Loading...
Pages: [1]   Go Down
Author Topic: typedef in function definition has a problem  (Read 1183 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
The following program produces a compiler error (Arduino 0011 alpha):
struct foo{
  int    a;
  int    b;
typedef struct foo FOO;
FOO  myvar[21];
FOO *myFunct(){}
void setup(){}
void loop(){}
ERROR is: error: expected constructor, destructor, or type conversion before '*' token
If I change
<FOO *myFunct(){}>
to
<struct foo *myfunct(){}> it compiles just fine.
Mike...
mikeasl@mac.com
Logged
Forum Administrator
Cambridge, MA
Offline Offline
Faraday Member
View Profile
WWW
You need to put type definition inside a separate header file, as the function prototypes that are generated by the IDE are inserted above the typedef (but below pre-processor directives like #include).  This header can be another tab in your sketch; use the right facing arrow in the upper right of the IDE.
Logged
Pages: [1]   Go Up
Print
Jump to:
