Topic: Ethernetsends a String as one char at the time (Read 3050 times) previous topic - next topic
vesal
I must do
String str = "Hello World";
int n = str.length()+1;
char st[n];
str.toCharArray(st,n);
client.print(st);
instead of
client.print(str)
to send s String in on one TCP/IP packet.
The problem is in Print.cpp:
void Print::print(const String &s)
for (int i = 0; i < s.length(); i++) {
  write(s);
and then every write(char)  is send in Client.cpp
as in one TCP/IP packet.  That sinks the transfrer
rate a lot.
It might be idea to do a write(const String &) in Print and
then implement print(const String &) by calling that.
And then in Client one must override write(const String &)
by writing all chars to same packet.
One problem to implement that is that
void String::toCharArray(char *buf, unsigned int bufsize)
and
void String::getBytes(unsigned char *buf, unsigned int bufsize)
are not const methods as they should be.
bubulindo
well... I guess you're gonna have to read through 5100's manual and create a driver yourself. :\
This... is a hobby.
robtillaart
From Ethernet library - Client.cpp
void Client::write(uint8_t b) {
 if (_sock != MAX_SOCK_NUM)
   send(_sock, &b, 1);
void Client::write(const char *str) {
   send(_sock, (const uint8_t *)str, strlen(str));
void Client::write(const uint8_t *buf, size_t size) {
   send(_sock, buf, size);
Should be easy ... Try replacing Client.print(str) with Client.write(str), Add a '\n' to the string if using println...
Does this help?
Rob Tillaart
