Author Topic: open random file from SD card  (Read 3220 times)
I am trying to open a random text file from a SD card.
I am using an indexing array for the filenames but this method seems pretty dumb to me
File myFile;
char* myTXTs[]={"1.txt", "2.txt", "3.txt", "4.txt", "5.txt","6.txt","7.txt", "8.txt", "9.txt",
               "10.txt", "11.txt", "12.txt", "13.txt", "14.txt", "15.txt", "16.txt", "17.txt", "18.txt", "19.txt",
               "20.txt", "21.txt", "22.txt", "23.txt", "24.txt", "25.txt", "26.txt", "27.txt", "28.txt", "29.txt",
               "30.txt", "31.txt", "32.txt", "33.txt", "34.txt", "35.txt", "36.txt", "37.txt", "38.txt", "39.txt",
               "40.txt", "41.txt"," 42.txt"," 43.txt", "44.txt", "45.txt", "46.txt", "47.txt", "48.txt", "49.txt",
               "50.txt", "51.txt", "52.txt", "53.txt", "54.txt", "55.txt", "56.txt", "57.txt", "58.txt", "59.txt",
               "60.txt", "61.txt", "62.txt", "63.txt", "64.txt", "65.txt", "66.txt", "67.txt", "68.txt", "69.txt",
               "70.txt", "71.txt", "72.txt", "73.txt", "74.txt", "75.txt", "76.txt", "77.txt", "78.txt", "79.txt",
               "80.txt", "81.txt", "82.txt", "83.txt", "84.txt", "85.txt", "86.txt", "87.txt", "88.txt", "89.txt",
               "90.txt", "91.txt", "92.txt", "93.txt", "94.txt", "95.txt", "96.txt", "97.txt", "98.txt", "99.txt"};
thisTXT = random(1, 100);
 myFile = SD.open(myTXTs[thisTXT]);
this method uses a lot of ram and I'am asking if there is simpler way?
I would like to pick out one random text file from a pool of 2000 stored on SD card
Dallas
Shannon Member
#include <stdio.h>
int thisTXT;
char FileName[[glow]7[/glow]];  [glow]// DO NOT make this buffer too small[/glow]
thisTXT = random(1, [glow]100[/glow]);  [glow]// DO NOT go over 100 without adjusting the size of the buffer[/glow]
sprintf( FileName, "%i.txt", thisTXT );
myFile = SD.open( FileName );
thx for that super fast answer.. What I am exactly trying to do is print out random text snipplets stored on sd card on a POS printer
here is the full code but it doesn't seem to print now (what it did before)
Since I am quite a noob this code ,ay look a little bit odd
 smiley-wink
//Microprinter V0.1
#include <SD.h>
#include <Debounce.h> // für taster
#include <TrueRandom.h>
#include <stdio.h>
int taster = 5;       // INPUT PIN TASTER
int ledPin1 = 13;     // OUTPUT PIN LED
int thisTXT;
char FileName[7];
Debounce debouncer = Debounce(20 , taster ); //debounce Taster mit 20ms Debounce Zeit
const byte esc = 0x1B; //definiert esc zur Druckerkommunikation
const byte gs = 0x1D;  //definiert gs zur Drukcerkommunikation
File myFile;
  pinMode(ledPin1, OUTPUT); //
  pinMode(taster, INPUT);
  digitalWrite(taster, HIGH);
  Serial.begin(9600); //serial anschluss für den Drucker
randomSeed(TrueRandom.random());
 SD.begin();
void SDPrint()
 thisTXT = random(1, 100);  // DO NOT go over 100 without adjusting the size of the buffer
  if (!SD.begin(4))
  if (myFile) {
    // read from the file until there's nothing else in it:
    while (myFile.available()) {
          Serial.write(myFile.read());
    // close the file:
    myFile.close();
        // if the file didn't open, print an error:
    Serial.print("kann Texte nicht lesen");
 Serial.print(0xA, BYTE);
  debouncer.update();
  int tasterVal = debouncer.read();
  int val = digitalRead(taster);
  if (val == HIGH) {
    digitalWrite(ledPin1, HIGH);
   SDPrint();
  else {
    digitalWrite(ledPin1, LOW);
« Last Edit: January 22, 2011, 08:32:42 pm by strangemachines » Logged
Dallas
Shannon Member
Does the printer have paper?
the printer has plenty of paper
and it works with the following code change:
 initprinter();
  schrift();
  umlaut();
  center();
 thisTXT = random(1, 120);  // DO NOT go over 100 without adjusting the size of the buffer
Dallas
Shannon Member
Glad to hear you have it working.
Did you increase the buffer size?
I increased the buffer size to 8. The esc/POS protocol for the printer communication seems to be a little bit picky but everything is running fine now.
What does the stdio libary do exactly? I couldn't find any reference for it on the arduino pages.
Dallas
Shannon Member
For very general questions like that, the best choice is...
http://www.google.com/search?q=stdio
Bear in mind that, on the AVR processor, stdio deviates from the standard stdio.
http://www.google.com/search?q=stdio+avr+gcc
« Last Edit: January 23, 2011, 02:36:19 pm by bcook » Logged
