I've been fighting a problem where my code crashes and usually setup() gets called again and starts over (although a few builds just froze completely). I'm using the Arduino 0021 IDE on a Macbook Pro, targeting an Arduino Duemilanove. I haven't figured out how to debug with the Arduino IDE yet aside from hammer-and-chissel Serial.println()'s. However, the number of calls I have to Serial.println() in my code appear to directly effect this crashing behavior. When this behavior begins, I can make it go away by removing some of the Serial.println()s from the code. Note that I remove ones that wouldn't get called anyway, so they are not the problem themselves (the code is still calling Serial.printXX(), just not the ones that were removed). I'm thinking it could be based on variable space needed for storing the strings, or maybe a bug in Serial.printXX() ? The Arduino IDE shows “Binary sketch size: 16464 bytes (of a 30720 byte maximum)”, so it's not too big. Another behavior seen, when it doesn't crash, is that strings printed by Serial.print() or Serial.println() will get garbled together (appears to be corrupted string data). Could be a bug in Serial.printXX(), or linker's dealing with variable data, or compiler setup/usage of stack space, or ??
Note that I examined closely the code that was crashing and there was nothing recursive going on that could blow the stack (I have no recursive routines in this code), nor could I find any code that could overflow a local or global variable.
I also notice I can also “fix it” by changing global space allocation. I have a 2x2 array of longs, and if I reduce the size of it by a few entries, that can make it go from 100% failure to 100% success.
Feels like it's blowing the stack somehow, but not sure how to really debug this without ability to add printf's or access to an actual debugger.
I have a few questions I'm hoping someone can help me out on:
Q) Are there limits/rules on total stack space usage? Global variable space size/usage? Is there a FAQ on this stuff somewhere I should be looking at?
Q) Is there a debugger for the Arduino IDE / what's the best way to debug a sketch?
Q) I'm confused about the compiler's behavior when I increase the size of a global variable. I would expect the Binary sketch size to INCREASE in size, not DECREASE. Am I not understanding something here, or is this a bug in the compiler/linker?
Before Change:
unsigned long g_right_turn_weights[2][2];
After Increasing Global Variable Array Size by 16 bytes (4 longs):
unsigned long g_right_turn_weights[2][4];
Binary sketch size: 16410 bytes (of a 30720 byte maximum)
Thanks in advance for the helpful pointers/tips.
-- Nick
P.S. I've been programming for over 30 years, but I'm new to the Arduino world (very cool stuff), so please excuse the newbee questions - I'm learning as fast as I can, with your help
