Topic: String library problem (Read 944 times) previous topic - next topic
OrangeRiver
I can't get the String library to work, even declaring an instance of Sting class, like this:
#include <String.h>
String str = String(10);
Throws this compiler error:
error: 'string' does not name a type
I've tried compiling the examples that come with the library, and (after fixing the include from WString.h to String.h), they have the same problem.
Any ideas?
Kitep
#1
Dec 27, 2009, 06:07 pm Last Edit: Dec 27, 2009, 06:07 pm by Kitep Reason: 1
If you switch it back, it compiles no problem.
Even though the library is called "String", the actually file names are called "WString".
Good luck!
