Topic: delay() and delayMicroseconds() issues (Read 42139 times) previous topic - next topic
borref
I worked on code recently that required precise timing of microsecond intervals from an ISR. Issues that surfaced forced me to deep dive into the Arduino timer functions (see also thread on micros) and some caveats to consider.
The wiki on delayMicroseconds() has a good section on caveats/issues, but it may not be obvious at first what these imply. The delayMicroseconds() function will provide accurate delays as may be needed for some types of applications (e.g. SofwareSerial bit banging) by disabling interrupts during its core delay code. Still, interrupts (e.g. timer overflow, serial, others) may execute before the delayMicroseconds function returns and thus upset precise timing. As a consequence, time critical code will need to guard itself against interrupts even though delayMicroseconds is used. As such, the function does not provide a proper solution to time critical code in itself and it also has other negative consequences as in the following:
In LiquidCrystal bundled with the Arduino IDE 0016, the functions "clear()" and "home()" use delayMicroseconds to pause for 2000 microseconds. Since interrupts are disabled for the duration of the delay, this will cause a loss of one timer overflow interrupt (delays in excess of 1024 microseconds) for every call to home and clear. Considering that the LiquidCrystal library as such does not need exact microsecond interval timing, but rather a guaranteed minimum delay, this is an unnecessary cost to pay as it is likely to upset other code.
So why not use delay() then when longer delays are needed (e.g. 2000 microseconds)? The issue here is that delay depends on millis() which in turn depends on the timer0 overflow interrupt. The delay() function may return immediately when called for a 1 millisecond delay because the overflow interrupt may be only 1 microsecond away. So what if we ask for a two millisecond delay then? Every overflow interrupt is actually 1024 microseconds apart and the remainder (24 microseconds) is accounted for by the millis() function such that on occasion it gets incremented twice for a single timer0 overflow interrupt. As a consequence, even a two millisecond delay may return immediately with no delay whatsoever besides the function call overhead.
Further, if we use the Serial library to receive data at 9600 baud, a new character (8 bits + start and stop bit) will arrive roughly every millisecond. Any calls to delayMicroseconds with delays in excess of the per-character time may result in lost characters for data received during the delay. At 57600 baud, the per-character interval is as low as 174 microseconds.
My proposal is that the interrupt guard used within delayMicroseconds should be removed. This will allow use of this function for guaranteed minimum delays without upsetting overflow, serial or other interrupts. Then what about existing code relying on precise delays? Unless this code guards itself against interrupts, it is actually non-the-worse since interrupts get re-enabled by delayMicroseconds prior to return anyway.
Further I suggest that the delay() function is rewritten to properly deal with short delays. As it is implemented now, it may be as much as 20% off even for a 10 millisecond delay.
Coding Badly
Quote
I'd rather delay be left as-is and see a delayAtLeast (guaranteed delay no less than what was specified) and delayExactly (as close as possible without disabling interrupts) be added.
JetC
Quote
Yes, I also think that more specialized functions will be handy and flexible
borref
The timing loop used in delayMicroseconds() is coded as follows:
Code: [Select]
     // disable interrupts, otherwise the timer 0 overflow interrupt that
     // tracks milliseconds will make us delay longer than we want.
     oldSREG = SREG;
     cli();
     // busy wait
     __asm__ __volatile__ (
           "1: sbiw %0,1" "\n\t" // 2 cycles
           "brne 1b" : "=w" (us) : "0" (us) // 2 cycles
     // reenable interrupts.
     SREG = oldSREG;
Comments in the source above suggests that disabling interrupts will suppress timer0 interrupts and allow for exact timing of microsecond delays. This is true for the loop itself, but the architecture of the atmega is such that interrupts are sticky and will be serviced as soon as global interrupts are reenabled. This will be on the first clock cycle after "SREG = oldSREG" gets executed. Consequently, ISR overhead delays will add up irrespective of disabling interrupts, but with the negative side effects as outlined in the first post.
Rather we should replace above code with the following  to avoid the negatives:
Code: [Select]
     // busy wait
The change will not break existing code because delays will be as  today (no change from an application perspective).
The delay() function is unpredictable and incosistent for delays in the low millisecond range (see first post). Th current implementation is as follows:
Code: [Select]
void delay(unsigned long ms)
     unsigned long start = millis();
     while (millis() - start <= ms)
If we fix the delayMicroseconds() function, we could use this to em\liminate the issue with delay() as follows:
Code: [Select]
    if (ms > 20) {
      while (millis() - start <= ms) ;
    } else delayMicroseconds((unsigned int)ms * 1000);
The above would not break existing code as it simply ads consistency for delays in the low millisecond range.
mellis
I've been thinking that we should remove the disabling of interrupts from the delayMicroseconds() function.  This is another good reason for doing so.  Thanks for the thorough explanation.
I don't think we need two separate delay() functions, but it's not a bad idea to improve the implementation to be more accurate for small delays.
I'm adding this to the issues list on Google Code: http://code.google.com/p/arduino/issues/list
