Loading...
Pages: 1 [2]   Go Down
Author Topic: SpeakJet /TTS Serial Question  (Read 4141 times)
Monterey CA
Offline Offline
Sr. Member
Addicted to Arduino
View Profile
WWW
I got it to work! Thanks for all the help. Here is the new code if anyone ever needs it.
As part of testing I switched to Newsoftserial, but both work. Not sure which I should stay with. I read something about it and servos which i will be using.
Code:
Testing Sketch for Robot
//Soft serial library used to send serial commands on pin 2 instead of regular serial pin.
#include <NewSoftSerial.h>
//Define the Pin Numbers of the Voicebox shield for the sketch.
#define E0  5
#define E1  6
#define E2  7
#define E3  8
#define E4  9
#define E5  10
#define E6  11
#define E7  12
#define RDY  13
#define RES  3
#define SPK  4
//Pin 2 of the shield should be wired to the TTS256 chip.
#define txPin  2
//Create a SoftSerial Object to send strings to the TTS256 chip.
NewSoftSerial speakjet(0, txPin);
//Create a message buffer to hold the ascii message to be converted to sound
char message[128]="";
char cmd[3]="";
int cmdCode;
  //Configure the pins for the SpeakJet module
  pinMode(txPin, OUTPUT);
  pinMode(SPK, INPUT);
  //Set up a serial port to talk from Arduino to the SpeakJet module on pin 3.
  speakjet.begin(9600);
  //Set up a serial port to get the ascii message from the host
  //Configure the Ready pin as an input
  pinMode(RDY, INPUT);
  //Configure Reset line as an output
  pinMode(RES, OUTPUT);
  //Configure all of the Event pins as outputs from Arduino, and set them Low.
  for(int i=E0; i<=E7; i++)
    pinMode(i, OUTPUT);
    digitalWrite(i, LOW);
  //All I/O pins are configured. Reset the SpeakJet module
  digitalWrite(RES, LOW);
  delay(100);
  digitalWrite(RES, HIGH);
  char sounds[] = {200, 201, 202, 203, 220, 221, 222};
  speakjet.println(sounds);
  //Get a message from the serial port
  getMessage(message, cmd);
  //Convert cmd from char to int
  cmdCode = atoi(cmd);
  //Send the message to the TTS256
  speakjet.println(message);
  while(digitalRead(RDY)==0);
  speakjet.println(cmdCode, BYTE);
  Serial.println(message);
  //Wait 12ms before checking the ready line (specified in TTS256 datasheet)
  delay(12);
  //Wait for the Speakjet to become 'ready' before sending more text.
//Function: getMessage(char *)
//Description: Retrieves a string from the Serial port. Doesn't return the string until a carriage return character is detected.
//Inputs: None
//Outputs: char * message - The message received on the serial port.
//Returns: Nothing
//usage: getMessage(english_sentance);
void getMessage(char * message, char * cmd)
    char in_char=0;    //Create a character to store the incoming byte from the serial port.
    //Wait for a character to come into the serial port
    while(Serial.available() <=0);
    //Copy the incoming character to our variable.
    in_char=Serial.read();
    //Keep retreiving characters until the 'end of sentance(0x0D)' character is received.
    while(in_char != 0x0D){
        if (in_char == 0x5C)
          while (in_char != 0x0D){
          while(Serial.available() <=0);    //Now wait for the next character...
          in_char = Serial.read();
          *cmd++=in_char;
        else {
        *message++=in_char;    //Every time we receive a character we should add the character to the message string.
        in_char = Serial.read();            //and copy it to the variable again.
   *message='\0';    //Strings must end with a Null terminator so we need to add this to our message.
   *cmd='\0';
    return;
Logged
Current Projects:                    Arduinos:
Security Robot Tank               Uno
Security Robot II 4WD            Mega2560
http://mobilewill.blogspot.com
Monterey CA
Offline Offline
Sr. Member
Addicted to Arduino
View Profile
WWW
I thought I would take it step further and try to handle multiple codes. So much for that. I changed the while loop to a for loop since all codes are 3 digits.
Is it possible to convert the code to a BYTE and insert it into the message char array so that it is sent inline? So that it is all sent at once and not to prints to serial?
EDIT: I figured it out, now I can read codes and insert then into the message array as a int, therefore having multiples codes and they are inline when it speaks back.
Here is the fine code
Code:
#define E0  5
#define E1  6
#define E2  7
#define E3  8
#define E4  9
#define E5  10
#define E6  11
#define E7  12
#define RDY  13
#define RES  3
#define SPK  4
#define txPin  2
char message2[128]="";
    pinMode(i, OUTPUT);
  delay(100);
  getMessage(message, message2);
  Serial.println(message2);
  print(message2);
  print(" ");
  delay(12);
//Inputs: None
//Returns: Nothing
void getMessage(char * message, char * message2)
    char cmd[4]="";
          for(int i = 0; i <= 2; i++){
          cmd[i]=in_char;
         int code = atoi(cmd);
         Serial.println(code);
         *message++=code;
        else {
        *message2++=in_char;
   *message2='\0';
    return;
The 2nd message array is so I can display the text to the serial and lcd without the codes.
« Last Edit: January 24, 2011, 12:59:50 am by wgarrido » Logged
Pages: 1 [2]   Go Up
Print
Jump to:
