Author Topic: Stepper Library Max speed bug  (Read 1027 times)
Ive recently been testing and driving some new steppers I got with the standard arduino Stepper Library, I am aware that a few bugs have been posted about this perticular Library.
If this bug has already been posted and reported my apologies but I was unable to find it in the forums and its still in the most recent release
During my test with the stepper i used a potentiometer to set the speed of the stepper,
I have a 45v powersupply @ 3A, so I know the voltage isnt the problem
and my Stepper is 1.8deg/step with total 200 steps/revolution
Here's the code I started with:
Stepper stepper(200,5,6,7,8);
void setup()  {
void loop()  {
  del = map(analogRead(0),0,1024,1,500);
  stepper.setSpeed(del)
  stepper.step(1);
This is suppose to map out the 0-1023 value from the analog pin to 0-500 for the rpm of the stepper library
While moving the knob through its full rotation I noticed the stepper reach a certain speed and any further the stepper stop moving and generated a semi high frequency,
I pulled out my osciliscope and noticed as I turned the knob the frequency on 1 of the 4 pins jumped from 245hz to 6000hz
This striked me as odd so i went back to the code and found that this happened when I set the setSpeed() function to 301, anything before 300 would be fine but 301+ generated alarming high frequency,
I looked through the Stepper Library code and found the problem and also came up with a solution
Heres the section of code that has the bug, where the delay is setup for the step function
void Stepper::setSpeed(long whatSpeed)
  this->step_delay = 60L * 1000L / this->number_of_steps / whatSpeed;
void Stepper::step(int steps_to_move)
   if (millis() - this->last_step_time >= this->step_delay)
      this->last_step_time = millis();
in the setSpeed function it calculates the delay needed in milliseconds to achive the deisred switching frequency. It appears that the step_delay variable which is apparently an int-type variable freaks out when I use 301+ rpm @ 200 steps/revolution
heres why:
60 * 1000 / #ofsteps / speed
= 60 * 1000 / 200 / 301
= 60,000 / 200 / 301
= 300/301
=0.9966
due to the int-type variable the 0.996 dosnt work to well, becuase it uses that value and the millis() function to determin the delay
**FIXED**
by using the micros() function instead of the millis() function and multiplying the step_delay by 1000 it maps the 0.996 millisecond delay to 996 microsecond delay, because 1 millisecond = 1000 microseconds
CODE:
  this->step_delay = 60L * 1000L / this->number_of_steps * 1000 / whatSpeed;
   if (micros() - this->last_step_time >= this->step_delay)
      this->last_step_time = micros();
This has been checked with an osciliscope and the 6000hz frequency that was being generated at 301rpm @ 200steps is now around 250hz, where as the 300rpm value that worked with the bug was around 245hz
PROBLEM FIXED!!
enjoy
Arch3r
Seattle, WA USA
Seattle, WA USA
heres why:
= 300/301
=0.9966
Actually, number_of_steps and step_delay are integer types, so the arithmetic is all integer. As a result, step_delay is 0, not 0.996. And the delay functions don't like being called with a value of 0.
yes I know there int type variables and thats why its not working so when you switch everything over from milliseconds to microseconds then the 0.966 thats seen as 0 is now seen as 996microseconds
