Topic: Enhanced LiquidCrystal (Read 35810 times) previous topic - next topic
jrraines
#105
Jun 09, 2010, 11:45 pm Last Edit: Jun 10, 2010, 01:59 am by jrraines Reason: 1
I realized a day or two ago that the advice I gave Mowcius is needlessly complex. The 40x4 display can be thought of as two 40x2 displays each with its own hd44780 controller chip and with all the pins in common except the enable line.
Here is some completely untested code to illustrate the concept:
Code: [Select]
#include <LiquidCrystal.h>
LiquidCrystal lcdwhole(rs,rw,enable1,enable2,d0,d1,d2,d3);  //this refers to the whole 40 x4
void setup (void){
lcdwhole.begin(40,4); //initialize the whole LCD
LiquidCrystal lcdBottomHalf(rs,rw,enable2,d0,d1,d2,d3); //define a temporary LCD object that only has 2 lines
lcdBottomHalf.begin(40,2);  //initialize the 2 line object
//now load custom characters into the whole LCD:
     uint8_t bell[8] = {0x4,0xe,0xe,0xe,0x1f,0x0,0x4};
     uint8_t note[8] = {0x2,0x3,0x2,0xe,0x1e,0xc,0x0};
     uint8_t clock[8] = {0x0,0xe,0x15,0x17,0x11,0xe,0x0};
     uint8_t heart[8] = {0x0,0xa,0x1f,0x1f,0xe,0x4,0x0};
     uint8_t duck[8] = {0x0,0xc,0x1d,0xf,0xf,0x6,0x0};
     uint8_t check[8] = {0x0,0x1,0x3,0x16,0x1c,0x8,0x0};
     uint8_t cross[8] = {0x0,0x1b,0xe,0x4,0xe,0x1b,0x0};
     uint8_t retarrow[8] = { 0x1,0x1,0x5,0x9,0x1f,0x8,0x4};
     lcdwhole.createChar(0, bell);
     lcdwhole.createChar(1, note);
     lcdwhole.createChar(2, clock);
     lcdwhole.createChar(3, heart);
     lcdwhole.createChar(4, duck);
     lcdwhole.createChar(5, check);
     lcdwhole.createChar(6, cross);
     lcdwhole.createChar(7, retarrow);
//now redefine custom char 0 for the lower 2 lines:
lcdBottomHalf.createChar(0,retarrow);
}  //end setup(); the temporary LCD object expires.
void loop (void){
     i = 0;
     lcdwhole.clear();
     while (i<4) {
           lcdwhole.setCursor(0,i);
           lcdwhole.print("user:");
           for (int j=0; j<7; j++) {
                 lcdwhole.print(j, BYTE);
           i++;
mowcius
Quote
Yeah. I had not had time to look into it in more detail so you saved me some time :)
I will try that code later if my 40x4 wants to play ball.
Mowcius
jrraines
#107
Aug 14, 2010, 09:55 am Last Edit: Aug 14, 2010, 10:05 am by jrraines Reason: 1
Way back in my first post on this thread, under "Disadvantages" I wrote:
"The possibility that someone with a little 16x2 LCD is using the scrollDisplayLeft() or scrollDisplayRight() instructions to move data across the screen, but wants to write the data 40 characters at a time with a print statement. This version really does not let the user write data to the HD44780 DDRAM which is not visible. To accomplish a scrolling display with 40 characters per line, you would now need to write 16 characters, scroll the display, write a little more and so on."
Yesterday in the course of answering a very interesting question what came to me is that if you declare the little 16x2 LCD to the software as being 40 characters wide then you defeat the linewrap feature and can write to all of the DDRAM on the LCD. see:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1281666158/9#9
jrraines
Thinking about my last 2 posts on this thread, both about ways to trick the software into doing something it really was not designed to do, reminds me of a famous story which all programmers should read and more users should know as well:
http://ifacethoughts.net/2007/12/15/levine-the-best-teacher-for-programmers/
enjoy.
oryan
I'm using Arduino 18. I've successfully written to a 20x4  LCD and am trying to write to a 40x4 Powertip PC4004A. I've used the LiquidCrystal4bit and LiquidCrystal404 libraries (and a simple 'hello world' program) but always end up with the same thing on the screen, that is: all characters on the first and third lines are all blocks, while lines 2 and 4 are blank.
I've read through as many posts as possible but haven't found anything extra to help me.  I'm confident my wiring is sound but wonder if there's a problem with the LCD itself? Has anyone had a similar issue?
Thanks for any input and ideas.
floresta
Quote
This means that your LCD controller is not being initialized properly.  Since the LiquidCrystal and LiquidCrystal440 libraries are correct this means that one or more of the six (or 7 for a 40x4) connections to your Arduino are bad.  You did connect the LCD R/W pin (pin 5) to GND didn't you?
Don
jrraines
when lines 1 and 3 are all blocks you know that the power, ground and contrast pins are OK. the LCD has not initialized, which could be a result of a bad connection/confused specification of pins  on any of the other lines, as Don said.
oryan
I'll recheck all connections, thanks.  It's good to be pointed in the right direction and to know where to look.
magorian
Code: [Select]
// WH4004A Test Program: WinStar 40x4 LCD
// using Enhanced LiquidCrystal440.h
// Since the pinouts are different from Forum example 40x4 LCDs
// Available nkcelectronics.  Data sheet WH4004A-YYH-JT.pdf
// To adjust contract, 10K pot between GND and +5V, wiper W to lcd 12
// LCD Func Arduino Desc pins          Dan Magorian 10/19/2010
// 1    DB7  12      Data bus line
// 2    DB6  11      Data bus line
// 3    DB5  10      Data bus line
// 4    DB4   9      Data bus line
// 5    DB3     Data bus line
// 6    DB2     Data bus line
// 7    DB1     Data bus line
// 8    DB0     Data bus line
// 9    E1   4  Chip enable signal, lcd lines 1 & 3
// 10   RW   3      H: Read(MPU?Module) L: Write(MPU?Module)
// 11   RS   2  H: DATA, L: Instruction code
// 12   V0   W  Contrast, gnd = full
// 13   VSS GND Ground for logic
// 14   VDD +5V Supply Voltage for logic
// 15   E2   5      Chip enable signal, lcd lines 2 & 4
// 16      NC
// 17      LED+      Ext +5V Supply for fluor LED+ optional turn fluor on
// 18      LED-      Ext GND Supply for fluor LED- optional turn fluor on
// If char blocks show black but nothing prints, adjust contrast pot,
// and check lcd pins 13 and 14: display may not be initialized.
// If alternate blocks and blank lines show, check E1 or E2.
#include <LiquidCrystal440.h>
// LiquidCrystal lcd(rs,rw,enable1,enable2,d4,d5,d6,d7);
// Note: some Forum examples using LiquidCrystal440.h have wrong DB pins,
// eg DB0-DB3, or in wrong order.  The top 4 work, in this order.
LiquidCrystal lcd(2, 3, 4, 5, 9, 10, 11, 12);
void setup(){
 lcd.begin (40, 4);
 lcd.clear();
   for (int j=18; j<129; j++) {
     lcd.write(j);
 } // print English chars in rom lower 4 bits, upper 4 bits Japanese
void loop() {}
floresta
Dan:
Are we supposed to evaluate this code?  Does it work or does it have problems?
Quote
I have never used a 40x4 device but I don't think that this is the way things work.  The 40x4 is like two stacked 40x2 devices so one of the enables should deal with lines 1 and 2 and the other should deal with lines 3 and 4.
Don
mowcius
Quote
Most 40x4 HD44780 LCDs...
There is always the exception to the rule so I wouldn't be too sure  ;)
floresta
Quote
Anything is possible, but in this case not at all likely.  This behavior is not a function of the interconnections between the LCD controller and the LCD PC board pins, it is a function of the internal structure of the HD44780 and the relationship between the two HD44780's on the 40x4 board.  I don't think any LCD module manufacturer is going to add the necessary external circuitry to achieve the interlaced action so I stand by my statement.
Don
floresta
#117
Oct 19, 2010, 10:15 pm Last Edit: Oct 19, 2010, 10:30 pm by floresta Reason: 1
Dan:
Some more thoughts:
If you look at the end of the section labeled '8. Contour Drawing & Block Diagram' in the data sheet you referenced you will see that my interpretation of the Enable pin operation is correct.  It is still not clear to me how to interpret 'E1=High' and 'E2=High' on that diagram since the enable pin does it's work on the transition between high and low.  It will be easier to experiment and find out once you get your device functioning than to try and figure out what is meant by this translation.
Quote
When a two line LCD module is powered up but not properly initialized then the top line has blocks and the bottom line is blank.  So this is an indication that neither of the controllers is properly initialized.  This can be caused by a problem with any of the connections between the LCD module and the Arduino, not just E1 or E2.  The usual culprit is the failure to deal with RW properly.
Don
magorian
You guys are, of course, correct (as well as fast), thanks for catching that comment labelling error of mine.  It came from when I wasn't hitting E2 and saw black blocks on the 1st and 3rd lines, and neglected to correct it after I read the datasheet and saw it wasn't interlaced.
Other than that, the sketch works and I put it out there b/c not only are the pinouts different, but there was some confusion about which databus pins work with that 440 lib version, and (after trying them all)  these worked in this order.  I would have put it in the example playground instead of this thread but as a newbie I don't seem to have permissions to do that yet.
Dan
magorian
Here's a version with corrected comments (thanks guys!) for other newbies
fishing around (like I was yesterday) for a working example 40x4 lcd sketch.
Hope it helps someone save some hours.  Dan
Code: [Select]
// Since the pinouts are different from Forum sample 40x4 LCDs
// Available nkcelectronics.com. Data sheet WH4004A-YYH-JT.pdf
// To adjust contrast, 10K pot between GND and +5V, wiper W to lcd 12
// 9    E1   4     Chip enable signal, lcd lines 1 & 2
// 10   RW   3     H: Read L: Write
// 12   V0   W     Contrast, gnd = full, too dark
// 15   E2   5     Chip enable signal, lcd lines 3 & 4
// 16    NC
// If alternate blocks and blank lines show, then neither of the controllers
// is properly initialized, check RW, E1, E2, or any of the connections
void setup(){
 lcd.begin (40, 4);
 lcd.clear();
     lcd.write(j);
void loop() {}
