Topic: Arduino timer scheduler library (Read 14010 times) previous topic - next topic
mem
#15
Aug 06, 2008, 10:23 pm Last Edit: Aug 06, 2008, 10:24 pm by mem Reason: 1
Regarding re-entrance, as Martin says, the service routine is only entered by foreground code calling another alarm library function  (typically it will be the library's delay or wait function). It is blocked from processing if its called from an alarm handler. There is flag in the service routine that ensures that a new alarm will never be triggered while processing an existing alarm. This minimizes stack usage and reduces the  likelihood that shared global variables in the users foreground sketch will be abused.
The comments are stimulating my thinking around  a very simple API along the lines mellis suggested with the option to create additional and more sophisticated alarm instances for those that need them. This gives basic scheduling that is highly intuitive out of the box but the richer functionality can be added by people that understand how to instantiate a class.  I don't think it adds any complexity to code I have (although it will be more complex than the code posted above)  but I do want to see if it adds much in the way of resource consumption.
mem
#16
Oct 02, 2008, 11:31 am Last Edit: Oct 02, 2008, 11:32 am by mem Reason: 1
Here is slightly modified version of the DateTimeAlarm code that compiles in Arduino version 0012:
Code: [Select]
 DateTimeAlarms.h - Arduino Date and Time alrms library
 This library is distributed in the hope that it will be useful,
 but WITHOUT ANY WARRANTY; without even the implied warranty of
 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
#ifndef DateTimeAlarms_h
#define DateTimeAlarms_h
#include <inttypes.h>
//#include <wiring.h> // moved into cpp file for Arduino ver 0012
#include "dateTime.h"
typedef enum {
    dtMillisecond, dtSecond, dtMinute, dtHour, dtDay //,clkMonth,clkYear
} dtUnits_t;
typedef struct  {
     uint8_t isEnabled              :1 ;
     uint8_t isOneShot              :1 ;
     uint8_t isAlarm                :1 ;
    AlarmMode_t   ;
typedef uint8_t AlarmID_t;
#define dtINVALID_ALARM_ID 255
#define dtNBR_ALARMS 6
class AlarmClass;  // forward reference
typedef void (*OnTick_t)(uint8_t);  // alarm callback function typedef
// class defining an alarm instance, only used by dtAlarmsClass
class AlarmClass
private:
public:
     AlarmClass();
     OnTick_t onTickHandler;
     void updateNextTrigger();
     time_t value;
     time_t nextTrigger;
     AlarmID_t ID;           // unique instance id (only used for debugging
     AlarmMode_t Mode;
// class containing the collection of alarms
class dtAlarmsClass
  friend class TimerClass;
private:
  AlarmClass Alarm[dtNBR_ALARMS];
  void serviceAlarms();
  boolean isServicing;
  AlarmID_t nextID;
  AlarmID_t create( time_t value, OnTick_t onTickHandler,boolean isAlarm, boolean isEnabled );
public:
     dtAlarmsClass();
     void delay(unsigned long ms);
     uint8_t getDigitsNow( dtUnits_t Units);  // returns the current digit value for the given time unit
     void waitForDigits( uint8_t Digits, dtUnits_t Units);
     void waitForRollover(dtUnits_t Units);
     // functions for specific alarms identifed by alarm ID
     AlarmID_t createAlarm( time_t value, OnTick_t onTickHandler, boolean isEnabled = true );
   AlarmID_t createTimer( time_t value, OnTick_t onTickHandler, boolean isEnabled = true );
     void setValue(AlarmID_t ID, time_t value);
     void enable(AlarmID_t ID);
     void disable(AlarmID_t ID);
extern dtAlarmsClass dtAlarms;  // make an instance for the user
* MACROS
/* public */
#define waitUntilThisSecond(_val_) waitForDigits( _val_, dtSecond)
#define waitUntilThisMinute(_val_) waitForDigits( _val_, dtMinute)
#define waitUntilThisHour(_val_)   waitForDigits( _val_, dtHour)
#define waitUntilThisDay(_val_)    waitForDigits( _val_, dtDay)
#define waitMinuteRollover() waitForRollover(dtSecond)
#define waitHourRollover()   waitForRollover(dtMinute)
#define waitDayRollover()    waitForRollover(dtHour)
#define AlarmHMS(_hr_, _min_, _sec_) (_hr_ * SECS_PER_HOUR + _min_ * SECS_PER_MIN + _sec_)
#endif /* Clock_h */
mem
here is the DateTimeAlarms.cpp file moded for 0012
Code: [Select]
DateTimeAlarms.cpp - cooperative scheduler for arduino
extern "C" {
#include <string.h> // for memset
#include <wiring.h> // moved from header to here for Arduino 0012
#include "DateTimeAlarms.h"
#include "DateTime.h"
//* Alarm Class Constructor
AlarmClass::AlarmClass()
 Mode.isAlarm =  Mode.isEnabled = Mode.isOneShot = 0;
 value = nextTrigger = 0;
 onTickHandler = NULL;  // prevent a callback until this pointer is explicitly set
//* Private Methods
void AlarmClass::updateNextTrigger()
 if( (value != 0) && (Mode.isEnabled != 0) )
   time_t time = DateTime.now();
   if(Mode.isAlarm && nextTrigger <= time )   // update alarm if next trigger is not yet in the future
     if( value >= time ) { // is the value a specific data and time in the future
       nextTrigger = value;  // yes, trigger on this value
     else if ( value <= SECS_PER_DAY) {
       if( value + previousMidnight(DateTime.now()) < time)
         nextTrigger = value + nextMidnight(time); // if time has passed then set for tomorrow
         nextTrigger = value + previousMidnight(time);  // set the date to today and add the time given in value
     else if ( value <= SECS_PER_WEEK) {
     else {
       Mode.isEnabled = 0; // values more than a year but less than today have expired so the alarm is disabled
   if(Mode.isAlarm == false){
     // its a timer
     nextTrigger = time + value;  // add the value to previous time (this ensures delay always at least Value seconds)
 else {
   Mode.isEnabled = 0;  // Disable if the value is 0
//* Date Time Alarms Public Methods
dtAlarmsClass::dtAlarmsClass()
 nextID = 0;
 isServicing = false;
AlarmID_t dtAlarmsClass::createAlarm(time_t value, OnTick_t onTickHandler, boolean isEnabled ){  // returns true if has been registerd ok
 return create( value, onTickHandler, true, isEnabled );
AlarmID_t dtAlarmsClass::createTimer( time_t value, OnTick_t onTickHandler, boolean isEnabled ){  // returns true if has been registerd ok
 return create( value, onTickHandler, false, isEnabled );
void dtAlarmsClass::enable(AlarmID_t ID)
 if(ID < dtNBR_ALARMS){
   Alarm[ID].Mode.isEnabled = (Alarm[ID].value != 0) && (Alarm[ID].onTickHandler != 0) ;  // only enable if value is non zero and a tick handler has been set
   Alarm[ID].updateNextTrigger(); // trigger is updated whenever  this is called, even if already enabled
void dtAlarmsClass::disable(AlarmID_t ID)
   Alarm[ID].Mode.isEnabled = false;
void dtAlarmsClass::setValue(AlarmID_t ID, time_t value){
   Alarm[ID].value = value;
   enable(ID);
// following functions are not Alarm ID specific.
void dtAlarmsClass::delay(unsigned long ms)
 unsigned long endtime = millis() + ms;
 boolean Overflow = endtime < millis();
 if( Overflow){
   while( millis() > endtime)
     serviceAlarms();
 while( millis() < endtime)
   serviceAlarms();
void dtAlarmsClass::waitForDigits( uint8_t Digits, dtUnits_t Units)
 while(Digits != getDigitsNow(Units) )
   serviceAlarms();
void dtAlarmsClass::waitForRollover( dtUnits_t Units)
 while(getDigitsNow(Units) == 0  ) // if its just rolled over than wait for another rollover
   serviceAlarms();
 waitForDigits(0, Units);
uint8_t dtAlarmsClass::getDigitsNow( dtUnits_t Units)
 if(Units == dtSecond) return numberOfSeconds(time);
 if(Units == dtMinute) return numberOfMinutes(time);
 if(Units == dtHour) return numberOfHours(time);
 if(Units == dtDay) return dayOfWeek(time);
 return 255;  // This should never happen
//* Private Methods
void dtAlarmsClass::serviceAlarms()
 if(! isServicing)
   isServicing = true;
   for(uint8_t i = 0; i < dtNBR_ALARMS; i++)
     if( Alarm[i].Mode.isEnabled && (DateTime.now() >= Alarm[i].nextTrigger)  )
       OnTick_t TickHandler = Alarm[i].onTickHandler;
       Alarm[i].updateNextTrigger();
       if( TickHandler != NULL) {
         (*TickHandler)(i);     // call the handler
AlarmID_t dtAlarmsClass::create( time_t value, OnTick_t onTickHandler,boolean isAlarm, boolean isEnabled ){  // returns true if has been registerd ok
 AlarmID_t id = dtINVALID_ALARM_ID;
 if( nextID < dtNBR_ALARMS){
     id = nextID;
   Alarm[id].onTickHandler = onTickHandler;
   Alarm[id].Mode.isAlarm = isAlarm;
     Alarm[id].value = value;
     isEnabled ?  enable(id) : disable(id);
   nextID++;
 return id;
// make one instance for the user to use
dtAlarmsClass dtAlarms = dtAlarmsClass() ;
bmaciel
I'm trying to use DateTimeAlarms in Arduino 0012.
I need to have a periodic alarm with period PERIOD, but that feature seems to have disappeared... I managed to do it by doing, at the end of the callback function,
Code: [Select]
 dtAlarms.setValue(alarmID, DateTime.now() + PERIOD);
Is there any other option?
Moreover, I have a question: is dtAlarms.delay() blocking? If I understand well, I need to include it in the loop() so that alarms get serviced. Because I need sparse alarms (daily or so), this an important thing...
Best regards
mem
#19
Dec 24, 2008, 02:21 am Last Edit: Dec 24, 2008, 02:22 am by mem Reason: 1
If you use the createTimer method instead if createAlarm, the argument to setValue will be the number of seconds from the time now. I think that is what you want.
[font=Courier New]Timer1 = dtAlarms.createTimer( PERIOD, &OnTimer); // call OnTimer function every PERIOD seconds
//the following is optional if the period needs to be changed on the fly:
dtAlarms.setValue(Timer1, NEW_PERIOD); // change the period for Timer1 [/font]
dtAlarms.delay() is blocking to the foreground sketch code, it works like delay() - with the difference that while waiting in dtAlarms.delay(), the scheduler is checking and servicing the alarms and timers, so the alarm code will be run even though the foreground sketch is blocked.
techyjt
Guys,
I now I am coming in late on this one, but I am trying to compile the TimerAlarms stuff under 016 and am getting the following errors:
In file included from C:\Arduino\arduino-0016\hardware\cores\arduino/WProgram.h:4,
c:/arduino/arduino-0016/hardware/tools/avr/lib/gcc/../../avr/include/stdlib.h:111: error: expected unqualified-id before 'int'
c:/arduino/arduino-0016/hardware/tools/avr/lib/gcc/../../avr/include/stdlib.h:111: error: expected `)' before 'int'
In file included from C:\Arduino\arduino-0016\hardware\cores\arduino/WProgram.h:6,
I am trying to track this down, but wanted to drop a quick note.
Thanks,
TBAr
@techyjt, Check for any code at the beginning of your sketch, like lines you think are comments but aren't really comments.
The problem sounds like a problem with a line just in front of the #INCLUDE for the WProgram.h header file, which the IDE generates.
techyjt
This is what is in my sketch:
// DateTime.pde
// example sketch for the DateTime library
#include <DateTime.h>
#include <DateTimeStrings.h>
#include "EEMWRITE.h"
#include <EEPROM.h>
#include <TimerAlarms.h>
#define TIME_MSG_LEN  11   // time sync to PC is HEADER followed by unix time_t as ten ascii digits
//#define TIME_HEADER  255   // Header tag for serial time sync message
#define TIME_HEADER  0x03   // Header tag for serial time sync message
//#define TIME_HEADER  0x00// Header tag for serial time sync message
#define SAVE_TIME 5  //time in minutes to save clock data
#define EEPROM_OFFSET 125  //offset to save data to in EEPROM
struct config_t
   long timeVal;
   int contrastVal;
} configuration;
int firstTimeFlag = 0;
void setup(){
If I comment out #include <TimerAlarms.h> it compiles fine.  If I uncomment I get the errors.  I will keep checking.
mem
use the code in  posts #16 and 17. Note that this library is now called DateTimeAlarms so save the files using that base name and delete the old TimerAlarms directory.
techyjt
Thanks, that did the trick.  Sorry about that.
Luis Manson
the example on first page is not workign anymore with the updated .12 code ?
mem
The libray has been superseded by a newer version that is available as part of the download here: http://www.arduino.cc/playground/Code/Time
Luis Manson
thanks mem, i saw the link but i cant find a way to set alarms like with the code here, am i missing something?
mem
The new library has a simpler method for setting the alarms. Did you have a look at the example sketch supplied with the new library and the documentation to see how this is done.
Luis Manson
oh, i saw the page, not the file... thanks!!! :D
very easy, congratulations :)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
