Pages: [1] 2 3   Go Down
Author Topic: software serial2  (Read 1223 times)
i need to use software serial to interface with the xport, but i couldnt get consistant results, even at 9600 so i poked at it a little and made a version that uses a pinchange interrupt (for diecimila or NG with chip upgrade only!). now it buffers the input characters to avoid the dreaded 'lost bits' errors i got.
it seems to work great! i will clean it up and make it more 'objecty' and maybe turn it into a library, but if someone wants to play with it...
 * Software UART
int ledPin = 13;                // LED connected to digital pin 13
#include <avr/pgmspace.h>
#define altPrint(x) alt_ROMputstring(PSTR(x), 0)
#define altPrintln(x) alt_ROMputstring(PSTR(x), 1)
int rxpin, txpin, altserialdelay = 0;
#define MAX_ALTRX_BUFF 8
char altRXD[MAX_ALTRX_BUFF];
int altrxsize = 0;
SIGNAL(SIG_PIN_CHANGE0)
  if ((rxpin >=8) && (rxpin <= 13)) {
    altRecv();
SIGNAL(SIG_PIN_CHANGE2)
  if (rxpin <smiley-cool {
    altRecv();
void altDelay(int delay) {
  while (delay != 0) {
     delay--;
void altRecv(void) {
  char i, d = 0;
  if (digitalRead(rxpin))
    return;       // not ready!
  altDelay(altserialdelay-5); // one half bit
  for (i=0; i<8; i++) {
    PORTB |= _BV(5);
    altDelay(altserialdelay*2); // one bit
    PORTB &= ~_BV(5);
      d |= (1 << i);
  altRXD[altrxsize] = d; // save data
  altrxsize++;  // got a byte
void altSerialSetup(int baudrate, char tx, char rx) {
  txpin = tx;
  pinMode(txpin, OUTPUT);
  digitalWrite(txpin, HIGH);
  rxpin = rx;
  pinMode(rxpin, INPUT);
  digitalWrite(rxpin, HIGH);  // pullup!
  if (baudrate == 19200) {
     altserialdelay = 62; // these are determined experimentally
  } else if (baudrate == 9600) {
     altserialdelay = 128;  // these are determined experimentally
  if (rxpin < smiley-cool {
    // a PIND pin, PCINT16-23
    PCMSK2 |= _BV(rxpin);
    PCICR |= _BV(2);
  } else if (rxpin <= 13) {
    // a PINB pin, PCINT0-5
    PCICR |= _BV(0);
    PCMSK0 |= _BV(rxpin-8);
void altPutchar(char d) {
  int i;
  cli();  // turn off interrupts, make it nice & kleen
  digitalWrite(txpin, LOW);       //start bit
  for (i=0; i< 8; i++) {
    if (d & 0x1) {
    d >>= 1;
  digitalWrite(txpin, HIGH);     // one stop bit
  sei();   // turn on interrupts
void alt_ROMputstring(const char *str, uint8_t nl) {
  uint8_t i;
  for (i=0; pgm_read_byte(&str); i++) {
    altPutchar(pgm_read_byte(&str));
  if (nl) {
    altPutchar('\n'); altPutchar('\r');
void altPrintNumber(uint16_t n) {
      uint8_t cnt=0, flag=0;
      while (n >= 10000UL) { flag = 1; cnt++; n -= 10000UL; }
      if (flag) altPutchar('0'+cnt);
      cnt = 0;
      while (n >= 1000UL) { flag = 1; cnt++; n -= 1000UL; }
      cnt = 0;
      while (n >= 100UL) { flag = 1; cnt++; n -= 100UL; }
      cnt = 0;
      while (n >= 10UL) { flag = 1; cnt++; n -= 10UL; }
      cnt = 0;
      altPutchar('0'+n);
      return;
int altAvailable(void) {
void setup()                    // run once, when the sketch starts
  pinMode(ledPin, OUTPUT);      // sets the digital pin as output
  altSerialSetup(9600, 2, 3);
int counter=0;
void loop()                     // run over and over again
  digitalWrite(ledPin, LOW);    // sets the LED off
  if (altrxsize) {
      Serial.print(altRXD[0]);
      altrxsize--;
  if (Serial.available()) {
      altPutchar(Serial.read());
Forum Administrator
Cambridge, MA
Awesome.
The current SoftwareSerial library kind of sucks, so it would be great to have this as a replacement.  Let us know when you do and I can include it in the distribution.
ok i fixed it
http://www.ladyada.net/make/eshield/AFSoftSerial.zip
supports RX and TX, up to 57600 tested. due to the delay inherent in digitalRead() its probably not possible to go any faster.
should probably be poked at by others. currently only for Diecimila (16mhz atmega168)
#include <AFSoftSerial.h>
AFSoftSerial mySerial =  AFSoftSerial(3, 2);
void setup()  {
  pinMode(13, OUTPUT);
  // set the data rate for the SoftwareSerial port
  mySerial.begin(9600);
  mySerial.println("Hello, world...");
  if (mySerial.available()) {
      Serial.print((char)mySerial.read());
      mySerial.print((char)Serial.read());
skcor oniudrA
ok i fixed it
void setup()  {
What a genius, you rock! That fixes a huge problem, that would enable a few serial devices to be connected to one board, how did you do it?
Will it work with BT's, Lilypads and NG's?
« Last Edit: February 05, 2008, 10:55:13 pm by John_Ryan » Logged
actually you can only have one software serial device at a time (right now) because of the pinchange interrupt. i could adapt it for more but its a real hassle and, well, i figure this is good enough for now.
er, no..."currently only for Diecimila (16mhz atmega168)"  smiley-wink
London
Have fun!
Thanks for that, it will be a huge help.
One question, with interrupts turned off when sending a char, does that mean that receive bits will be lost if they are presented at the same time as a character is being sent?
skcor oniudrA
er, pity
yes
but the old software serial couldnt do that either so its not really a big deal
er, pity
send me a lilypad an an NG with an 8mhz xtal and ill make it work with 'em!
skcor oniudrA
er, pity
I needed a solution a while back, but improvised this instead.
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1201476854/5#5
This should work with your 168's aye, if I wanted to make something like a dualCoreDuino  ;D
London
Have fun!
yes
No big deal at all (as long as users are aware that data may be missed if received while sending). Many thanks for taking the time and effort to impliment this. It will be very useful to me and I am sure many other people.
« Last Edit: February 06, 2008, 05:01:43 am by mem » Logged
Brisbane, Australia
Isnt the Lillypad a 168? Not sure about the Bluetooth one.
London
Have fun!
I believe the lilypad uses the internal clock so runs at 8mhz.
Hello ladyada,
      I am working on the RFID reader which operates at baudrate 2400. I have tried to amend your coding in order to support it but I cannot figure out the correct  _bitDelay for baudrate 2400....
Would you please provide me the library that supports baudrate 2400?!
Thanks for your assistant in advance!!!!!
skcor oniudrA
You don't need to be changing the library, the parameters are set by the application.
SS works "up to" 9600, so the phidgets at 2400 should be fine
  mySerial.begin(2400);
You'll need to remove the 'hello world' of course smiley
Pages: [1] 2 3   Go Up
