Topic: Confuzzled about Serial.print() behavior (Read 6837 times) previous topic - next topic
vulrath
Okay...I have been trying to give myself a crash course in serial communication was going really well until now), and I came across this little tidbit that makes no sense.  I know C and C++, both of which completely ignore unnecessary spacing unless the situation deems it appropriate (EG when calling an API in C++ or inside the quotation marks on a printf() command in C), and I know that Arduino is based off of Wiring, which is based off of C, which makes me scratch my head and wonder where I went wrong.
My code:
Quote
 * eh, math...
 int a=5;
 int b=10;
 int c=20;
   Serial.println("a = ");
   Serial.print(a);
   Serial.println("b = ");
   Serial.print(b);
   Serial.println("c = ");
   Serial.print(c);
   Serial.println("a+b = ");
   Serial.print(a+b);
   Serial.println("a*c = ");
   Serial.print(a*c);
   Serial.println("c/b = ");
   Serial.print(c/b);
   Serial.println("b-c = ");
   Serial.print(b-c);
The serial output:
Quote
a =
5b =
10c =
20a+b =
15a*c =
100c/b =
2b-c =
-10
Now, for the confusing thing - this is the code copied and pasted from the site where I got it from (http://www.ladyada.net/learn/arduino/lesson4.html)
Quote
 * eh, math...
 * Math is fun!
int a = 5;
int b = 10;
int c = 20;
void setup()                    // run once, when the sketch starts
  Serial.begin(9600);           // set up Serial library at 9600 bps
  Serial.println("Here is some math: ");
  Serial.print("a = ");
  Serial.println(a);
  Serial.print("b = ");
  Serial.println(b);
  Serial.print("c = ");
  Serial.println(c);
  Serial.print("a + b = ");       // add
  Serial.println(a + b);
  Serial.print("a * c = ");       // multiply
  Serial.println(a * c);
  Serial.println("c / b = ");       // divide
  Serial.print(c / b);
  Serial.print("b - c = ");       // subtract
  Serial.printl(b - c);
void loop()                     // we need this to be here even though its empty
Aaaand the output...
Quote
Here is some math:
a = 5
b = 10
c = 20
a + b = 15
a * c = 100
c / b =
2b - c =
-10
Now, I know that my version of the code isn't exactly "neat" as far as spacing and such goes, but I don't really see any point as it really doesn't matter all that much because I document well enough, and because like I said earlier, it's C.  It usually doesn't matter all that much.  I just can't understand why it's doing it this time.
dania25
You mixed up printIn with print. it is starting a new line with the number, and continuing the new line with the next print.
Coding late at night? ;D
AWOL
#2
Jan 23, 2011, 10:10 am Last Edit: Jan 23, 2011, 10:12 am by AWOL Reason: 1
I'm not sure what your problem here is, but I think you need to look carefully at what 'println' does.
I'd be more worried about how yoir cut and paste works.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
vulrath
#3
Jan 23, 2011, 08:24 pm Last Edit: Jan 23, 2011, 09:46 pm by vulrath Reason: 1
Quote
Coding late at night? Grin
That did it...That syntax had worked perfectly with the "Hello world" program that I wrote, so I made the assumption (which made an ass out of me and a guy named umption) that that was the correct way to do it.  I went back over the material I was studying, and sure enough, Serial.println() is described as "prints with line break".  Forest, trees...You get the picture.  Thanks for the assist.
