Topic: Arduino-0016 Bug with external interrupts (Read 1 time) previous topic - next topic
darkirby
When using any external interrupts with the arduino 0016 software for the pro mini 8mhz you get an error when you compile.
mellis
Hmm, I didn't have any problems with the sample program I just tried.  Can you post your code and the error you get?  Which boards give you the error and which don't?
darkirby
#2
Jun 08, 2009, 07:54 am Last Edit: Jun 08, 2009, 07:59 am by darkirby Reason: 1
mellis,
Thanks for the quick reply.  The code I am having trouble with is a three tab file.  This code does fully compile with zero errors in the Arduino-0015 environment for an Arduino Pro or Pro Mini (3.3V, *MHz) w/ ATMega168.  Hopefully this will help.
Tab 1 Code:
Quote
//Variable Initialization, Setup, and Main loop
//Magnetometer and Period Variables
volatile int time=0;
volatile int period=0;
volatile int new_period=0;
volatile int last_period=0;
volatile byte count=0;
volatile int first_half=0;
volatile int second_half=0;
//Timer 2 ISR variables
int mode=1;
int isr_count=0;
 pinMode(3,INPUT);   //mag data
 pinMode(4,OUTPUT);  //mag reset
 pinMode(8,OUTPUT);  //flap
 pinMode(9,OUTPUT);  //throttle
 pinMode(13,OUTPUT); //led
 degauss();
 degauss();
 Serial.begin(19200);
 TCCR2A=0x02;
 TCCR2B=0x07;
 TCNT2=0x00;
 OCR2A=0x9C;
 GTCCR=0x02;
 TIMSK2=0x02;
 attachInterrupt(1,getRPM,RISING);
 if (count==30)
   count=0;
   Serial.println(period);
   degauss();
Tab 2 Code:
Quote
//replaces get_RPM function
/*boolean blink=false;
void getRPM()
 if (millis()>80)
 blink=!blink;
 if (blink) PORTB |= 1<<PB5;
 else PORTB &= ~(1<<PB5);
//set mode of timer2 isr in order to sync up flapping
void getRPM()
 time=millis();
 if (time>80)
   mode=4;
   count++;
   new_period=time;
   last_period=period;
   period=((period<<2)-period+new_period)>>2;
   first_half=period>>1;
   second_half=period-first_half;
   timer_reset();
void degauss()
     //assumes that the magreset pin is connected to 4
     PORTD|=1<<PD4;
     delayMicroseconds(2);
     PORTD&=~(1<<PD4);
extern volatile unsigned long timer0_clock_cycles;
extern volatile unsigned long timer0_millis;
void timer_reset()
     unsigned char oldSREG=SREG;
     cli();
     timer0_clock_cycles=0;
     timer0_millis=0;
     SREG=oldSREG;
//original getrpm
/*void getRPM()
     time=millis();
     if (time>80)
           if (time>300) time=300;
               count++;
           new_period=time;
           last_period=period;
           timer_reset();
Tab 3 Code:
Quote
//ISR routine for translation
ISR(TIMER2_COMPA_vect)
 switch(mode)
   case 1: //wait for half period
       isr_count++;
       if (isr_count==first_half)
         mode=2;
         TCCR2B=0x04;
         OCR2A=125;
         GTCCR=0x02;
   case 2: //turn led off
       PORTB &= ~(1<<PB5);
       TCCR2B=0x04;
       OCR2A=125;
       GTCCR=0x02;
       mode=3;
       isr_count=0;
   case 3: //
       isr_count++;
       if (isr_count==second_half)
         mode=4;
         TCCR2B=0x04;
         OCR2A=125;
         GTCCR=0x02;
   case 4: //turn led on
       PORTB |= 1<<PB5;
       TCCR2B=0x04;
       OCR2A=125;
       GTCCR=0x02;
       mode=1;
       isr_count=0;
   default:
That is the end of the code and this is the list of errors that I am getting.
o: In function `timer_reset':
C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build39811.tmp/Temporary_1953_2035.cpp:111: undefined reference to `timer0_clock_cycles'
Couldn't determine program size: C:\Documents and Settings\Administrator\Desktop\IARC\software and drivers\arduino-0016\arduino-0016\hardware/tools/avr/bin/avr-size: 'C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build39811.tmp\Translation_Debugging.hex': No such file
mellis
timer0_clock_cycles is (was) an internal / unsupported variable.  You'll have to take a look inside the wiring.c to find a equivalent technique for Arduino 0016.
