstly i tested it with an original wii system and the nunchuck was working fine. But when i try to connect it in my arduino...i get nothing. Any one got an idea why ?? Thnx in advance.
Logged
MD, USA
Offline
God Member
A jack of all trades and a master of none!
« Reply #1 on: January 29, 2010, 06:02:44 pm » |
Do you have it wired right? What code are you using?
We need more information here before we can speculate on the problem.
Logged
Greece
Offline
Newbie
Arduino rocks
« Reply #2 on: January 29, 2010, 06:17:21 pm » |
Thnx digimike for your reply. Do you have it wired right? What code are you using? Yes i m sure that is wired right. I also open it and take some readings with the multimeter in the accelerometer exit. The code im using is http://todbot.com/arduino/sketches/NunchuckPrint/. I v also tested almost every code i v found in the internet .
Logged
Greece
Offline
Newbie
Arduino rocks
« Reply #3 on: January 29, 2010, 06:46:14 pm » |
« Last Edit: January 29, 2010, 06:47:20 pm by ntgr »
Logged
Australia
Offline
Jr. Member
Arduino rocks
« Reply #4 on: January 30, 2010, 05:02:30 pm » |
Wii "Extension Controllers" other than the original Nunchuck have an initialisation sequence which differs from the one found in the nunchuck library originally designed by Tim Hirzel. I found this out when I tried to use a Wii "Classic Controller". To initialise anything other than an OEM Nunchuck, you need to replace this in the init call: Wire.begin(); // join i2c bus as master Wire.beginTransmission(0x52);// transmit to device 0x52 Wire.send(0x40);// sends memory address Wire.send(0x00);// sends sent a zero. Wire.endTransmission();// stop transmitting With this: byte cnt;
Wire.begin(); // init controller delay(1); Wire.beginTransmission(0x52); // device address Wire.send(0xF0); // 1st initialisation register Wire.send(0x55); // 1st initialisation value Wire.endTransmission(); delay(1); Wire.beginTransmission(0x52); Wire.send(0xFB); // 2nd initialisation register Wire.send(0x00); // 2nd initialisation value Wire.endTransmission(); delay(1); // read the extension type from the register block Wire.beginTransmission(0x52); Wire.send(0xFA); // extension type register Wire.endTransmission(); Wire.beginTransmission(0x52); Wire.requestFrom(0x52, 6); // request data from controller for (cnt = 0; cnt < 6; cnt++) { if (Wire.available()) { ctrlr_type[cnt] = Wire.receive(); // Should be 0x0000 A420 0101 for Classic Controller, 0x0000 A420 0000 for nunchuck } } Wire.endTransmission(); delay(1); // send the crypto key (zeros), in 3 blocks of 6, 6 & 4. Wire.beginTransmission(0x52); Wire.send(0xF0); // crypto key command register Wire.send(0xAA); // sends crypto enable notice Wire.endTransmission(); delay(1); Wire.beginTransmission(0x52); Wire.send(0x40); // crypto key data address for (cnt = 0; cnt < 6; cnt++) { Wire.send(0x00); // sends 1st key block (zeros) } Wire.endTransmission(); Wire.beginTransmission(0x52); Wire.send(0x40); // sends memory address for (cnt = 6; cnt < 12; cnt++) { Wire.send(0x00); // sends 2nd key block (zeros) } Wire.endTransmission(); Wire.beginTransmission(0x52); Wire.send(0x40); // sends memory address for (cnt = 12; cnt < 16; cnt++) { Wire.send(0x00); // sends 3rd key block (zeros) } Wire.endTransmission(); delay(1); // end device init Also somewhere you'll need to store the ctrlr_type that you collected in the routine, its type is (make it global or whatever you like): uint8_t ctrlr_type[6]; This works for my Classic Controller and my nunchuck, even though the old code also worked for my nunchuck. The inspiration for this code came from the wiibrew site, http://wiibrew.org/wiki/Wiimote#Extension_Controllers
« Last Edit: January 30, 2010, 05:08:53 pm by crimony »
Logged
Greece
Offline
Newbie
Arduino rocks
« Reply #5 on: January 31, 2010, 03:05:52 am » |
crimony .. YES !!! YES !!! YES !!!  Working !!!! Many many thnx .... You r THE BEST ... THNX..
Logged
0
Offline
Newbie
Arduino rocks!
« Reply #6 on: February 17, 2010, 06:24:50 am » |
I have a Dealextreme nunchuck and with this modification of the code it now works great! thanks crimony! however i didnt get it to work with the complimentary filter implimentation done by ardvark http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1253202298please help out
« Last Edit: February 17, 2010, 07:31:06 am by turbosharp »
Logged
Seattle, WA USA
Online
Brattain Member
Seattle, WA USA
« Reply #7 on: February 17, 2010, 06:44:53 am » |
however i didnt get it to work...please help out It would be oh so much easier if you gave us the tiniest little hint what didn't work. Did the cheap ebay nunchuck not work? Did the code not work? Did the code not compile correctly? What does YOUR code look like?
Logged
0
Offline
Newbie
Arduino rocks!
« Reply #8 on: February 17, 2010, 08:01:34 am » |
Of course Paul. problemMy nunchuck dont work with the complimentary filter code I cant get readings => problems with the Ic2 Communications Suggestion as mention by crimony, " Wii "Extension Controllers" other than the original Nunchuck have an initialisation sequence which differs from the one found in the nunchuck library originally designed by Tim Hirzel" I succesfully manage to change the nunchuck_funcs.h library done by todbot. So the nunchuck works fine.. just different  So I think my problem is in the initialisation sequence
. I've tryed the same approach but cant get it to work on the complimentary filter code. SummaryChange the initialisation sequence in this thread http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1253202298/0 to crimonys solution above
Logged
0
Offline
Newbie
Arduino rocks
« Reply #9 on: May 13, 2010, 10:19:57 pm » |
Just registered to post in here. I bought a cheap nunchuck solely to use it for my arduino. I spent 3 hours trying to get it to work and thought I'd wasted my money, but the code here made it work! Thanks crimony. You're a lifesaver.
Logged
0
Offline
Newbie
Arduino rocks
« Reply #10 on: May 24, 2010, 02:39:41 pm » |
i love you crimony
i had the same headache and now it works beautifully
Logged
0
Offline
Newbie
Arduino rocks
« Reply #11 on: May 24, 2010, 09:01:06 pm » |
hello, I also bought the cheap wii nunchuck from china, and I'd like to know how to connect it because there is 5 wires(white, black, red, yellow, green), I think the original one has 4.. thanx
Logged
0
Offline
Newbie
Arduino rocks
« Reply #12 on: May 31, 2010, 04:22:14 am » |
I have the same problem , though maine came ftom amzone uk. The remote is working , but nunchuk not.
I went through this site , but as not any expert , hard to understand what can possibly be done ?
Can anyone please describe the steps.
Tnx
Logged
0
Offline
Newbie
Arduino rocks
« Reply #13 on: November 07, 2010, 03:36:47 pm » |
Hi all, I have an issue with the low costs nunchucks from China... I have tried the workaround from crimony and updated the init block Here the code I'm using: #include <Wire.h>
void setup() { Serial.begin(19200); Serial.print ("Begin of setup\n"); nunchuck_setpowerpins(); // use analog pins 2&3 as fake gnd & pwr nunchuck_init(); // send the initilization handshake Serial.print ("End of setup\n"); }
void loop() { nunchuck_get_data(); nunchuck_print_data(); delay(100); }
// // Nunchuck functions //
static uint8_t nunchuck_buf[6]; // array to store nunchuck data, uint8_t ctrlr_type[6];
// Uses port C (analog in) pins as power & ground for Nunchuck static void nunchuck_setpowerpins() { #define pwrpin PORTC3 #define gndpin PORTC2 DDRC |= _BV(pwrpin) | _BV(gndpin); PORTC &=~ _BV(gndpin); PORTC |= _BV(pwrpin); delay(100); // wait for things to stabilize }
// initialize the I2C system, join the I2C bus, // and tell the nunchuck we're talking to it void nunchuck_init() { /*Wire.begin(); // join i2c bus as master Wire.beginTransmission(0x52); // transmit to device 0x52 Wire.send(0x40); // sends memory address Wire.send(0x00); // sends sent a zero. Wire.endTransmission(); // stop transmitting*/ Serial.print ("Begin nunchuck init\n"); byte cnt; Wire.begin();
Serial.print ("Step 1\n"); // init controller delay(1); Wire.beginTransmission(0x52); // device address Wire.send(0xF0); // 1st initialisation register Wire.send(0x55); // 1st initialisation value Wire.endTransmission(); delay(1); Wire.beginTransmission(0x52); Wire.send(0xFB); // 2nd initialisation register Wire.send(0x00); // 2nd initialisation value Wire.endTransmission(); delay(1); Serial.print ("Step 2\n"); // read the extension type from the register block Wire.beginTransmission(0x52); Wire.send(0xFA); // extension type register Wire.endTransmission(); Wire.beginTransmission(0x52); Wire.requestFrom(0x52, 6); // request data from controller for (cnt = 0; cnt < 6; cnt++) { if (Wire.available()) { ctrlr_type[cnt] = Wire.receive(); // Should be 0x0000 A420 0101 for Classic Controller, 0x0000 A420 0000 for nunchuck } } Wire.endTransmission(); delay(1); Serial.print ("Step 3\n"); // send the crypto key (zeros), in 3 blocks of 6, 6 & 4. Wire.beginTransmission(0x52); Wire.send(0xF0); // crypto key command register Wire.send(0xAA); // sends crypto enable notice Wire.endTransmission(); delay(1); Wire.beginTransmission(0x52); Wire.send(0x40); // crypto key data address for (cnt = 0; cnt < 6; cnt++) { Wire.send(0x00); // sends 1st key block (zeros) } Wire.endTransmission(); Wire.beginTransmission(0x52); Wire.send(0x40); // sends memory address for (cnt = 6; cnt < 12; cnt++) { Wire.send(0x00); // sends 2nd key block (zeros) } Wire.endTransmission(); Wire.beginTransmission(0x52); Wire.send(0x40); // sends memory address for (cnt = 12; cnt < 16; cnt++) { Wire.send(0x00); // sends 3rd key block (zeros) } Wire.endTransmission(); delay(1); // end device init }
// Send a request for data to the nunchuck // was "send_zero()" void nunchuck_send_request() { Wire.beginTransmission(0x52); // transmit to device 0x52 Wire.send(0x00); // sends one byte Wire.endTransmission(); // stop transmitting }
// Receive data back from the nunchuck, int nunchuck_get_data() { int cnt=0; Wire.requestFrom (0x52, 6); // request data from nunchuck while (Wire.available ()) { // receive byte as an integer nunchuck_buf[cnt] = nunchuk_decode_byte(Wire.receive()); cnt++; } nunchuck_send_request(); // send request for next data payload // If we recieved the 6 bytes, then go print them if (cnt >= 5) { return 1; // success } return 0; //failure }
// Print the input data we have recieved // accel data is 10 bits long // so we read 8 bits, then we have to add // on the last 2 bits. That is why I // multiply them by 2 * 2 void nunchuck_print_data() { static int i=0; int joy_x_axis = nunchuck_buf[0]; int joy_y_axis = nunchuck_buf[1]; int accel_x_axis = nunchuck_buf[2]; // * 2 * 2; int accel_y_axis = nunchuck_buf[3]; // * 2 * 2; int accel_z_axis = nunchuck_buf[4]; // * 2 * 2;
int z_button = 0; int c_button = 0;
// byte nunchuck_buf[5] contains bits for z and c buttons // it also contains the least significant bits for the accelerometer data // so we have to check each bit of byte outbuf[5] if ((nunchuck_buf[5] >> 0) & 1) z_button = 1; if ((nunchuck_buf[5] >> 1) & 1) c_button = 1;
if ((nunchuck_buf[5] >> 2) & 1) accel_x_axis += 2; if ((nunchuck_buf[5] >> 3) & 1) accel_x_axis += 1;
if ((nunchuck_buf[5] >> 4) & 1) accel_y_axis += 2; if ((nunchuck_buf[5] >> 5) & 1) accel_y_axis += 1;
if ((nunchuck_buf[5] >> 6) & 1) accel_z_axis += 2; if ((nunchuck_buf[5] >> 7) & 1) accel_z_axis += 1;
Serial.print(i,DEC); Serial.print("\t"); Serial.print("joy:"); Serial.print(joy_x_axis,DEC); Serial.print(","); Serial.print(joy_y_axis, DEC); Serial.print(" \t");
Serial.print("acc:"); Serial.print(accel_x_axis, DEC); Serial.print(","); Serial.print(accel_y_axis, DEC); Serial.print(","); Serial.print(accel_z_axis, DEC); Serial.print("\t");
Serial.print("but:"); Serial.print(z_button, DEC); Serial.print(","); Serial.print(c_button, DEC);
Serial.print("\r\n"); // newline i++; }
// Encode data to format that most wiimote drivers except // only needed if you use one of the regular wiimote drivers char nunchuk_decode_byte (char x) { x = (x ^ 0x17) + 0x17; return x; } When I upload the code to the board, no error is showned, but on the serial monitor I see only: Begin of setup Begin nunchuck init Step 1 after that the sketch seems to be stopped. If I unplug the data wire from the nunchuck then the sketch start again running Can anyone help? Thanks a lot jdc
Logged
0
Offline
Newbie
Arduino rocks
« Reply #14 on: November 08, 2010, 12:11:47 pm » |
HEllo Some more information regarding my issue mentionned in my previous post. It seems the Wire.endTransmission();
has something to do with my issue. When I comment the line, the sketch continue to the next steps but at the end it is still not working properly. If anyone can help ...  Thanks a lot jdc
Logged
