UK
Offline
Full Member
Kittens eat Arduinos
« on: January 17, 2011, 02:11:19 pm » |
I building grand plans for my arduino mega, involving sequences of actions depending on inputs from the real world that might talk an indeterminate time to happen. And remote policy commands via a wireless link. One of the policy actions I would like to implement is - give up and start again. void (*Sketch_Restart)(void) = 0x0000;
I think that (based on an amateurs lucky reading of the boot-loader code) and testing on the Arduino Mini that this definition works. Simple test code.. counts the 'c's that it sees prints when sent a 'p' and restarts from the beginning when sent an 'r' #define GREEN_LED 7 // flickers fast #define RED_LED 8 // slow flicker #define YELLOW_LED 9 // more of a flash
void setup() { Serial.begin(9600) ; pinMode(GREEN_LED, OUTPUT) ; pinMode(RED_LED, OUTPUT) ; pinMode(YELLOW_LED, OUTPUT) ; digitalWrite(GREEN_LED, 1) ; digitalWrite(RED_LED, 1) ; digitalWrite(YELLOW_LED, 1) ; }
static int static_variable = 0 ; static unsigned long counter = 0 ;
void loop() { counter++ ;
if ((counter % (16u*1024LU)) == 0UL) // every 16k thru the loop { digitalWrite(GREEN_LED, (counter % (32u*1024UL)) == 0UL) ; // togle green if ((counter % (32u*1024UL)) == 0UL) // every 32k times { digitalWrite(RED_LED, (counter % (64u*1024UL)) == 0UL) ; // toggle red if ((counter % (64u*1024UL)) == 0UL) // every 64k times digitalWrite(YELLOW_LED, (counter % (128u*1024UL)) == 0UL) ; // toggle yellow } } if(Serial.available()) // a character is waiting { switch(Serial.read()) { case 'r': Sketch_Restart() ; // call the start of myself:) break ; // dosnt get here case 'c': static_variable ++ ; // count my 'c's break ; case 'p': Serial.print("static_variable = ") ; Serial.println(static_variable) ; Serial.print("loop counter = ") ; Serial.println(counter) ; break ; } } } I do not know enough to know if this test means that what I want tio happen is happening - or if it is just luck. I would feel much happier if it was a part of the Arduino API  Dave
« Last Edit: January 17, 2011, 02:13:09 pm by dafid »
Logged
Netherlands
Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
« Reply #1 on: January 17, 2011, 03:13:27 pm » |
There is a lot of discussion on this forum about this function pointing to 0x0000. It restarts your code but it won't reset all registers and internal counters. If you search for "reset function" (upper right) you find several threads e.g. - http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1235780325That said, as long as it works for your sketches ...
Logged
UK
Offline
Full Member
« Reply #2 on: January 17, 2011, 08:27:55 pm » |
Thanks for the pointers, I now have read quite a bit more, and perhaps I understand some more. I understand the comments from others in the past - that a software reset() is not really a good thing to seek out... But given the sorts of things that I want to ask my poor micro controller to do (tack my model boat, and get the sails on the right side pulling, and head a certain direction, ...) And that I want that to be done in combinations of interrupt code and other peoples PID code and etc... I am sure that a fast - start from the very beggining() - method is worth having  . All that said, what I understand is required is: Set all the device registers to the initial states documented in the datasheet Set the cpu registers to zero jmp 0 #ifdef simple_reset void (*sketchRestaRt)(void) = 0x0000; #else #include <avr/io.h> void sketchRestart(void) { noInterrupts() ; // no interrupts while adjusting register values. // SET ALL DOCUMENTED REGISTERS TO THEIR POWER ON VALUES. MCUSR = 0 ; // no reset source WDTCSR = 0 ; // no watch dog resets EICRA = 0 ; // no external interrupts EIMSK = 0 ; // external interrupt mask cleared EIFR = 0 ; // external interrupt flag register - no pending interrupts PCICR = 0 ; // pin change interrupt control register PCIFR = 0 ; // pin change inetrrupt flag register PCMSK2 = 0 ; // pin change mask register 2 PCMSK1 = 0 ; // pin change mask register 1 PCMSK0 = 0 ; // pin change mask register 0 // port B DDRB = 0 ; PORTB = 0 ; // PINB not defined. // port C DDRC = 0 ; PORTC = 0 ; // PINC not defined // port D DDRD = 0 ; PORTD = 0 ; // PIND not defined // timer prescalers (timer 0 and 1) GTCCR = 0 ; // Timer - 0 TCCR0A = 0 ; TCCR0B = 0 ; TCNT0 = 0 ; OCR0A = 0 ; OCR0B = 0 ; TIFR0 = 0 ; TIMSK0 = 0 ; // Timer - 1 TCCR1A = 0 ; TCCR1B = 0 ; TCCR1C = 0 ; TCNT1 = 0 ; // 16 bit OCR1A = 0 ; // 16 bit OCR1B = 0 ; // 16 bit ICR1 = 0 ; // 16 bit TIFR1 = 0 ; TIMSK1 = 0 ; // Timer - 2 TCCR2A = 0 ; TCCR2B = 0 ; TCNT2 = 0 ; OCR2A = 0 ; OCR2B = 0 ; TIFR2 = 0 ; TIMSK2 = 0 ; // Assynchronous Status Register (timer 2 stuff) ASSR = 0 ; // SPI SPCR = 0 ; SPSR = 0 ; // SPDR undefined on restart // usart0 UDR0 = 0 ; UCSR0A = 0 ; // UDRE0 bit is read only, and 1 according the restart normal logic // can not change a read-only bit :( UCSR0B = 0 ; UCSR0C = _BV(UCSZ01) | _BV(UCSZ00) ; // reset values are these bits. UBRR0L = 0 ; UBRR0H = 0 ; // two wire interface TWBR = 0 ; TWCR = 0 ; TWSR = 0 ; TWDR = 0xff ; // this write might not suceed. Is only writeable when TWI is not shifting a byte. // maybe should disable twi as early as possible, so more chance this instruction works. // could need to delay for >1 milliSec for byte to be sent. // I do not use TWI (yet) so can perhaps ignore this.
TWAR = ~(_BV(TWGCE)) ; // all bits except TWGCE set. TWAMR = 0 ; // analog comparator ADCSRB = 0 ; ACSR = 0 ; DIDR1 = 0 ; // ADC ADMUX = 0 ; ADCSRA = 0 ; ADCSRB = 0 ; DIDR0 = 0 ; // ADCL = 0 ; // read only and the output of a conversion, not really a problem if not 0 on restart. // ADCH = 0 ; // read only // debugWire - not accessible outside debugWire // DWDR = 0 ; // might be prohibited from setting this. // flash access control SPMCSR = 0 ; // clear registers - still to do
interrupts() ; asm volatile ("jmp 0") ; } #endif
Ok... i haven't cleared the cpu registers yet - and there are IO registers that are read only with values defined at startup - so sketchRestart() is never going to be a 100% reset, but all the periperals that I care about are done/ for a 168 or a 368. It sort of works, [glow]except that the output of the first print is corrupted after the reset.[/glow]I am guessing that the hardware serial code is assuming some control value has been set in the boot loader. That will be a problem for tomorrow. And then the register clear. And then the same stuff for a Mega 1280. Maybe I am optimistic... but I think that then we will have a sketchReset() that is fast and reliable 8-) Dave
Logged
Left Coast, CA (USA)
Offline
Brattain Member
Measurement changes behavior
« Reply #3 on: January 17, 2011, 09:20:34 pm » |
Maybe I am optimistic... but I think that then we will have a sketchReset() that is fast and reliable Well the point that sold me on not having/using a 'softReset' function is that it is usually just a lack of imagination and/or experience at program structure. When someone can explain why they must have that function and that there is not other way for s/he's program to function without it, then maybe I will stand in that line. Until then, color me meh... I think I would rather learn how to master better program structure. Learning software skills has been frustrating to me at times, but I do feel I'm making steady progress. Mostly because I stay away from that nasty C++ stuff and just swim in the C part of the pool.  Lefty
Logged
Global Moderator
UK
Online
Brattain Member
I don't think you connected the grounds, Dave.
« Reply #4 on: January 18, 2011, 03:08:11 am » |
If you really need a reset (and I'm not saying you do), what's wrong with a watchdog? That's what they are designed for.
(still trying to reconcile 'fast' and 'sailboat' in my head)
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
UK
Offline
Full Member
« Reply #5 on: January 18, 2011, 07:08:07 pm » |
AWOl,
Sail boats are slowish.. but it is remote controlled, and possible to capsize, so if i get confused, or the micro controller gets confused, i do want a way back to the beggining.
So I think the watch-dog will go to hardware reset vector - and then wait for a timeout... and then start listening to commands.
Since I will already be in panic mode when i go for the reset, the extra delay is likely to panic me more.
Lefty,
C++ is a nice language. I have spent too many years doing coding. The first 10 years where a purgetory of assembler, fortran 4, pascal and c. Then we got a c++ compiler.
When you deal with something a lot/ like for 10+ years/ you have patterns and methods that make the problems easier to work with.
If you use C++ to represent what you know about the problem space then it frees you to concentrate on the novel parts of the problem. I really like C++ for this reason.
But since I know almost nothing about electronics, or the arduino, or the ATMEGAxx, I am using C++ to write C code.
And asking silly questions.
Dave
Logged
UK
Offline
Full Member
« Reply #6 on: January 18, 2011, 07:25:37 pm » |
The code is better or at least more elaborate.. Lots more comments as I have read more detail about how the USART works in the 328 and the 168. Clears registers  . The corruption on the serial port is reduced a bit. if you send 'ccccccccccccccccccccccccpr' as one string then the last character of the printed data is not properly flushed through the usart when the reset happens, and the next time i send a 'p' a garbage character is printed in place of the newline. I think the change that I made with most effect was to comment out UDR0 = 0 ; when I realised that it was a bi-directional register. I have still not worked out how to drain the transmit path.. i almost think it mioght not be possible But, it is getting closer I think, and I know some more, and having fun. Now I have registers cleared, and most of the USART code right (i think) next is to review the other devices. Regards, Dave #define GREEN_LED 7 // flickers fast #define RED_LED 8 // slow flicker #define YELLOW_LED 9 // more of a flash
void setup() { Serial.begin(115200) ; pinMode(GREEN_LED, OUTPUT) ; pinMode(RED_LED, OUTPUT) ; pinMode(YELLOW_LED, OUTPUT) ; digitalWrite(GREEN_LED, 1) ; digitalWrite(RED_LED, 1) ; digitalWrite(YELLOW_LED, 1) ; } #ifdef simple_reset void (*sketchRestaRt)(void) = 0x0000; #else #include <avr/io.h> void sketchRestart(void) { noInterrupts() ; // no interrupts while adjusting register values. // SET ALL DOCUMENTED REGISTERS TO THEIR POWER ON VALUES. MCUSR = 0 ; // no reset source WDTCSR = 0 ; // no watch dog resets EICRA = 0 ; // no external interrupts EIMSK = 0 ; // external interrupt mask cleared EIFR = 0 ; // external interrupt flag register - no pending interrupts PCICR = 0 ; // pin change interrupt control register PCIFR = 0 ; // pin change interrupt flag register PCMSK2 = 0 ; // pin change mask register 2 PCMSK1 = 0 ; // pin change mask register 1 PCMSK0 = 0 ; // pin change mask register 0 // port B DDRB = 0 ; PORTB = 0 ; // PINB not defined. // port C DDRC = 0 ; PORTC = 0 ; // PINC not defined // port D DDRD = 0 ; PORTD = 0 ; // PIND not defined // timer prescalers (timer 0 and 1) GTCCR = 0 ; // Timer - 0 TCCR0A = 0 ; TCCR0B = 0 ; TCNT0 = 0 ; OCR0A = 0 ; OCR0B = 0 ; TIFR0 = 0 ; TIMSK0 = 0 ; // Timer - 1 TCCR1A = 0 ; TCCR1B = 0 ; TCCR1C = 0 ; TCNT1 = 0 ; // 16 bit OCR1A = 0 ; // 16 bit OCR1B = 0 ; // 16 bit ICR1 = 0 ; // 16 bit TIFR1 = 0 ; TIMSK1 = 0 ; // Timer - 2 TCCR2A = 0 ; TCCR2B = 0 ; TCNT2 = 0 ; OCR2A = 0 ; OCR2B = 0 ; TIFR2 = 0 ; TIMSK2 = 0 ; // Assynchronous Status Register (timer 2 stuff) ASSR = 0 ; // SPI SPCR = 0 ; SPSR = 0 ; // SPDR undefined on restart // usart0 if ( UCSR0B & (1<<RXEN0)) // if recieve enabled, drain the input buffers { unsigned char dummy; while ( UCSR0A & (1<<RXC0) ) dummy = UDR0; // while data present read from receive queue } if (UCSR0B & (1<<TXEN0)) // if transmit enabled { // Try to to drain the transmit fifo; sometimes we do not succeed, we leave the data // in the shift register and change the settings, leading to garbage on the line. // This code is not sure to work, as it is not possible to reliably tell if // there is data in the trasmit shift register. // The bit TXC0 is cleared after a transmit interrupt is sent, and can be cleared by code. // If the TXC0 bit is clear, it could mean that there is data waiting to be sent or that there isn't. // If the TXC0 bit is set, there is no data to send. // The only reliable signal that there is more data to send is the UDRE0 bit which indicates that one and // a part characters are waiting to be sent. if ((UCSR0A & (1<<UDRE0)) == 0) // there is a byte in the transmit fifo { while ((UCSR0A & (1<<UDRE0)) == 0) // while transmit queue is not empty ; // drain the transmit buffer while ((UCSR0A & (1<<TXC0)) == 0) // transmit of last character not yet complete ; // and wait for the transmit shift buffer to empty } } // the UDR0 register supplys the data for both input and output side of UART comms.. // UDR0 = 0 ; // would be transmitting a null :( - leads to corruption because we are about to set the speed to 1M Bit/second. // if I put this back the garbage is much more :)
UCSR0A = 0 ; // RXC0 bit is clear due to read queue draining above // TXC0 bit is cleared by assinment to 0. // UDRE0 bit is read only, and 1 according the restart normal logic // UDRE0 bit should be 1 if transmit was enabled because of the transmit fifo draining above. // FE0 (frame error) is cleared by draining the read queue // DOR0 (data over run) is cleared by draining read queue // UPE0 (usart parity error) is cleared by draining the read queue // U2X0 (double baud rate) is set to zero by assignment of 0 // MPCM0 (multi-processor communication mode) cleared by to zero by assignment of 0 UCSR0B = 0 ; // no recieve interrupt, no TX complete interrupt, no UDR empty interrupt, reciever disabled, transmitter disabled, // ! 9bit chars, 9th bit in =0, 9th bit out=0 UCSR0C = _BV(UCSZ01) | _BV(UCSZ00) ; // reset values are these bits; // 8 bit characters // UMSEL01, UMSEL00 - bits are 0, indiactes Asynchronous USART // UPM01, UPM00 - bits are 0, partity disabled. // USBS = 0, one stop bit // UCSZ01, UCSZ02 - bits are 1, implies 8 bits per character. // UCPOL0, bit is 0, asynchronous mode. UBRR0L = 0 ; // baud rate is clock divided by 16 UBRR0H = 0 ; // // two wire interface - more to check TWBR = 0 ; TWCR = 0 ; TWSR = 0 ; TWDR = 0xff ; // this write might not suceed. Is only writeable when TWI is not shifting a byte. // maybe should disable twi as early as possible, so more chance this instruction works. TWAR = ~(_BV(TWGCE)) ; // all bits except TWGCE set. TWAMR = 0 ; // analog comparator ADCSRB = 0 ; ACSR = 0 ; DIDR1 = 0 ; // ADC ADMUX = 0 ; ADCSRA = 0 ; ADCSRB = 0 ; DIDR0 = 0 ; // ADCL = 0 ; // read only // ADCH = 0 ; // read only // debugWire - not accessible outside debugWire // DWDR = 0 ; // might be prohibited from setting this. // flash access control SPMCSR = 0 ;
asm volatile ("clr r0") ; asm volatile ("clr r1") ; asm volatile ("movw r2, r0") ; asm volatile ("movw r4, r0") ; asm volatile ("movw r6, r0") ; asm volatile ("movw r8, r0") ; asm volatile ("movw r10, r0") ; asm volatile ("movw r12, r0") ; asm volatile ("movw r14, r0") ; asm volatile ("movw r16, r0") ; asm volatile ("movw r18, r0") ; asm volatile ("movw r20, r0") ; asm volatile ("movw r22, r0") ; asm volatile ("movw r24, r0") ; asm volatile ("movw r26, r0") ; asm volatile ("movw r28, r0") ; asm volatile ("movw r30, r0") ; interrupts() ; asm volatile ("jmp 0") ; } #endif
if ((counter % (16u*1024LU)) == 0UL) // every 16k thru the loop { digitalWrite(GREEN_LED, (counter % (32u*1024UL)) == 0UL) ; // togle green if ((counter % (32u*1024UL)) == 0UL) // every 32k times { digitalWrite(RED_LED, (counter % (64u*1024UL)) == 0UL) ; // toggle red if ((counter % (64u*1024UL)) == 0UL) // every 64k times digitalWrite(YELLOW_LED, (counter % (128u*1024UL)) == 0UL) ; // toggle yellow } } if(Serial.available()) // a character is waiting { switch(Serial.read()) { case 'r': sketchRestart() ; // call the start of myself:) break ; // dosnt get here case 'c': static_variable ++ ; // count my 'c's break ; case 'p': Serial.print("static_variable = ") ; Serial.println(static_variable) ; Serial.print("loop counter = ") ; Serial.println(counter) ; break ; } } }
Logged
Global Moderator
Dallas
Offline
Shannon Member
« Reply #7 on: January 18, 2011, 08:16:08 pm » |
Since I will already be in panic mode when i go for the reset, the extra delay is likely to panic me more. 16 milliseconds is going to panic you more? Will that extra 16 milliseconds make that much of a difference on a sailboat? Would you even be able to tell the difference between zero delay and a 16 millisecond delay? In my experience, less code = fewer bugs. You're adding quite a bit of code to "reset" the processor. Does your plan include a method for identifying bugs in your reset code? What if your reset code does not work correctly? Will you have a "reset squared" in case your "reset" fails to work?
« Last Edit: January 18, 2011, 08:19:26 pm by bcook »
Logged
UK
Offline
Full Member
« Reply #8 on: January 19, 2011, 03:55:44 am » |
Thanks for the questions... I don't see 16ms delay on a reset. When my Arduiono Mini resets it spends a LONNGGGGGG time waiting in the boot loader Sometimes it feels like 10 seconds. Since it is easy to plug into a prototype board, the Mini is what I use on the desk, so almost exclusively. I have always had to time about 2 seconds after starting the download in the IDE to release of the reset switch to get new software downloaded onto it, but it works  . A while back I put a new bootloader on the Mini, using the IDE, in the hope that it would be better, with no difference perceived. Is there some way to avoid this delay that I have missed? Dave
Logged
Global Moderator
UK
Online
Brattain Member
« Reply #9 on: January 19, 2011, 04:08:26 am » |
16ms is the watchdog timeout, the rest of the time after the watchdog RESET is the bootloader. Once you have proved your software, put it direct into a fresh AVR without a bootloader. Hopefully by then, you'll have tested your software so well, you won't actually need the watchdog.
Logged
UK
Offline
Full Member
« Reply #10 on: January 19, 2011, 02:01:36 pm » |
Ok, I see where you are coming from - I can replace the bootloader code, so I shouldn't fuss with the reset. That is probably the correct low risk approach as my simulated reset is never going to be quite right (as otherwise ATMEL would have a doc on their site saying how to do it). But I am treating it as a learning exercise, to better understand the processor, while also preserving the ability to bootload the code. My eventual objective is that I will be able to build quite complex strategies into the top level controller - with no need to have the logic that reverts each path back to a known starting point. This is an extension of a well known approach in application development - called "Crash only software" http://lwn.net/Articles/191059/ - which states that you know your program will fail, so design for it to fail and recover gracefully, and quickly. If you get it right (like I hope to) then you are free to actively use the fail & recovery path to simplify your system... So for example, I will only code the control algorithms to a position that is defined in terms of the current position. All the commands that request a change to a position determined from the boot up state will be saved in a EEPROM location and executed after restart. This should reduce the amount of code I need to write quite a bit. Dave
« Last Edit: January 19, 2011, 02:04:17 pm by dafid »
Logged
Global Moderator
Dallas
Offline
Shannon Member
« Reply #11 on: January 19, 2011, 02:30:10 pm » |
This is an extension of a well known approach in application development - called "Crash only software" http://lwn.net/Articles/191059/ - which states that you know your program will fail, so design for it to fail and recover gracefully, and quickly. Which is a rehash of a much older concept called a "watchdog timer".
Logged
Offline
Brattain Member
« Reply #12 on: January 19, 2011, 02:43:56 pm » |
It's still my opinion that you are trying to solve a problem that does not exist. Just write better/proper structure to begin with, would seem to me to be better all around strategy?
" Who guards the guards?"
Lefty
« Last Edit: January 19, 2011, 02:44:23 pm by retrolefty »
Logged
UK
Offline
Full Member
« Reply #13 on: January 19, 2011, 05:18:43 pm » |
Hi Coding Badly and Lefty, (sorry i hit tab in the editor and then return which posted while i was still working on it) I will try to sketch out the reasoning for the software sketchReset() for you and explain how it is just a bit different to a Watch-Dog-Timer... First picture a program structure in loop() that implements various tasks in functions, and each task-function breaks its steps into lower level functions.. So there might be a function which called tack() to sail the boat onto the other side of the wind... that is if the wind is on the left of the boat at the start, it should be on the right at the end - and the boat should move forwards at all times... Here is a rough (first try at) tack() void tack() { boolean startTack = currentTack() ;
while (currentSpeed() < 0 || startTack == currentTack()) // while not moving forwards or not on the new tack { // work to fix these issues
while (speed() < 0) // sailing backwards { try_to_sail_forwards() ; // this is pretty complex in of itself - and will take some time to fix. // in a real boat can break things by sailing backwards. }
// we are sailing forwards - is a good start :)
// have to start a tack with some boat speed, because sailing through the wind slows us down - we can end out stopped // head to the wind - 'in irons' is the old term. // we will drift backwards with the wind and then need the try_to_sail_forwards() ...
// we are sailing forwards while (currentTack() == startTack) // we are still on the wrong tack { // work to sail fast enough to tack while (currentSpeed() < GOOD_STEERAGE_WAY) // while not going fast enough to turn into the wind and across to the other tack { // work to sail faster try_to_sail_faster() ; }
while (sailsPulling()) // still under power from wind { while (currentSpeed() > GOOD_STEERAGE_WAY) // still fast enough to manoeuvre { headUpALittle() ; /// steer into the wind trimSails() ; // adjust the sails so they keep pulling } } // sails not pulling - to close to the wind to sail.. while (currentTack() == startTack && headingVersusWind() < currentSpeed() * CLUDGE_FACTOR) // not tacked and still moving { // we should be able to continue through wind onto other tack loosenSails() ; // reduce drag from wind on the boat headUpALittle() ; // steer into the wind, not too much or rudder will act like a brake } // either on the right tack or are too slow } // on the right tack now, but the tack is not complete until you are moving with STEERAGE_WAY while (currentSpeed() < GOOD_STEERAGE_WAY) // while not going fast enough { // work to sail faster try_to_sail_faster() ; } return ; // on the right tack now. }
The thing to notice is almost all the commands are relative adjustments to controls or policy... And that each function trimSails(), as an extreme example, could be as involved as the above. If every thing is working then the boat should smoothly sail up to close to the wind, let the sails loose and then continue to glide through the wind onto the other tack, and then trim the sails in and sail away on the other tack. If it goes wrong... then the control software will not know how to move to a better state. For example, if the wind shifts by 50 degrees, then the boat could be caught head to wind, and just think that the wind has died.... At that point, I by remote control, would send boat the command to do the wake-up and gain control sequence - ie the power on sequence. I know that there are finite state machine approaches to control software that might allow this stuff to be written differently, with different classes of special cases that are difficult to deal with... But this is the sort of way I think when I attempt to explain sailing... So I think the patterns will be quite complex... // I could wrap each function call with an abort signal propagator - something like
if (!trimSails()) return false ;
// And in the character received interrupt if (ch == 0x3) // control-C abortRequested = true ; // will be seen in loops
// And the application code where it fails if (unhandledCaseHappens()) return false ;
//with checks in every loop like so
if (abortRequested) return false ;
but it seems ugly in comparison to // in the code where required if (unhandledCaseHappens()) restartSketch() ;
// in the character received interrupt if (ch == 0x3) // control-C restartSketch() ;
This is LIKE the Watch Dog Timer of old.. - which is still a good idea where the requirement is to ensure that the code stays on the straight and narrow.. and a bit like cheap software exceptions with exactly one catch() block - the sketch reload point  . Dave
« Last Edit: January 19, 2011, 06:30:28 pm by dafid »
Logged
