Pages: [1] 2   Go Down
Author Topic: Cheap ebay nunchuck NOT working  (Read 3360 times)
Greece
Hi.
I bought cheap nunchuck from China and it would not work whatever i do. :-[
Firstly i tested it with an original wii system and the nunchuck was working fine.
But when i try to connect it in my arduino...i get nothing.
Any one got an idea why ??
Thnx in advance.
MD, USA
A jack of all trades and a master of none!
Do you have it wired right? What code are you using?
We need more information here before we can speculate on the problem.
Greece
Thnx digimike for your reply.
Yes i m sure that is wired right. I also open it and take some readings with the multimeter in the accelerometer exit.
The code im using is http://todbot.com/arduino/sketches/NunchuckPrint/. I v also tested almost every code i v found in the internet .
Greece
Here is an image of the board.
http://img96.imageshack.us/i/p1142482.jpg/
« Last Edit: January 29, 2010, 06:47:20 pm by ntgr » Logged
Australia
Wii "Extension Controllers" other than the original Nunchuck have an initialisation sequence which differs from the one found in the nunchuck library originally designed by Tim Hirzel. I found this out when I tried to use a Wii "Classic Controller".
To initialise anything other than an OEM Nunchuck, you need to replace this in the init call:
   Wire.begin();                // join i2c bus as master
    Wire.beginTransmission(0x52);// transmit to device 0x52
    Wire.send(0x40);// sends memory address
    Wire.send(0x00);// sends sent a zero.
    Wire.endTransmission();// stop transmitting
With this:
byte cnt;
Wire.begin();
// init controller
delay(1);
Wire.beginTransmission(0x52);      // device address
Wire.send(0xF0);                    // 1st initialisation register
Wire.send(0x55);                    // 1st initialisation value
delay(1);
Wire.send(0xFB);                    // 2nd initialisation register
Wire.send(0x00);                    // 2nd initialisation value
delay(1);
// read the extension type from the register block
Wire.send(0xFA);                    // extension type register
Wire.requestFrom(0x52, 6);               // request data from controller
for (cnt = 0; cnt < 6; cnt++) {
    if (Wire.available()) {
        ctrlr_type[cnt] = Wire.receive(); // Should be 0x0000 A420 0101 for Classic Controller, 0x0000 A420 0000 for nunchuck
delay(1);
// send the crypto key (zeros), in 3 blocks of 6, 6 & 4.
Wire.send(0xF0);                    // crypto key command register
Wire.send(0xAA);                    // sends crypto enable notice
delay(1);
Wire.send(0x40);                    // crypto key data address
    Wire.send(0x00);                    // sends 1st key block (zeros)
Wire.send(0x40);                    // sends memory address
for (cnt = 6; cnt < 12; cnt++) {
    Wire.send(0x00);                    // sends 2nd key block (zeros)
for (cnt = 12; cnt < 16; cnt++) {
    Wire.send(0x00);                    // sends 3rd key block (zeros)
delay(1);
// end device init
Also somewhere you'll need to store the ctrlr_type that you collected in the routine, its type is (make it global or whatever you like):
uint8_t ctrlr_type[6];
This works for my Classic Controller and my nunchuck, even though the old code also worked for my nunchuck.
The inspiration for this code came from the wiibrew site, http://wiibrew.org/wiki/Wiimote#Extension_Controllers
« Last Edit: January 30, 2010, 05:08:53 pm by crimony » Logged
Greece
crimony ..
YES !!! YES !!! YES !!!  smiley
Working !!!!
Many many thnx ....
You r THE BEST ...
THNX..
Arduino rocks!
I have a Dealextreme nunchuck and with this modification of the code it now works great! thanks crimony!
however i didnt get it to work with the complimentary filter implimentation done by ardvark http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1253202298
please help out
« Last Edit: February 17, 2010, 07:31:06 am by turbosharp » Logged
Seattle, WA USA
Seattle, WA USA
however i didnt get it to work...please help out
It would be oh so much easier if you gave us the tiniest little hint what didn't work.
Did the cheap ebay nunchuck not work? Did the code not work? Did the code not compile correctly? What does YOUR code look like?
Arduino rocks!
Of course Paul.
problem
My nunchuck dont work with the complimentary filter code
I cant get readings => problems with the Ic2 Communications
Suggestion
as mention by crimony, "Wii "Extension Controllers" other than the original Nunchuck have an initialisation sequence which differs from the one found in the nunchuck library originally designed by Tim Hirzel"
I succesfully manage to change the nunchuck_funcs.h library done by todbot. So the nunchuck works fine.. just different  smiley
So I think my problem is in the initialisation sequence
. I've tryed the same approach but cant get it to work on the complimentary filter code.
Summary
Change the initialisation sequence in this thread http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1253202298/0 to crimonys solution above
Just registered to post in here. I bought a cheap nunchuck solely to use it for my arduino. I spent 3 hours trying to get it to work and thought I'd wasted my money, but the code here made it work! Thanks crimony. You're a lifesaver.
i love you crimony
i had the same headache and now it works beautifully
hello,
I also bought the cheap wii nunchuck from china, and I'd like to know how to connect it because there is 5 wires(white, black, red, yellow, green), I think the original one has 4..
thanx
I have the same problem , though maine came ftom amzone uk.  The remote is working , but nunchuk not.
I went through this site , but as not any expert , hard to understand what can possibly be done ?
Can anyone please describe the steps.
Tnx
Hi all,
I have an issue with the low costs nunchucks from China...
I have tried the workaround from crimony and updated the init block
Here the code I'm using:
#include <Wire.h>
  Serial.begin(19200);
  Serial.print ("Begin of setup\n");
  nunchuck_setpowerpins(); // use analog pins 2&3 as fake gnd & pwr
  nunchuck_init(); // send the initilization handshake
  Serial.print ("End of setup\n");
  nunchuck_get_data();
  nunchuck_print_data();
  delay(100);
// Nunchuck functions
static uint8_t nunchuck_buf[6];   // array to store nunchuck data,
// Uses port C (analog in) pins as power & ground for Nunchuck
static void nunchuck_setpowerpins()
#define pwrpin PORTC3
#define gndpin PORTC2
    DDRC |= _BV(pwrpin) | _BV(gndpin);
    PORTC &=~ _BV(gndpin);
    PORTC |=  _BV(pwrpin);
    delay(100);  // wait for things to stabilize
// initialize the I2C system, join the I2C bus,
// and tell the nunchuck we're talking to it
void nunchuck_init()
  /*Wire.begin();                      // join i2c bus as master
  Wire.beginTransmission(0x52);      // transmit to device 0x52
  Wire.send(0x00);            // sends sent a zero.
  Wire.endTransmission();      // stop transmitting*/
  Serial.print ("Begin nunchuck init\n");
  byte cnt;
  Wire.begin();
  Serial.print ("Step 1\n");
  // init controller
  delay(1);
  delay(1);
  delay(1);
  Serial.print ("Step 2\n");
  delay(1);
  Serial.print ("Step 3\n");
  delay(1);
  delay(1);
  // end device init
// Send a request for data to the nunchuck
// was "send_zero()"
void nunchuck_send_request()
  Wire.send(0x00);            // sends one byte
// Receive data back from the nunchuck,
int nunchuck_get_data()
    int cnt=0;
    Wire.requestFrom (0x52, 6);      // request data from nunchuck
    while (Wire.available ()) {
      // receive byte as an integer
      nunchuck_buf[cnt] = nunchuk_decode_byte(Wire.receive());
      cnt++;
    nunchuck_send_request();  // send request for next data payload
    // If we recieved the 6 bytes, then go print them
    if (cnt >= 5) {
     return 1;   // success
    return 0; //failure
// Print the input data we have recieved
// accel data is 10 bits long
// so we read 8 bits, then we have to add
// on the last 2 bits.  That is why I
// multiply them by 2 * 2
void nunchuck_print_data()
  static int i=0;
  int joy_x_axis = nunchuck_buf[0];
  int joy_y_axis = nunchuck_buf[1];
  int accel_x_axis = nunchuck_buf[2]; // * 2 * 2;
  int accel_y_axis = nunchuck_buf[3]; // * 2 * 2;
  int accel_z_axis = nunchuck_buf[4]; // * 2 * 2;
  int z_button = 0;
  int c_button = 0;
  // byte nunchuck_buf[5] contains bits for z and c buttons
  // it also contains the least significant bits for the accelerometer data
  // so we have to check each bit of byte outbuf[5]
  if ((nunchuck_buf[5] >> 0) & 1)
    z_button = 1;
  if ((nunchuck_buf[5] >> 1) & 1)
    c_button = 1;
  if ((nunchuck_buf[5] >> 2) & 1)
    accel_x_axis += 2;
  if ((nunchuck_buf[5] >> 3) & 1)
    accel_x_axis += 1;
  if ((nunchuck_buf[5] >> 4) & 1)
    accel_y_axis += 2;
  if ((nunchuck_buf[5] >> 5) & 1)
    accel_y_axis += 1;
  if ((nunchuck_buf[5] >> 6) & 1)
    accel_z_axis += 2;
  if ((nunchuck_buf[5] >> 7) & 1)
    accel_z_axis += 1;
  Serial.print(i,DEC);
  Serial.print("\t");
  Serial.print("joy:");
  Serial.print(joy_x_axis,DEC);
  Serial.print(",");
  Serial.print(joy_y_axis, DEC);
  Serial.print("  \t");
  Serial.print("acc:");
  Serial.print(accel_x_axis, DEC);
  Serial.print(",");
  Serial.print(accel_y_axis, DEC);
  Serial.print(",");
  Serial.print(accel_z_axis, DEC);
  Serial.print("\t");
  Serial.print("but:");
  Serial.print(z_button, DEC);
  Serial.print(",");
  Serial.print(c_button, DEC);
  Serial.print("\r\n");  // newline
  i++;
// Encode data to format that most wiimote drivers except
// only needed if you use one of the regular wiimote drivers
char nunchuk_decode_byte (char x)
  x = (x ^ 0x17) + 0x17;
  return x;
When I upload the code to the board, no error is showned, but on the serial monitor I see only:
Begin of setup
Begin nunchuck init
Step 1
after that the sketch seems to be stopped.
If I unplug the data wire from the nunchuck then the sketch start again running
Can anyone help?
Thanks a lot
jdc
HEllo
Some more information regarding my issue mentionned in my previous post.
It seems the
has something to do with my issue.
When I comment the line, the sketch continue to the next steps but at the end it is still not working properly.
If anyone can help ...  smiley
Thanks a lot
jdc
Pages: [1] 2   Go Up
