thanks
Ok, not quite sure what you want to do exactly now.
This is the menu you want to do:
- Fill Delay Time
- Ram Delay Time
- Ram Pulse Time
- Start
- Pause
- Stop
Just ignore what I said before about one button.
Do you want to have 3 buttons, one left, one right and one select?
Do you want to have 3 buttons, one up, one down and one select?
Or do you want a single scrolling menu on one button (seperate screen change for each item or scrolling up/down?)
The only reason why I used the one button was becuase I was short on I/O pins. If I had had more pins then I would have done a better menu which scrolled up/down, with 3 buttons
If you want a scrolly up down menu then this is what I am thinking. It will also help me with coding a scrolling menu on my 40x4 LCD so I'm not just doing it for you ;D
My idea:
First screen:
Fill Delay <
Ram Delay
After one press of the down button:
Fill Delay
Ram Delay <
After the next press of the down button:
Ram Delay
Ram Pulse <
If you then press the up button:
Ram Delay <
Ram Pulse
If you get to the botton of the menu:
Stop <
Maybe make it so if you get to the top it cycles back round to the start..
What do you think?
The code you posted has a load of errors so I am not going to try and correct it at the moment.
You have the basics but I think the type of menu I described above would be more suitable.
If you just want a single button (but not so obvious as to how to use) menu then I can sort out that code for you.
When I get home, I will also have my serial LCD to play on and test with.
Mowcius
Hi Mowcius
That would be GREAT!!!!
I just want to thank you for all your help. I will have my LCD tommorrow too!!
thanks
ben
I presume you are wanting a 2 line up/down scrolling menu then.
I will see what I can do.
Mowcius
Here is my 15 minutes...
It is not very good code wise but it works... Just...
You might need to change the position code for the 16x2 serial LCD but it should help anyway.
#include <NewSoftSerial.h>
NewSoftSerial LCDserial(0, 2);
int prognumber = 1;
int line = 1;int down = 8;
int select = 9;
int up = 10;void menu();
void LCDclear();
void LCDfirst();
void LCDsecond();
void LCDmenudisplay();void first();
void second();
void third();
void fourth();
void fifth();void setup() {
LCDserial.begin(9600);
menu();
}void loop() {
//nothing to loop but is required in every sketch.
}void LCDclear(){
LCDserial.print(0xFE, BYTE);
LCDserial.print(0x01, BYTE);
}void LCDfirst(){
LCDserial.print(128, BYTE);
void LCDsecond(){
LCDserial.print(192, BYTE);
}void menu() {
while(digitalRead(up) == HIGH or digitalRead(down) == HIGH or digitalRead(select) == HIGH){};
delay(50);
LCDclear();
LCDfirst();
if(prognumber > 1){
prognumber--;
else{
prognumber == 1;
LCDmenudisplay();
LCDsecond();
prognumber++;
LCDmenudisplay();
if(line == 1){
LCDserial.print(143, BYTE);
LCDserial.print("<");
else {
LCDserial.print(207, BYTE);
while(digitalRead(up) == LOW && digitalRead(down) == LOW && digitalRead(select) == LOW){}
if(digitalRead(down) == HIGH){
line++;
if(line > 2){
line = 2;
prognumber++;
if(prognumber > 4){
prognumber = 5;
menu();
else if(digitalRead(up) == HIGH){
line--;
if(line < 1){
line = 1;
prognumber--;
menu();
else if(digitalRead(select) == HIGH){
if(line == 1){
prognumber--;
switch (prognumber) {
case 1:
first();
break;
case 2:
second();
break;
case 3:
third();
break;
case 4:
fourth();
break;
case 5:
fifth();
break;
default:
first();
}void LCDmenudisplay() {
case 1:
LCDserial.print("First");
break;
case 2:
LCDserial.print("Second");
break;
case 3:
LCDserial.print("Third");
break;
case 4:
LCDserial.print("Fourth");
break;
case 5:
LCDserial.print("Fifth");
break;
default:
void first() {
digitalWrite(13, HIGH);
menu();
}void second() {
menu();
}void third() {
menu();
}void fourth() {
menu();
}void fifth() {
digitalWrite(13, LOW);
menu();
Mowcius
the void first(){ } etc are where you would stick the pieces of code.
No doubt someone can write something much better (and so could I with more time and less tiredness).
The newsoftserial could be changed to the softwareserial library with no problems but the newsoftserial library is better...
I was testing it using the top 2 lines of my 40x4 so that is why the positioning is probably off for the second line text...
The code basically does what I explained a few posts up but you will see if you try it.
Look at serial LCD datasheet to find out the positioning values for the 16x2 LCD.
Mowcius
You still around reading this?
Mowcius
Hi Mowcius Sorry Yes Im still reading this I have been away and haven't had a chance to come back here.
I have been playing with the first code you gave me ( 1 Button) and I have it working fully.
Do you mind having a quick look to see if there are an obvious errors/problems.
/* Menu Code by Adapated from Mowcius Code
#include <EEPROM.h>
NewSoftSerial LCDserial(0, 3);
// START Menu Stuff
int menuButton = 2;
int programnumber = 1;
int menudelaycount = 0;
int menudelaycount2 = 0;
// End Menu Stuff
long ramCycle = 0;
int FRPin = 8;
int MotorPin = 7;
long fillDelay = 1000;
long holdDelay = 500;
int ramPulse = 500;
LCDclear();
selectLineOne();
LCDserial.print("Azzurra Bathroom");
selectLineTwo();
LCDserial.print("Testing Rig V1.0");
delay(5000);
pinMode(menuButton, INPUT);
pinMode(FRPin, OUTPUT);
pinMode(MotorPin, OUTPUT);
//Pull Ram in fully
retractRam();
mainMenu();
void loop(){
void start()
delay(3000);
while(digitalRead(menuButton) == LOW){
LCDclear();
//Turn on Motor then push out for ramPulse Time
selectLineOne();
LCDserial.print("Extending Ram");
digitalWrite(MotorPin, HIGH);
digitalWrite(FRPin, HIGH);
delay(ramPulse);
checkPress();
//Hold the motor for holdDelay Time (-- PUSH OUT--)
LCDclear();
selectLineOne();
LCDserial.print("Holding Ram");
digitalWrite(MotorPin, LOW);
delay(holdDelay);
checkPress();
//Turn on Motor then pull in for ramPulse Time
LCDclear();
selectLineOne();
LCDserial.print("Retracting Ram");
digitalWrite(FRPin, LOW);
delay(ramPulse);
checkPress();
//Hold the motor for holdDelay Time (--PULL IN--) & Print Current Ram Count
LCDclear();
selectLineOne();
ramCycle++;
LCDclear();
selectLineOne();
LCDserial.print("Ram Count ");
selectLineTwo();
LCDserial.print(ramCycle);
delay(fillDelay);
checkPress();
void retractRam()
LCDclear();
selectLineOne();
selectLineTwo();
LCDserial.print("to Home Position");
delay(6000);
void mainMenu()
LCDclear(); //clears the LCD
selectLineOne();
switch (programnumber) { //reads the program number (set as 1 in setup)
case 1: //displays the first menu item
LCDserial.print("Set Fill Delay");
break;
case 2: //displays the second menu item
LCDserial.print("Hold Delay");
break;
case 3: //displays the third menu item
LCDserial.print("Ram Pulse");
break;
case 4: //displays the first menu item
LCDserial.print("Start");
break;
case 5: //displays the third menu item
LCDserial.print("Stop");
break;
default: //if errors then it goes to default item
LCDserial.print("Fill Delay");
selectLineTwo();
LCDserial.print("Next >"); //next code in specific position
while(digitalRead(menuButton) == HIGH){} //while button is high do nothing: {} (helps with debounce after button has been pressed)
delay(5);
while(digitalRead(menuButton) == LOW){} //wait until button has been pressed (taken high).
menudelaycount = 0; //clear menu delay
while(menudelaycount <500){ //do this code within the 500 limit (over 500ms because of other stuff that is done and takes time)
delay(1);
menudelaycount++;
if(digitalRead(menuButton) == LOW){ //if the button goes low (button released) within this loop then it advances one menu option
programnumber++; //increase the menu option
if(programnumber > 5){
programnumber = 1;
mainMenu(); //then run menu code from start: the change in program number makes it change the option it is on.
switch (programnumber) { //if the button is not let go within the menu time stated above then it does not loop back and then selects the subroutine from this switch case:
case 1:
//LCDserial.print("Fill Func");
fillMenu();
break;
case 2:
// LCDserial.print("Delay Func");
delayMenu();
break;
case 3:
//LCDserial.print("Pulse Func");
pulseMenu();
break;
case 4:
LCDclear();
selectLineOne
LCDserial.print("Starting Test");
start();
break;
case 5:
LCDserial.print("Stop Func");
break;
default:
LCDserial.print("Default Start Func");
void fillMenu()
LCDclear();
selectLineOne();
LCDserial.print(fillDelay);
selectLineTwo();
delay(5);
menudelaycount = 0;
delay(1);
menudelaycount++;
fillDelay = fillDelay +3000;
if(fillDelay > 120000){
fillDelay = 0;
fillMenu();
LCDclear();
selectLineOne();
LCDserial.print("Fill Delay set @ ");
selectLineTwo();
delay(3000);
mainMenu();
void delayMenu()
LCDclear();
selectLineOne();
LCDserial.print(holdDelay);
selectLineTwo();
delay(5);
menudelaycount = 0;
delay(1);
menudelaycount++;
holdDelay = holdDelay +500;
if(holdDelay > 60000){
holdDelay = 0;
delayMenu();
LCDclear();
selectLineOne();
LCDserial.print("Hold Delay set @ ");
selectLineTwo();
delay(3000);
mainMenu();
void pulseMenu()
LCDclear();
selectLineOne();
LCDserial.print(ramPulse);
selectLineTwo();
delay(5);
menudelaycount = 0;
delay(1);
menudelaycount++;
ramPulse = ramPulse +250;
if(ramPulse > 6000){
ramPulse = 0;
pulseMenu();
LCDclear();
selectLineOne();
LCDserial.print("Ram Pulse set @ ");
selectLineTwo();
delay(3000);
mainMenu();
void checkPress()
if (digitalRead(menuButton) == HIGH)
retractRam();
LCDclear();
selectLineOne();
LCDserial.print("Paused");
// selectLineTwo();
// LCDserial.print("Press button to goto menu");
mainMenu();
void selectLineOne(){ //puts the cursor at line 0 char 0.
LCDserial.print(0xFE, BYTE); //command flag
LCDserial.print(128, BYTE); //position
void selectLineTwo(){ //puts the cursor at line 2 char 0.
LCDserial.print(192, BYTE); //position
void LCDclear(){
LCDserial.print(0x01, BYTE); //clear command
Thanks again
Ben
Well not that I can see from a very quick look. If it is working then it is probably ok.
If I get time then I will load up your code on my arduino and LCD later to see what it looks like and if I can suggest any changes/improvments.
If you get the time then you might still want to take a look at the scroling menu I wrote to see if it suits you better.
Mowcius
Hi Mowcius,
thanks Im going to load it up tomorrow to see how it works.
thanks
Ben
Hi Mowcius,
I loaded your code up & it looks great and seemed to work fine, but after about 10 - 20 key presses it just hangs.
I have the buttons wired 5v to one side if the switch and the Digital pin with a 10K resistor pulling low the other side of the switch.
any ideas????
Thanks
Ben
Yeah I had an issue with that too. I thought it might be just my wiring at the time but it appears not.
I think I may need to stick in a few delays somewhere. I will take another look some time.
Mowcius
Thanks Mowcius Look foward to your reply.
Hi Mowcius,
I think I found the error in your code
if(line > 2){
line = 2;
prognumber++;
[glow]}[/glow]
if(prognumber > 4){
prognumber = 5;
[glow]//}[/glow]
menu();
I moved the } bracket from the commented out section to the other highlighted section and now I doesn't lock up.
I think what was happening is that when you press 2 button simultaneously it would make the line number = 1 and the prognumber >4 so the if statement would allow it to go though..
What do you think
Ben
Sorry Scratch that it still does it :(!!!!
Yeah, sorry I have not had time to look at it yet.
I will post it up as a seperate topic and see if anyone else has any ideas...
Mowcius
The code issue was sorted here:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1274268079/15#15
int prognumber = 1;
int line = 1;
int down = 8;
int select = 9;
int up = 10;
void menu();
void LCDclear();
void LCDfirst();
void LCDsecond();
void first();
void second();
void third();
void fourth();
void fifth();
menu();
void LCDclear(){
void LCDfirst(){
void LCDsecond(){
void menu() {
while(digitalRead(up) == HIGH || digitalRead(down) == HIGH || digitalRead(select) == HIGH){};
LCDclear();
LCDfirst();
if(prognumber > 1){
prognumber--;
else{
prognumber = 1;
LCDmenudisplay();
LCDsecond();
prognumber++;
LCDmenudisplay();
if(line == 1){
else {
line++;
if(line > 2){
line = 2;
prognumber++;
if(prognumber > 4){
prognumber = 5;
line--;
if(line < 1){
line = 1;
prognumber--;
if(line == 1){
prognumber--;
case 1:
first();
break;
case 2:
second();
break;
case 3:
third();
break;
case 4:
fourth();
break;
case 5:
fifth();
break;
default:
first();
delay(50);
case 1:
break;
case 2:
break;
case 3:
break;
case 4:
break;
case 5:
break;
default:
void first() {
void second() {
void third() {
void fourth() {
delay(100);
delay(100);
delay(100);
void fifth() {
Mowcius
Cheers for the code!
Trying to make my own adaptation to this, but not going very well so far
Hi
Post your code and I'll have a look
