Topic: IDE on the EEE PC (800x480 lcd display) (Read 4736 times) previous topic - next topic
sekar
Hello,
i would just like to suggest that you lower the minimum size of the editor canvas, because i cant even see the lower part of the scrollbar.
Just try to resize the window to a height less than about 500px to see the problem.
Thank you,
Slavko
andrew0
Yeah, it is a bit broken on the Asus isn't it? I was wondering if a separate window for the serial monitor area might help. Maybe a dockable window so you can have it all in one as at present or tear it off and alt-tab between them.
Andrew
VenPixel
Andrew
Should be pretty easy to make the serial monitor panel show above the editor panel if the window size is less than 500px. I will try to take a look at it (since I do most of my editing on my EEE) and see if I can provide a patch to fix it.
andrew0
I don't use anything but the Eee PC with my Arduino - I think they make a perfect pair. Who'd have thought you could play with programmable microcontrollers while sitting on your sofa?
Andrew
VenPixel
Andrew
My feelings exactly.
jds
Oh, but I don't need an EEE PC to work with Arduino while sitting on my sofa. A 'normal' laptop works fine, is my experience!
andrew0
Depends how big your sofa is and if there's someone sitting next to you watching TV.
Andrew
jds
lol, I have a big sofa... but also 2 people watching tv...
Ok, back to topic please  :D
wayoda
I have made a few changes to the Arduino-IDE sources for version 0010 that allows for smaller windows suitable for the e3pc.
- The Splitpane that divides the editor-panel from message can now be resized,   so that both panels are fully visible (with scrollbars if necessary).
- I removed the statusbar that displays the current linenumber.
- I switched the look-and-feel of the IDE from "GTK" to "Metal"
- I switched to Java Swing Fileselection Dialogs because they are easier
 to navigate on a small screen.
It's now possible to work with the IDE in e3PC-EasyMode and still have the MenuBar
at the bottom of the screen.
The install instructions are here : http://www.wayoda.org/share/eeepc/README-EEEPC
The updated IDE-code is here (1.1MB) : http://www.wayoda.org/share/eeepc/pde.jar.eee
I really hope we can get some of these changes into the standard Arduino-Distribution so it needs to be only a temporary hack.
Eberhard
andrew0
Eberhard
Great! Can't wait to get home and try this out!
Andrew
wayoda
Hi
I have made a few changes to the Arduino-IDE sources for version 0010...
Just uploaded a zip-file with the patched java source  files : http://www.wayoda.org/share/eeepc/pde-jar-eee-src.zip
The beginning of regions where I applied my changes are marked with a comment:
//EEEPC-Hack : Comment whats been done
Eberhard
andrew0
Just tried this and it's a fantastic improvement. Thanks very much. Now I need to find out how to get rid of the window title bar when maximized to use all of the screen. I presume changing window managers might let me do it.
Andrew
wayoda
Hi Andrew,
Andrew
Excellent idea and ... done
I added an option to the jar, which run the IDE fullscreen without the titlebar.
The updated README for this : http://www.wayoda.org/share/eeepc/README-EEEPC
The updated pde.jar : http://www.wayoda.org/share/eeepc/pde.jar.eee
The sources for the changes :http://www.wayoda.org/share/eeepc/pde-jar-eee-src.zip
Eberhard
andrew0
Hi Andrew,
Andrew
Eberhard
Now you're just teasing me! /me waits impatiently for 17:30...
Andrew
