Topic: Atmel Microcontroller with Bipolar ADC  (Read 548 times) previous topic - next topic
GolamMostafa
1. My upcoming hobby is to build a True RMS Voltmeter.
2. I need to sample both the positive ans negative portions of the Line Volatge.
3. Is there any Atmel MCU that contains bipolar ADC?
4. Thanks in advance.
CrossRoads
KeithRB
Just use a precision rectifier.
(Or do like an RF bolometer. Use the AC to heat a thermistor and monitor the change in resistance. Now *that* is True RMS.)
MasterT
You can read negative half wave simply biasing input at Vcc/2 .
https://learn.openenergymonitor.org/electricity-monitoring/ctac/how-to-build-an-arduino-energy-monitor?redirected=true
KeithRB
If he really wants a "True RMS" meter he needs to account for the DC component.
GolamMostafa
1. By definition:
TRMS value of alternating wave of arbitrary wave shape
 = sqrt ( additions of the squares of samples over 3-5 cycles (at least 10 times
    of signal frequency; fulfilling of Nyquist Criterion is not enough in practice) and then divided by sample
    interval)
    The above formula automatically includes the DC component of the signal. Sampling, squaring, addition,
    division, square root, and finally normalisation; all these can be done in a pretty way using bi-polar ADC
    (preferably 16-bit) and Microcontroller.
2. As I am not finding my requisite in the Arduino Family, I have decided to hookup ADS7805 (16-bit Bi-
    polar ADC of Advanced Devices)with ArduinoMEGA.
3. I am afraid that my data item (after additions of the squares of the samples) might be greater than
    32-bit, which is not supported by ArduinoMEGA.
4. Is there any member of Arduino Family, which supports 40-bit or 56-bit or 64-bit data size?
KeithRB
Unfortunately, there is no listing of limits.h for every arduino. But the Due uses 32 bit ints. I am assuming the longs will be 64.
JohnRob
I'm going to guess it might not meet your basic goal (I'm thinking this is an exercise in "can I do this"),
but if not there are some RMS to DC converter IC's you could use.
JR
GolamMostafa
JR
My ultimate target is to measure the RMS value of a distorted wave shape (produces by non-linear semiconductor loads), and then use it for the calculation of effective power factor of the load. As far as I know, the stand alone ICs (RMS to DC) are designed to see pure sine wave (or close to it) for the production of proportional output. There are some mathematical calculations which can be carried out by ArduinoUNO/MEGA/DUE.
Thanks for the feedback.
GolamMostafa
Google knows a lot more than you:
http://www.analog.com/media/en/technical-documentation/data-sheets/AD636.pdf
Yes! Google has response to my inquiry; but, I am too late to submit the question; instead I made a guess which could not spit even a bit of dirt on the dignity of AD636 and others; but, on me. Now, I know that these ICs can very correctly produce proportion DC in response to the excitation of 'complex wave' (ac wave of any shape).
KeithRB
Not any shape. You are supposed to say that your waveforms will have a crest factor of more than 6. 8^)
It is much funner with the arduino anyway. Next you are going to be asking for an integer square root algorithm!
GolamMostafa
#12
Mar 23, 2017, 04:42 am Last Edit: Mar 23, 2017, 05:35 am by GolamMostafa
1. (a) Yes! Peak could be as large as 6*200 mV = 1200 mV. But, the region to the left and right
          of the peak bounded by the cycle zero-crossings can take up any shape. This is an
          example of a complex wave shape.
    (b)  When signals of different frequencies are added (Vm1 sin(xwt+y1) +
           Vm3sin(3wt+y3)+Vm5sin(5wt+y5)), we come up with a complex wave.
     (c)  So, what is incorrect in saying 'any wave shape?'. The data sheet of AD636 has put
           restriction on the peak by specifying the crest factor in order to prevent the input
           electronics from being over-stressed (perhaps damaged); but, it has not said anything
           about the form factor which is a quantitative measure of the irregular geometrical shape
           of a signal.
2.   Yes! Your guess is correct. I have been looking for an ATmega32 (ASM based and not C)
      algorithm (preferably Babylonian) for computing square-root of a number range : 000000 -
      065535 (decimal). The Arduino IDE has the function sqrt(); I should straight use it. Why
      am I looking for the ASM version? As you have said - 'Can it be done?'
3.   AD636 data sheet says:
      Crest factor = up to 6 can be accommodated with less than 0.5% additional error (Page-1).
      How is it 'more than 6.8' in your post#11?
KeithRB
That was 6(period)(space)(8 for smiley)
The crest factor has all to do with accuracy, not protecting the hardware.
You, of course have the same issue. You will need to sample at  more than twice the highest harmonic you want to capture.
GolamMostafa
many thanks for cordial conversation.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
