Author Topic: add ability to write to EEPROM  (Read 1244 times)
Brooklyn, NY, USA
arduino for all
The Atmel ATMEGA8 has 512 bytes of EEPROM on the chip.  It would be very handy if we could use it with the Arduino language.
panta rei resist the resistors!
seek the "hidden powers" and ye shall find ;-)
look in the playground wiki under the code section
http://www.arduino.cc/playground/Main/CodeLib
cheers
b.
Forum Administrator
Cambridge, MA
That's not quite enough info.  The sample code below might help.  Maybe someone can update the wiki?  Also, this would be a great thing to have a library for; something like:
Eeprom.write(address, value, BYTE);
Eeprom.write(address, value, WORD);
Eeprom.read(address, BYTE);
Eeprom.read(address, WORD);
Here's the eeprom sample (copied by hand so maybe it's wrong):
#include <avr/eeprom.h>
unsigned int addr = 0;
  long value = eeprom_read_byte((unsigned char *) addr);
  //long value = eeprom_read_word((unsigned int *) addr);
  //eeprom_write_byte((unsigned char *) addr, addr); // fill each address with its own value
  addr = (addr + 1) % 512;
  Serial.println(value);
you asked it for
the wiki is now updated
the Eeprom library can be a very good thing to understand how to code libraries...
I'll see if I can give it a try...if I only could find a spare life lying around  smiley-razz
thanks mellis
b.
I post it here just for completenedd
I've found the reference page in the AVR-libc manuals
http://www.sigterm.de/projects/sens-o-nuts/Dokumentation/atmel/libc/group__avr__eeprom.html
I can say that your code is way more clear smiley
but hey...it's just a reference
cheers
b.
Britanny
Mais vrai, j'ai trop pleuré, toute lune est atroce
some code to use the eeprom read/write is here... sorry in french :'(
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1146607557
hope this'll be helpfull
eric
Slovenia
How to write over 255 i use intiger but somehow it cant compile if i don't use char?
Poitiers (France)
Ca va j'vais le faire !
Hello,
I think, ...
Declaration's of eeprom_read_byte (const uint8_t *addr) look wrong with tionuint8 (BYTE) for type of addr.
I have made some functions to read/write from/to eeprom.
void eeprom_wr_byte (unsigned int const * ptr, byte val)
  register byte sreg;
  sreg = SREG;
  cli();
  while ( EECR & (1 << EEWE )) {
    SREG = sreg;
    cli ();
  EEAR = (unsigned int)ptr;
  EEDR = val;
  EECR |= ( 1 << EEMWE );
  EECR |= ( 1 << EEWE );
  SREG = sreg;
void eeprom_wr_word (unsigned int const * ptr, unsigned int val)
  unsigned int uiTmp = (unsigned int)ptr;
  byte bH = (val >> 8) & 0xFF;
  byte bL = val & 0xFF;
  eeprom_wr_byte ((unsigned int *)uiTmp, bL);
  uiTmp++;
  eeprom_wr_byte ((unsigned int *)uiTmp, bH);
Cordialement,
Benoît ROUSSEAU
Poitiers (France)
And...
byte eeprom_rd_byte (unsigned int const * ptr)
  register byte sreg, tmp;
  sreg = SREG;
  cli();
    SREG = sreg;
    cli ();
  EECR |= (1 << EERE);
  tmp = EEDR;
  SREG = sreg;
  return tmp;
unsigned int eeprom_rd_word (unsigned int const * ptr)
  unsigned int iRet = 0;
  byte bH = 0;
  byte bL = 0;
  bL = eeprom_rd_byte ((unsigned int *)uiTmp);
  uiTmp++;
  bH = eeprom_rd_byte ((unsigned int *)uiTmp);
  iRet = bH;
  iRet = iRet << 8;
  iRet |= bL;
  return iRet;
« Last Edit: July 01, 2006, 12:28:02 pm by Benoit » Logged
Cordialement,
Benoît ROUSSEAU
Bremen, Germany
I played around with mellis pieces of code and made it work.
This code is tested and works for reading from and writing to the internal eeprom:
// simple read and write to internal eeprom
// by Kristian Gohlke / kr1 <http://filformat.net>
// reads or writes data to the eeprom and prints it to the screen
// the stored data is preserved even when the boards power connection is unplugged
// so you could think of the eeprom as arduinos amazing 512byte harddrive
// useful for storing the last few bytes of data from a sensor or to keep config settings
// try storing some data to your eeprom unplug the boards power supply and relax
// get back to it some days later to find your data lying there waiting for you untouched
// created 13 August 2006
// (cleft) 2006 Kristian Gohlke
byte e_in;  //holds the value to be written to the eeprom
byte e_out; //holds the value that is read from the eeprom
//the adress inside the eeprom to write to
//the eeprom can hold 512 bytes, so the adress space is from 0 to 511
//read or write ?
boolean writemode = true;
//boolean writemode = false;
//WRITE TO EEPROM
if(writemode){
  //set the value to be written to the eeprom
  e_in = 90;                  //the character "Z" (ascii code 90)
  //e_in = (e_in + 1) % 256;  //ascii characters 0 - 256
  eeprom_write_byte((unsigned char *) addr, e_in);
  //debug:
  Serial.print("WRITE addr: ");
  Serial.print(int(addr));
  Serial.print(" / e_in: ");
  Serial.print(int(e_in));  //prints eeprom value as integer
  Serial.print(" = ");
  Serial.println(e_in);     //prints eeprom value as ascii character
//READ FROM EEPROM
if(!writemode){
  e_out = eeprom_read_byte((unsigned char *) addr);
  //debug:
  Serial.print("READ addr: ");
  Serial.print(" / e_out: ");
  Serial.print(int(e_out));   //prints eeprom value as integer
  Serial.println(e_out);      //prints eeprom value as ascii character
  delay(20);
