Topic: LCD Library (Read 10674 times) previous topic - next topic
mellis
I've been doing multiline support the way that wiring does: not explicitly configuring it that way, but allowing you to move the cursor to any line you want.  I can write to all the lines on the 2 and 4 line displays I have.
gradbert: The constructor for the LiquidCrystal library on Arduino will be basically what you suggest.  The rest of the API will mirror Wiring's, although we could certainly add some functions (either now or later).
gradbert
Ok, I figured code speaks louder than words, so I took the LCD4bit library and combined it with the code from SoftwareSerial.  The constructor it the interface described previously.  It has the most of the same print() and println() functions as SoftwareSerial.  The print(uint8_t) is replaced with rprint(uint8_t).  something with the casting was giving me grief.  All the printing functions have been moved to a class called Printable.  the LCDnew class only has to implement rprint().  I don't have the carrage return/line feed handling implemented in the LCD class yet.
check it out at http://www.gradbert.org/ldcnew.zip
I still need to do some work on this but I figure some early feedback would be good
mem
#17
Apr 29, 2008, 03:40 pm Last Edit: Apr 29, 2008, 03:41 pm by mem Reason: 1
hi gradbert, I am looking forward to trying your LCD library but your site is not responding.
mellis
gradbert: cool.  I actually did something similar (see: http://svn.berlios.de/wsvn/arduino/trunk/hardware/cores/arduino/), but you've got some nice improvements.  I like the name Printable better than Print, which is what I used.  Also, did you get this to work on the Arduino?  I had trouble getting virtual functions to compile, so I hacked together my own version.
gradbert
I should be more careful posting late at night.  The correct url is http://www.gradbert.org/lcdnew.zip
gradbert
I did get it working.  In the zip file is an example program that will compile, download, and display on an lcd.  The only thing that was really giving me a problem was that the build doesn't seem to be very happy with a library including another library, so in my sketch I have to explicitly include <Printable.h>.
Now because the pin assignments are local to the instance of the object, I should be able to hook up two lcd displays at once.  If I have some time this week, I will make a second lcd cable and try it.
gradbert
Here is a pic of an arduino driving two lcd's at once using the lcd library i have been playing with
(the small circuit board on the protoboard is a 3 axis accelerometer, for another project)
gradbert
I have the println() methods working now.  The new version is at http://www.gradbert.org/lcdnew.zip
tigrezno
will this work with serial-enabled LCDs?
gradbert
no, this is for paralele interfaced LCD's with the hitachi chipset.
brianbr
I have a library for an LCD driven by Software Serial. The command codes are for a PH Anderon controller chip, but they would be trivially easy to edit.
http://www.wulfden.org/downloads/code/arduino/SWSerialLCDPHA_Lib.zip
cheers ... BBR
follower
It will support both 4 and 8 bit modes (though is there any reason you'd want to use the 8-bit one?).
Isn't there some non-trivial speed difference between the two methods? (From memory, not personal experience.)
--Phil.
cmroanirgo
cheers ... BBR
I must thank everyone so far for their efforts for a unified 8 and 4-bit library, but wouldn't it be prudent to also support a serial version of this new library? I was thinking of just an undertaking...but many wonderful people here have already started and I wouldn't dream of encroaching upon their work :)
mellis
As far as I know, different serial LCDs have different protocols, which makes it hard to write a single library to talk to them.  But if anyone wants to take a shot at creating a nice system for supporting multiple protocols and selecting between them, that would be cool.
tweeks
What's the process for the code getting merged into the other 4/8bit hitachi and/or serial LCD librar(ies)?
Also.. Please provide a clear hookup diagram for your version.. I've seen a half dozen different hookup configs.. none of which are compatible with each other.
Tweeks
