Loading...
Pages: 1 [2] 3   Go Down
Author Topic: LCD Library  (Read 948 times)
Forum Administrator
Cambridge, MA
Offline Offline
Faraday Member
View Profile
WWW
I've been doing multiline support the way that wiring does: not explicitly configuring it that way, but allowing you to move the cursor to any line you want.  I can write to all the lines on the 2 and 4 line displays I have.
gradbert: The constructor for the LiquidCrystal library on Arduino will be basically what you suggest.  The rest of the API will mirror Wiring's, although we could certainly add some functions (either now or later).
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Ok, I figured code speaks louder than words, so I took the LCD4bit library and combined it with the code from SoftwareSerial.  The constructor it the interface described previously.  It has the most of the same print() and println() functions as SoftwareSerial.  The print(uint8_t) is replaced with rprint(uint8_t).  something with the casting was giving me grief.  All the printing functions have been moved to a class called Printable.  the LCDnew class only has to implement rprint().  I don't have the carrage return/line feed handling implemented in the LCD class yet.
check it out at http://www.gradbert.org/ldcnew.zip
I still need to do some work on this but I figure some early feedback would be good
Logged
London
Offline Offline
Faraday Member
Have fun!
View Profile
hi gradbert, I am looking forward to trying your LCD library but your site is not responding.
« Last Edit: April 29, 2008, 08:41:01 am by mem » Logged
Forum Administrator
Cambridge, MA
Offline Offline
Faraday Member
View Profile
WWW
gradbert: cool.  I actually did something similar (see: http://svn.berlios.de/wsvn/arduino/trunk/hardware/cores/arduino/), but you've got some nice improvements.  I like the name Printable better than Print, which is what I used.  Also, did you get this to work on the Arduino?  I had trouble getting virtual functions to compile, so I hacked together my own version.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Quote
I should be more careful posting late at night.  The correct url is http://www.gradbert.org/lcdnew.zip
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Quote
I did get it working.  In the zip file is an example program that will compile, download, and display on an lcd.  The only thing that was really giving me a problem was that the build doesn't seem to be very happy with a library including another library, so in my sketch I have to explicitly include <Printable.h>.
Now because the pin assignments are local to the instance of the object, I should be able to hook up two lcd displays at once.  If I have some time this week, I will make a second lcd cable and try it.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Here is a pic of an arduino driving two lcd's at once using the lcd library i have been playing with
(the small circuit board on the protoboard is a 3 axis accelerometer, for another project)
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
I have the println() methods working now.  The new version is at http://www.gradbert.org/lcdnew.zip
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
will this work with serial-enabled LCDs?
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
no, this is for paralele interfaced LCD's with the hitachi chipset.
Logged
Underhill Center, Vermont, USA
Offline Offline
Jr. Member
Arduino rocks
View Profile
WWW
Quote
I have a library for an LCD driven by Software Serial. The command codes are for a PH Anderon controller chip, but they would be trivially easy to edit.
http://www.wulfden.org/downloads/code/arduino/SWSerialLCDPHA_Lib.zip
cheers ... BBR
Logged
New Zealand
Offline Offline
God Member
Arduino pebbles
View Profile
WWW
Quote
It will support both 4 and 8 bit modes (though is there any reason you'd want to use the 8-bit one?).
Isn't there some non-trivial speed difference between the two methods? (From memory, not personal experience.)
--Phil.
Logged
Sydney, Australia
Offline Offline
Newbie
View Profile
WWW
Quote
cheers ... BBR
I must thank everyone so far for their efforts for a unified 8 and 4-bit library, but wouldn't it be prudent to also support a serial version of this new library? I was thinking of just an undertaking...but many wonderful people here have already started and I wouldn't dream of encroaching upon their work smiley
Logged
Forum Administrator
Cambridge, MA
Offline Offline
Faraday Member
View Profile
WWW
As far as I know, different serial LCDs have different protocols, which makes it hard to write a single library to talk to them.  But if anyone wants to take a shot at creating a nice system for supporting multiple protocols and selecting between them, that would be cool.
Logged
San Antonio, TX USA
Offline Offline
Newbie
Arduino rocks
View Profile
What's the process for the code getting merged into the other 4/8bit hitachi and/or serial LCD librar(ies)?
Also.. Please provide a clear hookup diagram for your version.. I've seen a half dozen different hookup configs.. none of which are compatible with each other.
 Tweeks
Logged
Pages: 1 [2] 3   Go Up
Print
Jump to:
