Las Vegas, NV
Offline
God Member
« on: May 15, 2008, 05:08:27 pm » |
I've been looking at the implementation of the millis() function and, unless I've missed something, I've noticed that it does not account for the possibility of a timer0 overflow interrupt occuring in the middle of the retrieval of timer0_overflow_count. Since this variable is a long, accessing it requires a non-atomic operation that becomes interruptable.
For example, imagine you call millis() when timer0_overflow_count is 0x0000FFFF, and in the middle of retrieving timer0_overflow_count the timer0 overflow interrupt occurs. If the interrupt happens after you've loaded the two highest bytes but before you've loaded the two lowest bytes, millis() will return 0.
The odds of this happening are quite low, so this bug would manifest itself as an exceedingly rare and almost impossible-to-duplicate run-time error in code that relies on millis() for timing. An example of a simple fix for this would be:
// new global variable to flag when an overflow has occurred unsigned char timer0_overflow_flag;
SIGNAL(SIG_OVERFLOW0) { timer0_overflow_count++; timer0_overflow_flag = 1; // flag the overflow }
unsigned long millis() { unsigned long count; do { timer0_overflow_flag = 0; // clear the overflow flag count = timer0_overflow_count; // read timer0_overflow_counter } while (timer0_overflow_flag); // if an overflow occurred during the read, try again
return count * 64UL * 2UL / (F_CPU / 128000UL); }
You should use a similar construction if you ever set timer0_overflow_flag equal to a value since an interrupt in the middle of the setting process can cause problems.
- Ben
Logged
London
Offline
Faraday Member
Have fun!
« Reply #1 on: May 15, 2008, 11:11:47 pm » |
Hi Ben, thats a neat way of handling the problem without disabling interrupts but I think you need to declare the timer0_overflow_flag volatile or the compiler will optimise out the test to see if its set; // new global variable to flag when an overflow has occurred volatile unsigned char timer0_overflow_flag; // <- this needs to be declared volatile
« Last Edit: May 15, 2008, 11:16:17 pm by mem »
Logged
Las Vegas, NV
Offline
God Member
« Reply #2 on: May 16, 2008, 12:46:33 am » |
Hi Ben, thats a neat way of handling the problem without disabling interrupts but I think you need to declare the timer0_overflow_flag volatile or the compiler will optimise out the test to see if its set; Very true, thanks for pointing that out! - Ben
Logged
Forum Administrator
Cambridge, MA
Offline
Faraday Member
« Reply #3 on: May 16, 2008, 09:20:51 am » |
We've implemented something similar in SVN, which will be in Arduino 0012. From wiring.c: volatile unsigned long timer0_clock_cycles = 0; volatile unsigned long timer0_millis = 0;
SIGNAL(SIG_OVERFLOW0) { // timer 0 prescale factor is 64 and the timer overflows at 256 timer0_clock_cycles += 64UL * 256UL; while (timer0_clock_cycles > clockCyclesPerMicrosecond() * 1000UL) { timer0_clock_cycles -= clockCyclesPerMicrosecond() * 1000UL; timer0_millis++; } }
unsigned long millis() { unsigned long m; uint8_t oldSREG = SREG; cli(); m = timer0_millis; SREG = oldSREG; return m; } How's that seem? Do you think it's better to use the overflow flag as in your code instead of temporarily disabling interrupts?
Logged
Las Vegas, NV
Offline
God Member
« Reply #4 on: May 16, 2008, 01:57:17 pm » |
Thanks for the detailed response, Mellis. I have a few comments about these changes (one major gripe and two minor gripes):
1) You've increased the time spent in the time overflow ISR by a tremendous factor, especially when you note that every operation is dealing with four-byte longs. I like that in 0011 you keep the ISR as short as possible and do the time-consuming computation in millis(), which is called only when the user needs it. By moving the computations to the ISR, you're forcing the CPU to evaluate them every timer overflow and occuping valuable CPU processing time. This could become especially devastating if someone runs timer0 with a lower prescaler, such as 8 or 1, and still wants to catch timer overflows. Additionally, spending a lot of time in the timer0 overflow interrupt means that other more important interrupts are potentially delayed, which could hurt certain applications.
My advice is to stick to the principle of "get in and get out" when dealing with interrupts. Let the interrupt set up the calculation, but actually perform the calculation outside the interrupt if at all possible.
I'm currently writing a motor-control Arduino library for the Orangutan and Baby Orangutan robot controllers. These use timer0 and timer2 to generate the PWMs that control the motor drivers, but those timers need to run using a prescaler of 8 if they are to produce a 10 kHz PWM. I had intended to provide my own version of millis() as part of the library that would account for the faster timer0 clock, but I think with the above changes I would just have to disable timer0 interrupts altogether to keep the CPU from getting overly monopolized by the interrupt. With a prescaler of 8, the interrupt will happen every 2048 clock cycles, and I estimate that the current (0011) interrupt probably requires around 51 clock cycles, so I lose around 2.5% of my CPU processing time. Your new ISR could be anywhere from twice to maybe five times that, depending on whether clockCyclesPerMicrosecond() is a macro or an actual function call and depending on how many times the loop iterates.
2) This is a pretty minor gripe, but I don't like disabling global interrupts because someone else might be relying on them for some extremely time-critical application. I think the more friendly approach would be to only disable the interrupt that could potentially cause the problem:
uint8_t temp = TIMSK0; // store current state of TIMSK0 TIMSK0 &= ~(1 << TIOE0); // disable timer0 overflow interrupts m = timer0_millis; TIMSK = temp; // restore TIMSK0 to previous state (i.e. enable interrupts if they were enabled)
On the other hand, globally disabling interrupts for 9 cycles probably isn't going to be too much of a hardship on people given that they already have to deal with having interrupts disabled for much longer time periods by the timer0 overflow interrupt itself. Either way, I think this is a fine equivalent to my suggested overflow-flag approach and it has the added benefit of being harder to screw up (e.g. forgetting to make the flag volatile) and easier to understand.
3) In your proposed new construction, you probably no longer need to declare timer0_clock_cycles as volatile (assuming it's only used inside the timer0 overflow ISR). Any compiler optimizations will be valid since there's no chance of an ISR changing its value as you're using it. By keeping it volatile, you're forcing the ISR to load all four bytes from RAM (8 cycles) and save all four bytes to RAM (8 cycles) every time you do something like
timer0_clock_cycles -= something;
- Ben
« Last Edit: May 16, 2008, 01:59:13 pm by bens »
Logged
Forum Administrator
Cambridge, MA
Offline
Faraday Member
« Reply #5 on: May 16, 2008, 03:59:23 pm » |
We wanted to eliminate the rollover in the millis() values, and increasing the work done in the interrupt seemed like the easiest way to do that. Changing the timer 0 prescale factor or overflow frequency isn't "supported" functionality and most people never do it, but they do run into the millis() overflow problem. Do you want to try eliminating the overflow by improving the millis() function and leaving the interrupt handler as it was? I'd love to do it that way, but don't really have time to write the code myself.
Logged
Las Vegas, NV
Offline
God Member
« Reply #6 on: May 16, 2008, 05:31:53 pm » |
Sure, I'll see if I can come up with something that meets with your approval. Also, the millis() overflow doesn't have to be much of a problem if you do your timing using differences rather than absolute numbers. For example, if I want to see if one hour has passed since the last "event" (i.e. the last time I checked and stored millis()), I can do it in two different ways:
1)
if (millis() >= lastEventMillis + 3600000UL) do something;
2)
if (millis() - lastEventMillis >= 3600000UL) do something;
Technique number 1 will fail if millis() has overflowed, but technique number 2 will always work. The only problem I can see that arises from the millis() overflow is that you can't time durations longer than 9 hours, but how often does something like this come up?
- Ben
Logged
Forum Administrator
Cambridge, MA
Offline
Faraday Member
« Reply #7 on: May 16, 2008, 08:46:51 pm » |
That's what I thought, too, the first few times people brought up the overflow problem. Unfortunately, that doesn't work, because millis() doesn't overflow on an even data size boundary, but instead as the result of an intermediate calculation. So the workarounds get uglier.
Logged
London
Offline
Faraday Member
Have fun!
« Reply #8 on: May 17, 2008, 03:14:19 am » |
The following doesn't solve the millis problem but it does avoid overflows for time intervals measured in seconds or more, and it also adds a useful real time clock capability. A few lines of code added to the overflow counter in wiring.c can provide an accurate count of seconds that doesn't overflow. It uses the Unix like unsigned long seconds count since Jan 1 1970, so it does actuallly overflow in 2038, but this is unlikely to be an inconvenience. volatile unsigned long timer0_overflow_count; // the timer overflow counter volatile byte timer0_overflow_flag; // Bens' flag to indicate timer overflow
volatile unsigned long sysTime; // seconds since midnight Jan 1 1970 // two counters used to determine 976.5625 counts without using time consuming math volatile static unsigned int overflowCounter; volatile static byte fracOverflows;
timer0_overflow_flag = 1; // flag the overflow – Bens idea :>) // code added below increments Time counter every 976.5625 overflows (i.e. exactly once per second) ++fracOverflows; // this counter tells us fractional overflows without using floating point if( ++overflowCounter >= 976) { if( (fracOverflows >= 144)||(overflowCounter >= 977) ) // 144 divided by 256 equals 0.5625 { overflowCounter = 0; sysTime++; // increment the seconds counter } } }
// functions to get and set the system time unsigned long getTime() { unsigned long _time; // return the system time do { timer0_overflow_flag = 0; // clear the overflow flag _time = sysTime; } while (timer0_overflow_flag); // if an overflow occurred during the read, try again return _time; }
void setTime(unsigned long time) { // set the system time to the given time value (as seconds since Jan 1 1970) cli(); //disable interrupts sysTime = time; sei(); // enable interrupts }
This approach allows the addition and subtraction of time (in seconds) without overflow problems. It also makes it easy to get clock time information in an arduino sketch. I have a library for managing clock time that would be useful if you wanted to adopt this approach, here are some of the methods: void Sync(time_t time); // sync clock (typically uses messages on the serial port) time_t now(); // return the current time as seconds since Jan 1 1970 boolean available(); //Refreshes the time properties below, returns true if clock is synched. // read only time properties. // These are accurate to the nearest second of the most recent call to available(); byte Hour; byte Minute; byte Second; byte Day; byte DayofWeek; byte Month; // Jan is month 0 byte Year; // year minus 1900 I would be happy for any of this to be included in a future Arduino release if it would be useful.
« Last Edit: May 17, 2008, 03:23:45 am by mem »
Logged
Las Vegas, NV
Offline
God Member
« Reply #9 on: May 20, 2008, 02:14:02 pm » |
That's what I thought, too, the first few times people brought up the overflow problem. Unfortunately, that doesn't work, because millis() doesn't overflow on an even data size boundary, but instead as the result of an intermediate calculation. So the workarounds get uglier. Hmm, I was hoping things would just happen to work out with the overflow, but I guess I should have actually tried to work out the details. In that case, unless there are details I'm still neglecting, you could just force a timer0_overflow_count on an even data size boundary. For example: SIGNAL(SIG_OVERFLOW0) { unsigned long temp = timer0_overflow_count; temp++; if (temp == 33554432UL) // if (temp == 0x10000 / 128) temp = 0; timer0_overflow_count = temp; } I believe this would allow differential timing to work beyond the overflow while adding fewer than 10 cycles to the ISR. - Ben
Logged
Las Vegas, NV
Offline
God Member
« Reply #10 on: May 20, 2008, 02:21:49 pm » |
The following doesn't solve the millis problem but it does avoid overflows for time intervals measured in seconds or more, and it also adds a useful real time clock capability. I like it, especially since it doesn't bog down the ISR with too many extra calculations. void setTime(unsigned long time) { // set the system time to the given time value (as seconds since Jan 1 1970) cli(); //disable interrupts sysTime = time; sei(); // enable interrupts }
The version of this function that relies on the overflow flag would be: void setTime(unsigned long time) { do { timer0_overflow_flag = 0; sysTime = time; } while (timer0_overflow_flag); } But it might just be simpler to either disable interrupts or disable timer0 overflow interrupts for the duration of the write. - Ben
Logged
London
Offline
Faraday Member
Have fun!
« Reply #11 on: May 20, 2008, 03:23:12 pm » |
Hi Ben, If millis() overflows cleanly then I can increment the time outside the ISR time_t DateTimeClass::now() // return the current time { while( millis() - prevMillis >= 1000){ this->sysTime++; this->prevMillis += 1000; } return sysTime; }
void DateTimeClass::setTime(time_t time) {
this->sysTime = time; this->prevMillis = millis(); }
But I would much prefer if the timer0 overflow interrupt incremented sysTime as per my earlier post, this eliminate the extra four bytes for the prevMillis counter. BTW, i would expect that setTime would be called infrequently (typically once a day, perhaps once an hour at most) so disabling interrupts for that call should not be a problem. There is a thread on the DateTime library here: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1211215328
« Last Edit: May 20, 2008, 03:26:23 pm by mem »
Logged
Forum Administrator
Cambridge, MA
Offline
Faraday Member
« Reply #12 on: May 20, 2008, 03:24:13 pm » |
bens: are you sure that will make the return values of millis() overflow on an even boundary? The problem is that there's a division at the end of the millis() calculation, so an overflow at a nice variable size boundary in the intermediate calculation ends up as a weird overflow in the final result. Again, the priority is making millis() work well, not necessarily optimizing the ISR.
Logged
Las Vegas, NV
Offline
God Member
« Reply #13 on: May 20, 2008, 04:08:58 pm » |
bens: are you sure that will make the return values of millis() overflow on an even boundary? The problem is that there's a division at the end of the millis() calculation, so an overflow at a nice variable size boundary in the intermediate calculation ends up as a weird overflow in the final result. Again, the priority is making millis() work well, not necessarily optimizing the ISR. I understand the priority, I'm just looking for a solution that would accomplish both. If you change the overflow-compare number to 33554375, it will overflow on an even boundary if F_CPU is 16 MHz (since this number is divisible by 125). If F_CPU is not 16 MHz, the divisor is a truncated float and millis won't work right anyway. Just out of curiosity, have you ever considered using timer1 as your millis() generator, or is timer1 being used for something else? You could have init() configure timer1 to overflow every millisecond and then you wouldn't have to do any calculations at all. For example: // configure timer1 for CTC mode, TOP is OCR1A, clock source is I/O clock (F_CPU) TCCR1A = 0; TCCR1B = 0x09; OCR1A = F_CPU / 1000; // set TOP so TCNT1 overflows every 1ms TIMSK1 |= 1 << TOIE1; // enable timer1 overflow interrupt The two plus sides to this: 1) It will work for pretty much any F_CPU (so long as it's a multiple of 1000). 2) The ISR simply updates a millisecond counter (unsigned long) that can time for 49.7 days without overflowing, and when it does overflow, there are no uneven data boundary issues. You'd still want to implement a getMillis() and setMillis() function to ensure uninterrupted reads and writes of the millisecond counter, though. Just a thought. - Ben
« Last Edit: May 20, 2008, 04:09:32 pm by bens »
Logged
London
Offline
Faraday Member
Have fun!
« Reply #14 on: May 20, 2008, 04:40:45 pm » |
Just out of curiosity, have you ever considered using timer1 as your millis() generator, or is timer1 being used for something else? - Ben
I would not be happy if timer1 was lost to millis. Its too useful for other things like input capture and precision timing. Half of my Arduino code would break
« Last Edit: May 20, 2008, 04:42:22 pm by mem »
Logged
