Topic: on autoformat: String index out of range: 1023 (Read 923 times) previous topic - next topic
Nessuno
With a project (1 file only+1library) when i try to autoformat the code i get....
java.lang.StringIndexOutOfBoundsException: String index out of range: 1023
     at java.lang.String.charAt(String.java:558)
     at processing.app.tools.AutoFormat.getchr(AutoFormat.java:313)
     at processing.app.tools.AutoFormat.show(AutoFormat.java:499)
     at processing.app.Editor$15.actionPerformed(Editor.java:728)
     at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1849)
     at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2169)
     at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:420)
     at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:258)
     at javax.swing.AbstractButton.doClick(AbstractButton.java:302)
     at javax.swing.AbstractButton.doClick(AbstractButton.java:282)
     at javax.swing.plaf.basic.BasicMenuItemUI$Actions.actionPerformed(BasicMenuItemUI.java:969)
     at javax.swing.SwingUtilities.notifyAction(SwingUtilities.java:1571)
     at javax.swing.JComponent.processKeyBinding(JComponent.java:2772)
     at javax.swing.JMenuBar.processBindingForKeyStrokeRecursive(JMenuBar.java:656)
     at javax.swing.JMenuBar.processBindingForKeyStrokeRecursive(JMenuBar.java:664)
     at javax.swing.JMenuBar.processKeyBinding(JMenuBar.java:640)
     at javax.swing.KeyboardManager.fireBinding(KeyboardManager.java:255)
     at javax.swing.KeyboardManager.fireKeyboardAction(KeyboardManager.java:242)
     at javax.swing.JComponent.processKeyBindingsForAllComponents(JComponent.java:2849)
     at javax.swing.JComponent.processKeyBindings(JComponent.java:2841)
     at javax.swing.JComponent.processKeyEvent(JComponent.java:2735)
     at processing.app.syntax.JEditTextArea.processKeyEvent(JEditTextArea.java:1637)
     at java.awt.Component.processEvent(Component.java:5278)
     at java.awt.Container.processEvent(Container.java:1966)
     at java.awt.Component.dispatchEventImpl(Component.java:3968)
     at java.awt.Container.dispatchEventImpl(Container.java:2024)
     at java.awt.Component.dispatchEvent(Component.java:3803)
     at java.awt.KeyboardFocusManager.redispatchEvent(KeyboardFocusManager.java:1826)
     at java.awt.DefaultKeyboardFocusManager.dispatchKeyEvent(DefaultKeyboardFocusManager.java:677)
     at java.awt.DefaultKeyboardFocusManager.preDispatchKeyEvent(DefaultKeyboardFocusManager.java:934)
     at java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(DefaultKeyboardFocusManager.java:806)
     at java.awt.DefaultKeyboardFocusManager.dispatchEvent(DefaultKeyboardFocusManager.java:641)
     at java.awt.Component.dispatchEventImpl(Component.java:3841)
     at java.awt.Window.dispatchEventImpl(Window.java:1778)
     at java.awt.EventQueue.dispatchEvent(EventQueue.java:463)
     at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:242)
     at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:163)
     at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:157)
     at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:149)
     at java.awt.EventDispatchThread.run(EventDispatchThread.java:110)
my source code is this:
http://docs.google.com/Doc?id=dgwcpkhh_1389qq36g8
if i remove the blue part, the autoformat works.
the blue part is:
int temposterzo=800; //tempo per girare di 90° tutto il robot
int compensazione=255;
char* latocomp="D"; //motore da compensare D o S o N nessuno
Nessuno
OS: Xandros on eee900 (installed like this http://www.arduino.cc/playground/Linux/Xandros)
Arduino: 0011 alpha
set on board: Diecimila
mellis
Maybe it's confused by the degree sign?  You might try deleting that.
Nessuno
at the moment i can't try, but it's not about that line.
if i delete only 1 or 2 of those lines, it still gives that error. i have to delete all the 3 lines!
i've done other projects with the degree sign.. in a thermometer project that sign is used many many times!
mellis
Hmm, okay.
Can you reduce the sketch to a small one that has the same problem?  That would make it easier to debug.
Nessuno
later i'll try that, too.
update #1: the same code, on arduino 0011 alpha, on WIN XP, doesn't have this problem, it auto-formats correctly.
so this seems only a linux problem?
Nessuno
update #2: on linux, removing the "°" degree symbol fixes the problem.
maybe when i tried to remove lines line by line i forgot the first one.
so... a degree sign on linux only will break autoformat.
maybe the thermometer project i compiled was under win
