Topic: Source build from SVN is broken (Read 836 times) previous topic - next topic
doctorwho8
Hello!
I just tried building the Arduino code from SVN and there were a lot of complaints. This is on Cygwin-1.7 on Windows Seven:
GCL@CmdrSkywalker /usr/local/src/arduino/build/windows
$ ./make.sh
Building processing.core...
updating PApplet with PGraphics api changes
Building the PDE...
src\processing\app\syntax\JEditTextArea.java:27: package processing.app.syntax.i
m does not exist
import processing.app.syntax.im.InputMethodSupport;
src\processing\app\syntax\JEditTextArea.java:136: cannot find symbol
symbol  : class InputMethodSupport
 private InputMethodSupport inputMethodSupport = null;
src\processing\app\syntax\TextAreaPainter.java:15: package processing.app.syntax
.im does not exist
import processing.app.syntax.im.CompositionTextPainter;
src\processing\app\syntax\TextAreaPainter.java:38: cannot find symbol
symbol  : class CompositionTextPainter
 protected CompositionTextPainter compositionTextPainter;
src\processing\app\syntax\TextAreaPainter.java:83: cannot find symbol
  public CompositionTextPainter getCompositionTextpainter(){
src\processing\app\syntax\JEditTextArea.java:139: cannot find symbol
                       inputMethodSupport = new InputMethodSupport(this);
src\processing\app\syntax\TextAreaPainter.java:85: cannot find symbol
      compositionTextPainter = new CompositionTextPainter(textArea);
Note: Some input files use unchecked or unsafe operations.
Note: Recompile with -Xlint:unchecked for details.
7 errors
zip error: Nothing to do! (try: zip -rq ../lib/pde.jar . -i .)
Done.
This also happened with the exact same problem on Slackware Linux-12.1.
/me
wayoda
The build system for the latest version (trunk) is now using ant instead of make.
http://code.google.com/p/arduino/wiki/BuildingArduino
Eberhard
doctorwho8
Hello!
But the site does not explain what to do to get a recent JDK installed. And then recognized by Cygwin so that the Ant tool can find the JDK and take it from there.
By contrast everything just works under Linux and then instructions for Linux are indeed complete. But that solution is reserved for a long-time project.
/me
wayoda
Download from http://java.sun.com/javase/downloads/index.jsp
Edit the PATH settings?
http://ant.apache.org/manual/index.html
Ant has one of the best maintained online-manuals in the world of free software. There is a whole section on installing Ant and running checks to see if it works.
Eberhard
