Loading...
Pages: [1]   Go Down
Author Topic: Easy ethernet lookup macro's  (Read 199 times)
Netherlands
Offline Offline
Jr. Member
View Profile
WWW
For maintainability and easier usage of the Ethernet library, I present to you, the hostToIp macro's.
I have added the, what I've called, DnsPreprocessor.
Just before compiling the DnsPreprocessor handles two macro's
- hostToIpString, and
- hostToIpBytes.
The DnsPreprocessor looks up the ip address of the given host and returns either a string, or a byte[].
An example:
Code:
char google[] =  hostToIpString("www.google.com");
byte googleB[] = hostToIpBytes("www.google.com");
  Serial.print("String: ");
  Serial.println(google);
  Client client(googleB, 80);
To use this, you'll have to download the Arduino IDE source.
Add the DnsPreprocessor to app/src/processing/app/preproc
Modify Sketch.java as described below.
And compile the Arduino IDE.
In Sketch.java in preprocess(String buildPath, PdePreprocessor preprocessor) change this
Code:
   StringBuffer bigCode = new StringBuffer();
    int bigCount = 0;
    for (SketchCode sc : code) {
      if (sc.isExtension("pde")) {
        sc.setPreprocOffset(bigCount);
        bigCode.append(sc.getProgram());
        bigCode.append('\n');
        bigCount += sc.getLineCount();
//        if (sc != code[0]) {
//          sc.setPreprocName(null);  // don't compile me
    String program = code[0].getProgram();
    StringBuffer bigCode = new StringBuffer(program);
    int bigCount = code[0].getLineCount();
To this
Code:
    int bigCount = 0;
[glow]      try {
          bigCode = new DnsPreprocessor().process(bigCode.toString());
      } catch(java.net.UnknownHostException uhe) {
            uhe.printStackTrace();
            String msg = "Failed to lookup hostname";
            throw new RunnerException(msg);
      }[/glow]
Just for clarity; the ip address are looked up at compile time. So the ip address and not the hostname is what ends up in the compiled sketch.
Any suggestions are more than welcome.
Logged
Pages: [1]   Go Up
Print
Jump to:
