Author Topic: [Arduino004] serial error on PBG4 and osx  (Read 468 times)
Britanny
Mais vrai, j'ai trop pleuré, toute lune est atroce
hello
on my PBG4 with osx.4.6 (J2SE 5.0, FTDIUSBSerialDriver 2.0.1), i've received error when upload prog to arduino.
RXTX leds bright... i suppose the upload is ok.
Error inside Serial.<init>()
gnu.io.PortInUseException: Unknown Application
      at gnu.io.CommPortIdentifier.open(CommPortIdentifier.java:354)
      at processing.app.Serial.<init>(Serial.java:127)
      at processing.app.Serial.<init>(Serial.java:72)
      at processing.app.Uploader.uisp(Uploader.java:146)
      at processing.app.Uploader.uploadUsingPreferences(Uploader.java:78)
      at processing.app.Sketch.upload(Sketch.java:1689)
      at processing.app.Sketch.exportApplet(Sketch.java:1749)
      at processing.app.Editor$38.run(Editor.java:1866)
      at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
      at java.awt.EventQueue.dispatchEvent(EventQueue.java:461)
      at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:269)
      at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:190)
      at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:184)
      at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:176)
      at java.awt.EventDispatchThread.run(EventDispatchThread.java:110)
Atmel AVR ATmega8 is found.
Uploading: flash
Firmware Version: 1.18
there is no other prog used the serial port as describe in precedent post
i use the setup command and reboot the machine (more exactly shut down and restart as Tom Igoe explain in the processing bug page)
i've tried a simple prog to send string throug serial.
no compilation error, good tranfer, but no blinking TX's led.
i was exciting by the new version, but now :-/ :-?
regards
eric
« Last Edit: April 30, 2006, 05:33:04 pm by mrbbp » Logged
Britanny
don't know why, it's work now.
no reboot... :o
eric
Britanny
well...
serial is a bit "versatil".
- if i boot my computer with the arduino plugged, serial initialize correctly and serial monitor work fine.
if i unplugged the arduino card and plug again, even if i restart IDE, serial monitor doesn't work anymore with this message
      at processing.app.Serial.<init>(Serial.java:63)
      at processing.app.Editor.handleSerial(Editor.java:1397)
      at processing.app.EditorButtons.mousePressed(EditorButtons.java:373)
      at java.awt.Component.processMouseEvent(Component.java:5551)
      at javax.swing.JComponent.processMouseEvent(JComponent.java:3126)
      at java.awt.Component.processEvent(Component.java:5319)
      at java.awt.Container.processEvent(Container.java:2010)
      at java.awt.Component.dispatchEventImpl(Component.java:4021)
      at java.awt.Container.dispatchEventImpl(Container.java:2068)
      at java.awt.Component.dispatchEvent(Component.java:3869)
      at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4256)
      at java.awt.LightweightDispatcher.processMouseEvent(Container.java:3933)
      at java.awt.LightweightDispatcher.dispatchEvent(Container.java:3866)
      at java.awt.Container.dispatchEventImpl(Container.java:2054)
      at java.awt.Window.dispatchEventImpl(Window.java:1774)
      at java.awt.EventQueue.dispatchEvent(EventQueue.java:463)
- if i boot without the card plugged, i'm enable to have serial monitor, i've got the mesage above.
 >smiley-sad :-X :-/
it was working fine in arduino003.  :'( snif
it look so simple in v003 and so complex with 004.
sorry i'm on G4 not on Intel smiley-wink
eric
Forum Administrator
Cambridge, MA
Hmm, "You may also need to remove the contents of /var/spool/uucp".  So says Processing, anyway.
Also, can you post the output of typing at the Terminal: groups
And: ls -la /var/lock
And: ls -la /var/spool/uucp
Britanny
for groups
mrpow appserveradm uucp appserverusr admin
ls - la /var/lock
drwxrwxr-x    4 root   uucp   136 May  1 00:34 .
drwxr-xr-x   25 root   wheel  850 May  1 01:25 ..
-r--r--r--    1 mrpow  uucp    11 May  1 00:12 LK.002.009.000
-r--r--r--    1 mrpow  uucp    11 Apr 30 23:55 LK.002.009.002
/var/spool/uucp
drwxrwxr-x   14 root   uucp   476 May  1 00:35 .
drwxr-xr-x    8 root   wheel  272 Oct 20  2005 ..
-r--r--r--    1 mrpow  uucp    11 May  1 00:35 LK.002.009.010
-r--r--r--    1 mrpow  uucp    11 Apr 30 21:41 LK.002.009.012
-r--r--r--    1 mrpow  uucp    11 Apr 19 12:17 LK.002.009.014
-r--r--r--    1 mrpow  uucp    11 Apr 19 15:38 LK.002.009.016
-r--r--r--    1 mrpow  uucp    11 Apr 19 15:46 LK.002.009.018
-r--r--r--    1 mrpow  uucp    11 Apr 19 16:27 LK.002.009.024
-r--r--r--    1 mrpow  uucp    11 Mar 17 02:56 LK.002.009.026
-r--r--r--    1 mrpow  uucp    11 Apr 19 17:01 LK.002.009.028
-r--r--r--    1 mrpow  uucp    11 Apr 19 18:01 LK.002.009.032
-r--r--r--    1 mrpow  uucp    11 Apr 20 09:53 LK.002.009.036
-r--r--r--    1 mrpow  uucp    11 Apr 20 10:47 LK.002.009.038
-r--r--r--    1 mrpow  uucp    11 Nov 23 01:29 LK.003.009.000
hope this will help
eric
Forum Administrator
Cambridge, MA
You may need to delete all the files in /var/spool/lock.  From the Terminal, run: open /var/spool/lock
Then select all the files and delete them - you may need to authenticate.
Britanny
i've deleted all the files in /var/spool/uucp
and it seems to work.
i've no folder /var/spool/lock
in /var/spool/ :
cups    fax     mqueue  postfix samba   uucp
regards
eric
