Loading...
Pages: [1]   Go Down
Author Topic: How to read an array of bytes through Serial.read(  (Read 4634 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
   I am new to arduino.I am trying to communicate two arduino modules using Xbee modules. From one arduino am sending an array of 9 bytes, wih syntax:
Serial.write(RFout,9);  //RFout is an array with 9 bytes
On the other hand, the other arduino trying to recieve this information by using the below syntax:
int availableBytes = Serial.available();
delay(2000);
if (Serial.available() > 0) {
   for(int n=0; n<availableBytes; n++);
    RFin_bytes[n] = Serial.read();
But, it seems to be not working.Could you people help me out in solving this problem.
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Doesn't available() just return the number of bytes available now, which might only be 1.  You need an outer loop to keep trying to read till all the 9 bytes have been acquired?  Something like:
Code:
 int bytes_read = 0 ;
  while (bytes_read < 9)
        ...... read a byte and store it ....
        bytes_read ++;
Or you could wait for available() to return at least 9 before reading all 9 - the hardware buffer is 128 bytes.
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
I've just noticed your code is buggy anyway as you assume the two calls to available() return the same value, which is not guaranteed.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Sorry, i didn't understand the second reply. So could you please help me in storing the 9 bytes of incoming string.
Logged
UK
Offline Offline
Faraday Member
Gorm deficient
View Profile
Code:
delay(2000);
Two seconds is a very long time to wait.
If your serial line is running constantly at 9600 baud, the serial receiver buffer would overflow in less than a fifth of a second.
Logged
Per Arduino ad Astra
Weinsberg, Germany
Offline Offline
God Member
A Coder's Tale
View Profile
WWW
Why make it so complicated?
How about:
Code:
while (Serial.available()<9) {} // Wait 'till there are 9 Bytes waiting
for(int n=0; n<9; n++)
   RFin_bytes[n] = Serial.read(); // Then: Get them.
« Last Edit: March 16, 2010, 10:39:55 am by Joghurt » Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
One thing always to keep in mind when writing this kind of code is to be able to handle things when something goes wrong -- like what if you never get the 9 bytes you are expecting? I doubt you would want your code to lock up.
I'd probably do something like this:
Code:
#define MAX_MILLIS_TO_WAIT 1000  //or whatever
unsigned long starttime;
starttime = millis();
while ( (Serial.available()<9) && ((millis() - starttime) < MAX_MILLIS_TO_WAIT) )
      // hang in this loop until we either get 9 bytes of data or 1 second
      // has gone by
if(Serial.available() < 9)
            // the data didn't come in - handle that problem here
      Serial.println("ERROR - Didn't get 9 bytes of data!");
Logged
Weinsberg, Germany
Offline Offline
God Member
A Coder's Tale
View Profile
WWW
Don't forget to flush the buffer on error. smiley-wink
« Last Edit: March 17, 2010, 03:14:20 am by Joghurt » Logged
Pages: [1]   Go Up
Print
Jump to:
