Topic: problem reading a specific analog output (Read 2140 times) previous topic - next topic
sebb0
Hi!
I wrote this little app to read from specific inputs on a multiplexor and I have 8 small potentiometers.
The problem is that when I ativate one input and read it's value it still reads all the other 7 values so it doesn't matter which input I activate I can still change the value with any of the potentiometers.
I'm using a: 74HCT4051N multiplexer
and regular analog potentiometers.
My code:
Code: [Select]
int analog1 = 0;
int value = 0;
  beginSerial(9600);        // connect to the serial port
void changeMpu(char val1, char val2, char val3) {
  digitalWrite(1, val1);
  digitalWrite(2, val2);
  digitalWrite(3, val3);
  changeMpu(LOW, LOW, LOW);
  printString("A");
  value = analogRead(analog1);
  printInteger(value);
  serialWrite(10); // <-- end of line
  serialWrite(13); // <-- carriage return
  changeMpu(HIGH, LOW, LOW);
  printString("B");
Thanks in advance!
/sebb0
quique
It seems you haven't configured digital pins 1,2 and 3 as outputs, so function digitalWrite may don't work properly. But there is another problem:
when using serial comunication pins 1 and 2 cannot be used because they are mapped to Rx and Tx pins in the serial socket as you can see in the schematics.
So try to assign another set of pins as outputs and good luck. ;)
sebb0
Thanks for the quick answer and it works a bit better now.
Another problem I have is that when I change one of potentiometers that I haven't configured it to read the output to the computer just stops with a strange and always different letters.
Also, if I set one of the potetiometers to a specific position and then set to other to a different one, I get two different values which is good. But they aren't very stable and can change without me even touching the potentiometer.
DojoDave
Hej,
these problems you are reporting about the board-to-computer communication stopping, and the readings not being stable sound to me as typical wiring problems. I think you have to take a careful look to the circuit.
/David
