Loading...
Pages: [1]   Go Down
Author Topic: autoformat bug with syntactical error in for loop  (Read 439 times)
Seattle, USA
Offline Offline
Full Member
View Profile
WWW
I am getting an error using the Auto Format command when there is a syntactical error in a for loop specifier. (MacOS 10.5.7, Arduino 0016)
When the for statement has commas for separators instead of semi-colons, the IDE thinks for a very long time when asked to Auto Format the sketch, and then yields the message:
Exception in thread "AWT-EventQueue-0" java.lang.OutOfMemoryError: Java heap space
The compiler will correctly diagnose the error, however.
Here is a very simple sketch that demonstrates the error:
Code:
int i;
void setup () {
void loop () {
  for (i = 0, i < 10, i++)
Thanks.
.andy
Logged
Norway@Oslo
Offline Offline
Edison Member
loveArduino(true);
View Profile
WWW
Commas as separator in a for loop structure, is a compile error.
Actually, the only time I can think of, that the comma is a separator, not an operator, is in arguments lists.
Why not use semicolons?
« Last Edit: June 04, 2009, 05:58:55 pm by AlphaBeta » Logged
Seattle, USA
Offline Offline
Full Member
View Profile
WWW
I know that it's not the right syntax; it was just a typo on my part when entering the code in the sketch. And the compiler did catch it.
But the auto-formatter did NOT catch it, or at least did not recover gracefully from parsing the erroneous syntax, and crashed.
So I'm just reporting this as an auto-formatter bug...
Logged
Canada
Offline Offline
Full Member
Code Monkey
View Profile
WWW
Yup, it is falling off the end of the world trying to make sense of that bad code.  The parsing stuff looks ok, but it might be the display code wanting to display things over and over.
Logged
I yield() for co-routines.
0
Offline Offline
Sr. Member
dinosaur cork
View Profile
WWW
The autoformat function is still pretty buggy and is best avoided until after you have made sure that the program compiles.
It used to have a charming "auto-delete" bug where code was deleted if brackets weren't balanced (which balanced the code) but that one has been fixed for a while. There are still many bugs and quirks in it though so compile first - and you'll be happier.
Logged
Pages: [1]   Go Up
Print
Jump to:
