Topic: CP/M computer on Arduino Nano 3.0 (Read 12422 times) previous topic - next topic
FoxyLab
Mar 21, 2017, 04:51 pm Last Edit: Mar 21, 2017, 04:58 pm by FoxyLab
Greetings to all lovers of Arduino and old school computing! Nostalgia for the eight-bit computers of my youth led me to this project :-) - CP/M 2.2 computer from ... what would you think? ... Arduino Nano 3.0!
For weeks two or three I made the i8080 processor emulator for Arduino Nano (it passes the test from MICROCOSM) and adapted the CP / M.
The main problem - Arduino has only 2 (!) KB of RAM. But we also have an SD card - I made a 4-line cache (32 bytes) to this card, and the card itself emulated all 64 KB of RAM. Although I applied the most primitive cache management algorithm, the speed of work is not so bad.
At the same time, this card also emulates four floppy disks.
Here's the quick-and-dirty prototype of my work:
Yes, I did not use the adapter for the card, I inserted it into the connector of the cable from the five-inch drive. :-)
To communicate with a computer, I use a terminal program (in the future I plan a PS/2 keyboard and an LCD screen or connect to a TV).
Here is a screenshot of the memory check:
CP/M Download:
CPU Test:
DIR command:
My first program in BASIC for the past twenty (!)))) years:
(I launched TinyBASIC).
Are you interested in such a project?
GrooveFlotilla
Some people are like Slinkies.
Not really good for anything, but they bring a smile to your face when pushed down the stairs.
Isaac96
That is great!
Another person (i think it was on here) used a Mega1284, which was probably easier relatively speaking. One thing-there is a VGAout library somewhere. You might be able to output to a vga screen and have a command line!
Do not PM me for help. I will delete immediately.
CONNECT THE GROUNDS!
After Tuesday, even the calendar goes W T F
FoxyLab
That is great!
Many thanks! I plan to add PS/2 keyboard and LCD screen (or TV-out - but this required additional microcontroller as VGA-controller).
Isaac96
Awesome. That sounds amazing. Please post when that is complete.
FoxyLab
I uploaded on YouTube realtime video of my project in action:
https://youtu.be/LHFmt3qWAuY
thomai
Simply awesome!!!
But why didn't you use a SPI RAM extension?
petersieg
Where is the source? ;-)
Would like to give it a try..
Very interesting to use a 64kb area on sd card to mimick ram memory.
I assume the 4 floppy images are dd-ed on 4 partitions of the sd card?
Please keep this code as a separate (version 1) project, before you introduce ps/2 kb und display.
thx,
Peter
FoxyLab
#9
Mar 23, 2017, 10:04 pm Last Edit: Mar 23, 2017, 10:22 pm by FoxyLab
Simply awesome!!!
Thanks!
In future probably as an option (Ferroelectric RAM).
FoxyLab
#10
Mar 23, 2017, 10:15 pm Last Edit: Mar 23, 2017, 11:00 pm by FoxyLab
thx,
Peter
1. I will uploaded source in my GitHub repository - I believe, by the beginning of next week.
2. I use 4 GB SDHC Card, so i trade free space for simplifying - i write one line cache at the beginning of each sector (64 bytes of 512 bytes)   (cache has 8 lines of 64 bytes)  ->  65536/64 sectors to all RAM.
3. No, i dont use partitions on SD Card - raw read/write only.
petersieg
Thx. Would be glad if you upload also your sd card image so that one can write it directly with dd on a card.
Peter
FoxyLab
Peter
O.K.
pito
#13
Mar 24, 2017, 05:05 pm Last Edit: Mar 24, 2017, 05:22 pm by pito
I've got stm32duino (stm32F103zet6 board) with 64kB internal and 512kB of external sram (wired via FSMC). The 512kB of sram could be used for the heap. I can allocate the 64kB of CP/M's RAM with malloc() in that 512kB space easily.
So I may try to run your code on it, when available..
FYI:
External sram on stm32duino
FoxyLab
FYI:
Thanks!
But my target was Nano. For fun i plan in future connect Nano to 32+32 KBytes Ferroelectric RAM (FRAM) (~1.2$ on eBay) as option.
