Topic: arduino 003 macosx serial monitor (Read 953 times) previous topic - next topic
erich
hi,
any idea ?
pushing the serial monitor button on osx 10.3x results on my machine in a:
Error inside Serial.<init>()
gnu.io.PortInUseException: Unknown Application
        at gnu.io.CommPortIdentifier.open(CommPortIdentifier.java:354)
        at processing.app.Serial.<init>(Serial.java:127)
        at processing.app.Serial.<init>(Serial.java:63)
        at processing.app.Editor.handleSerial(Editor.java:1300)
        at
processing.app.EditorButtons.mouseReleased(EditorButtons.java:344)
        at java.awt.Component.processMouseEvent(Component.java:5166)
        at java.awt.Component.processEvent(Component.java:4963)
        at java.awt.Container.processEvent(Container.java:1613)
        at java.awt.Component.dispatchEventImpl(Component.java:3681)
        at java.awt.Container.dispatchEventImpl(Container.java:1671)
        at java.awt.Component.dispatchEvent(Component.java:3543)
        at
java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:3527)
        at
java.awt.LightweightDispatcher.processMouseEvent(Container.java:3242)
        at java.awt.LightweightDispatcher.dispatchEvent(Container.java:3172)
        at java.awt.Container.dispatchEventImpl(Container.java:1657)
        at java.awt.Window.dispatchEventImpl(Window.java:1606)
        at java.awt.EventQueue.dispatchEvent(EventQueue.java:456)
        at
java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.ja
va:234)
        at
java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java
:184)
        at
java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:178)
        at
java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:170)
        at java.awt.EventDispatchThread.run(EventDispatchThread.java:100)
admin
hello erich
That error usually happens when another application is using the serial port (i.e. ZTerm open or Processing is still connected etc etc)
make sure you have run the macosx_setup.command script.
shut down an restart machine after running the script
hope this helps
massimo
erich
of course - i did run the script - but i did not reboot !
now it works, merci !
erich
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
