Topic: "switch quantity not an integer"? (Read 9698 times) previous topic - next topic
flickerfly
In comparing the documentation at http://arduino.cc/en/Reference/SwitchCase, it doesn't say anything about the case statement requiring an integer. I tried using a float and it complained that it wasn't an integer. Can I not use a float? (If so, could a mention be made on the reference page for others to clarify that. :-)
Also, can an operator be used in a case? For example
switch (time) {
 case >300:
   do something;
 case >200:
   do something else;
 default:
kg4wsv
you can't use a float or an expression in a switch statement.
I'd recommend a set of if/else blocks.
-j
