South Coast UK
« Reply #15 on: December 18, 2010, 11:37:11 am » |
zoomkat.
Thanks for getting back. I have Xubuntu with LAMP.
If I type the value into my PHP script the database gets filled, what I don't understand is how or through what the Arduino passes info to the PHP.
If you have any ideas where I should look I'd much appreciate it.
Thanks again
Tony
Online
« Reply #16 on: December 18, 2010, 12:20:20 pm » |
You might post your PHP code that works to see what you have. Below shows how to append a GET request (query_string, the string after the ?) to a URL. In windows, apache sets the query_string as an environmental varable, from which an application started by apache collects the data. Note that some characters have special meaning and can't be put in a query_string.
client.println("GET /arduino.txt HTTP/1.0");
With query_string added:
client.println("GET /arduino.php?put-your-data-here HTTP/1.0");
« Last Edit: December 18, 2010, 12:21:32 pm by zoomkat »
South Coast UK
« Reply #17 on: December 18, 2010, 12:42:55 pm » |
Well this is what I'm trying to run. The Arduino code is yours, modified to update the database with a value. //zoomkat 11-13-10 //simple ethernet client test code //for use with IDE 0021 and W5100 ethernet shield //modify the arduino lan ip address as needed //open serial monitor to see what the arduino receives //push the shield reset button to run client again
#include <SPI.h> #include <Ethernet.h>
byte mac[] = {0x90, 0xA2, 0xDA, 0x00, 0x11, 0xAC }; byte ip[] = { 192, 168, 1, 19 }; byte server[] = { 192,168,1,20 }; // zoomkat
Client client(server, 80);
void setup() { Ethernet.begin(mac, ip); Serial.begin(9600); Serial.println("starting simple arduino client test"); Serial.println();
Serial.println("connecting...");
if (client.connect()) { Serial.println("connected"); //client.println("GET /arduino.txt HTTP/1.0"); client.println("GET /update_db.php?celsius=18 HTTP/1.0"); client.println(); } else { Serial.println("connection failed"); } }
void loop() { if (client.available()) { char c = client.read(); Serial.print(c); }
if (!client.connected()) { Serial.println(); Serial.println("disconnecting."); Serial.println("=================================="); Serial.println(""); client.stop(); for(;;); } }
And the PHP script <?php //Connect to database $con = mysql_connect("localhost", "xxxx", "xxxx"); if(!$con) { die('Could not connect: ' .mysql_error()); } mysql_select_db("1stClassElec", $con);
mysql_query("INSERT INTO device_1(temp) VALUES (celsius)"); mysql_close($con); ?> NOTE: If I change mysql_query("INSERT INTO device_1(temp) VALUES (celsius)"); to mysql_query("INSERT INTO device_1(temp) VALUES (19)"); and then run Arduino the value of 19 gets written into the database. Why mysql_query("INSERT INTO device_1(temp) VALUES (celsius)"); doesn't pass its value of celsius=18 from the Arduino script is a mystery to me at the moment.
« Last Edit: December 18, 2010, 01:12:38 pm by xsilvergs »
Seattle, WA USA
Seattle, WA USA
« Reply #18 on: December 18, 2010, 01:40:27 pm » |
In the PHP script, there are $_GET and $_POST variables that contain the data passed to the script, depending on the method used to to activate the script. The $_GET variables are name/value pairs. The value is obtained from the name: $val = $_GET['celcius']; It is the value ($val) that you want to store in the database.
South Coast UK
« Reply #19 on: December 18, 2010, 01:52:57 pm » |
@ PaulS I was just reading a web page which is similar to your explanation. My PHP script is working and now looks like this: <?php //echo ("update_db.php indicator"); $celsius = $_GET['celsius']; //Connect to database $con = mysql_connect("localhost", "xxxx", "xxxx"); if(!$con) { die('Could not connect: ' .mysql_error()); } mysql_select_db("1stClassElec", $con);
mysql_query("INSERT INTO device_1(temp) VALUES ('$celsius')"); mysql_close($con); ?> Thanks go to all of you for your help, and I expect I'll be back soon with another question
South Coast UK
« Reply #20 on: December 19, 2010, 03:36:35 pm » |
Ok back again. I would like my Arduino web-client to write data to the mysql database every 15 minutes.
What would be the best way to do the time interval counting?
As I see it, it could be done by the Arduino but could my web server poll the Arduino or what about the timer_ntp. I'd need some examples with the last two suggestions if they are good ideas.
« Last Edit: December 19, 2010, 03:53:49 pm by xsilvergs »
Seattle, WA USA
Seattle, WA USA
« Reply #21 on: December 19, 2010, 04:49:11 pm » |
As I see it, it could be done by the Arduino but could my web server poll the Arduino Yes. The Arduino could use millis() to determine the "time", and send data only once every 15 minutes. Or the Arduino could do nothing except wait for a client connection, and, in response to the client connection, return the temperature. Which approach to use depends on what you are comfortable programming.
South Coast UK
« Reply #22 on: December 20, 2010, 03:19:20 pm » |
Well in my endeavour to learn Arduino Ethernet I'm still unable to get the Arduino web-client to accept commands from a server PC. Also I'm unable to get web-server to send data to a mysql database. So I've written (probably poorly) code which I 95% understand that accepts commands from a browser. http://192.168.1.19/?7=1 turns digital 7 on http://192.168.1.19/?7=0 turns digital 7 off http://192.168.1.19/?A=0 gets the value from analogue 0, prints what looks like the correct string in the web-browser but it won't write to a mysql. #include <SPI.h> //#include <WString.h> #include <Ethernet.h>
byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0x11, 0xAC }; //physical mac address byte ip[] = { 192, 168, 1, 19 }; // ip in lan byte gateway[] = { 192, 168, 1, 1 }; // internet access via router byte subnet[] = { 255, 255, 255, 0 }; //subnet mask //byte server[] = { 192,168,1,20 }; Server server(80); //server port byte sampledata=50; //some sample data - outputs 2 (ascii = 50 DEC) int ledPin = 4; // LED pin char link[]="http://www.scienceprog.com/"; //link data String readString = String(30); //string for fetching data from address boolean LEDON = false; //LED status flag //####################################### #define READING_PIN 0 double R1 = 10000.0; //resistance put in parallel double V_IN = 5.0; double A = 1.129148e-3; double B = 2.34125e-4; double C = 8.76741e-8; double K = 9.5; // mW/dec C – dissipation factor double SteinhartHart(double R) { // calculate temperature double logR = log(R); double logR3 = logR * logR * logR; return 1.0 / (A + B * logR + C * logR3 ); } int celsius;//Global declare celsius //####################################### void setup(){ //start Ethernet Ethernet.begin(mac, ip, gateway, subnet); //pinMode; pinMode(7,OUTPUT); digitalWrite(7,LOW); // I use this pin as GND for the LED. pinMode(8,OUTPUT); // Sample output, unable to use built-in LED at pin 13 because Ethernet Shield uses pins 10,11,12,13. //enable serial datada print Serial.begin(9600); } void loop(){ readString="";//Clear readString before filling // Create a client connection Client client = server.available(); if (client) { while (client.connected()) { if (client.available()) { char c = client.read(); //read char by char HTTP request if (readString.length() < 30) { //store characters to string readString.concat(c); Serial.println(readString); } //output chars to serial port Serial.print(c); //if HTTP request has ended if (c == '\n') { //lets check if LED should be lighted Serial.println(readString.substring(6,9));//for test to allow readString to be viewed if(readString.substring(6,9)=="7=1") {//read the last 3 information characters from URL // Serial.println(readString); //set digital 7 HIGH Serial.println("HIGH"); digitalWrite(7, HIGH); // set the LED on readString="";//clear readString } if(readString.substring(6,9)=="7=0") { //set digital 7 LOW Serial.println("LOW"); digitalWrite(7, LOW); // set the LED OFF readString="";//clear readString } if(readString.substring(6,9)=="A=0") { //readAnal 0 temp ReadTemp(); Serial.println("for test"); client.print("GET http://192.168.1.20/update_db.php?celsius="); client.print(celsius); client.println(" HTTP/1.0"); client.println("Host: http://192.168.1.20"); client.println(); readString="";//clear readString } //clearing string for next read readString=""; //stopping client client.stop(); } } } } } //######################################################################## void ReadTemp() { //Serial.print("I'm at ReadTemp "); double adc_raw = analogRead(READING_PIN); double V = adc_raw / 1024 * V_IN;//Serial.println(adc_raw); double R_th = (R1 * V ) / (V_IN - V);//calculate resistance double kelvin = SteinhartHart(R_th) - V*V/(K * R_th); celsius = kelvin - 273.15;//was double but changed to int to remove decimal places Serial.println(); delay(1000); return; } //#######################################################################
Can anyone see and explain what's wrong as I've spent all day on this with no answer. All I want is an Arduino with Ethernet Shield that can accept commands from a web-server PC and send values to a mysql database on the same to the web-server PC. Thanks for any help. Tony
« Last Edit: December 20, 2010, 03:20:41 pm by xsilvergs »
Seattle, WA USA
Seattle, WA USA
« Reply #23 on: December 20, 2010, 03:56:51 pm » |
Do you have error handling turned on in PHP?
Online
« Reply #24 on: December 20, 2010, 04:19:46 pm » |
I'm still unable to get the Arduino web-client to accept commands from a server PC. Well, it looks like you have a mix of client and server in your code which I haven't tried. I suggest you work on the client part first. A client sends a request to a server, and the server sends info back to the client. For the client to do something like turn on lights and such, the client needs to evaluate the info returned from the server for what to do. The below simple client code shows what is received by the client from a server. The actual requested info contained in the returned material is the "woohoo...zoomkat" part. The rest is standard HTTP stuff. For the client to act on the returned info, the "woohoo...zoomkat" part would need to be extracted and evaluated for commands. //zoomkat 11-13-10 //simple ethernet client test code //for use with IDE 0021 and W5100 ethernet shield //modify the arduino lan ip address as needed //open serial monitor to see what the arduino receives //push the shield reset button to run client again
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; byte ip[] = { 192, 168, 1, 102 }; byte server[] = { 208, 104, 2, 86 }; // zoomkat
if (client.connect()) { Serial.println("connected"); client.println("GET /~shb/arduino.txt HTTP/1.0"); client.println(); } else { Serial.println("connection failed"); } }
South Coast UK
« Reply #25 on: December 20, 2010, 04:39:05 pm » |
according to the .ini Yes. And this is what is sent to the php file: GET /update_db.php?celsius=45 HTTP/1.1
by this line client.println("GET /update_db.php?celsius=45 HTTP/1.1"); If this arduino is set up as a web-server why can I use this client.println("GET /update_db.php?celsius=45 HTTP/1.1"); Should it not be Server.print which gives errors when I try to Compile?
« Last Edit: December 20, 2010, 04:46:41 pm by xsilvergs »
Online
« Reply #26 on: December 20, 2010, 05:45:47 pm » |
Should it not be Server.print which gives errors when I try to Compile? I have no idea. Your code is such a jumble of stuff that I don't think I can be of any help. Sorry.
South Coast UK
« Reply #27 on: December 20, 2010, 05:46:09 pm » |
zoomkat. Thanks for your help but I'm getting nowhere. I've tried putting in just the code to turn the LED ON/OFF but it doesn't work and the serial monitor chucks out tons of stuff. I've been on this since 7am and it's now 10:45pm so here's my code: //zoomkat 11-13-10 //simple ethernet client test code //for use with IDE 0021 and W5100 ethernet shield //modify the arduino lan ip address as needed //open serial monitor to see what the arduino receives //push the shield reset button to run client again
byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0x11, 0xAC }; byte ip[] = { 192, 168, 1, 19 }; byte server[] = { 192,168,1,20 };
Client client(server, 80); String readString = String(30); //string for fetching data from address
void setup() { Ethernet.begin(mac, ip); Serial.begin(9600); //pin mode pinMode(7,OUTPUT); digitalWrite(7,LOW); // I use this pin as GND for the LED. pinMode(8,OUTPUT); // Sample output, unable to use built-in LED at pin 13 because Ethernet Shield uses pins 10,11,12,13.
void loop() { if (client.available()) { //########################################################### char c = client.read(); //read char by char HTTP request if (readString.length() < 30) { //store characters to string readString.concat(c); Serial.println(readString); } //output chars to serial port Serial.print(c); //if HTTP request has ended if (c == '\n') { //Turn on LED Serial.println(readString.substring(6,9));//for test to allow readString to be viewed if(readString.substring(6,9)=="7=1") {//read the last 3 information characters from URL // Serial.println(readString); //set digital 7 HIGH Serial.println("HIGH"); digitalWrite(7, HIGH); // set the LED on readString="";//clear readString } if(readString.substring(6,9)=="7=0") { //set digital 7 LOW Serial.println("LOW"); digitalWrite(7, LOW); // set the LED OFF readString="";//clear readString } } //###########################################################
if (!client.connected()) { Serial.println(); Serial.println("disconnecting."); Serial.println("=================================="); Serial.println(""); client.stop(); // for(;;); } } }
I'll have another go tomorrow perhaps!
Seattle, WA USA
Seattle, WA USA
« Reply #28 on: December 20, 2010, 07:42:47 pm » |
Think about what a web browser is doing when it executes a GET request. It is asking the server for some information. Typically, the server is expected to return a web page. For the 7=1 and 7=0 requests, the server should send back a page that says that the light was turned on, or off.
For the A=0 request, the client is expecting a value in return. The response from the server can be a page that redirects the browser to another page, with arguments in the redirect string.
What you were sending back was a GET request, which the client is not prepared to accept.
Tomorrow, I'll see if I can find some html/PHP code that that does a re-direct.
Online
« Reply #29 on: December 21, 2010, 04:11:53 am » |
I suggest trouble shooing your server/php/mysql by using your get request below in a brouser URL box, hit enter, and see if the desired result is returned. Bottom is some client code that sends a request to a server, and then extracts the desired data from what is returned. http://192.168.1.20/update_db.php?celsius=45//zoomkat 12-21-10 //simple ethernet client test code //for use with IDE 0021 and W5100 ethernet shield //modify the arduino lan ip address as needed //open serial monitor to see what the arduino receives //push the shield reset button to run client again
#include <SPI.h> #include <Ethernet.h> String readString, readString1;
void setup() { Ethernet.begin(mac, ip); Serial.begin(9600); Serial.println("starting simple arduino client test"); Serial.println(); Serial.println("connecting...");
if (client.connect()) { Serial.println("connected"); client.println("GET /~shb/arduino1.txt HTTP/1.0"); client.println(); } else { Serial.println("connection failed"); } }
void loop() { if (client.available()) { char c = client.read(); readString += c; } if (!client.connected()) { client.stop(); Serial.print(readString); Serial.println(); Serial.println(); int d1 = readString.indexOf('<'); int d2 = readString.indexOf('>'); readString1 = (readString.substring(d1+1,d2)); Serial.println("=================================="); Serial.println("data from server:"); Serial.println(); Serial.println(readString1); Serial.println(); Serial.println("=================================="); Serial.println(); for(;;); } }
