Loading...
Pages: [1]   Go Down
Author Topic: pulseIn()  (Read 478 times)
Ignazio Moresco
Guest
I'm trying to read an accellerometer with the arduino board and I need to go below millis() to get the pulse length. I saw a pulseIn() implementation in wiring but the arduino 002 alpha doesn't implement it. Do I need to install a wiring library? How can I do that? Is there any shortcut to resolve the problem?
Thank you
Ignazio
Logged
Forum Administrator
MMX
Offline Offline
Edison Member
hallo kompis
View Profile
WWW
Hej Iganzio,
we haven't implemented that function yet. However there are a couple of easy roundabouts, I will mention the easiest one that we use with the Memsic2125:
Code:
val = digitalRead(Signal); // Append signal value to val
while(val == LOW) { // Loop until pin reads a high value
while(val == HIGH) { // Loop until pin reads a high value
 timecount = timecount +1;            // Count echo pulse time
This code snippet will listen to a HIGH pulse.
Which accelerometer are you using?
/David
Logged
Ignazio Moresco
Guest
David,
thanks so much
that works perfectly
ignazio
Logged
Forum Administrator
MMX
Offline Offline
Edison Member
hallo kompis
View Profile
WWW
uoops,
I misspelled your name .. I am sorry  :-[
/David
« Last Edit: October 28, 2005, 05:41:09 pm by DojoDave » Logged
Ignazio Moresco
Guest
No big deal
The accellerometer is the Memsic 2125
Ignazio
Logged
Pages: [1]   Go Up
Print
Jump to:
