Topic: ( to developers ARDUINO IDE...) add support /f command in serial monitor (Read 932 times) previous topic - next topic
selevo
Serial.print ("\ f");
Internal Serial Port monitor does not understand the /f command (new page / sheet or screen cleaning)
As a result, the information is not very convenient.
I suggest adding support for this command
So as in other terminals it was possible to display information beautifully and conveniently.
For example:
Similar code
Code: [Select]
         Serial.print("\f"); // очистка  экрана  терминала
              Serial.print("ADC0:");
    Serial.print(3*(analogRead(0)))  ;
Serial.print("ADC1:");
    Serial.print(analogRead(1))  ;
Serial.print("ADC2:");
    Serial.print(analogRead(2))  ;
delay (1000);
view in
internal serial monitor:
https://youtu.be/MY-1HiDB-NE
view in
windows  hiperterminal
https://youtu.be/s5n-bjAtVXo
It is obvious that in the second example, the species is significantly better.
AWOL
If you want terminal control functions, use a terminal emulator.
(PuTTY is way better than Hyperterm)
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
selevo
I propose to introduce team support in the built-in monitor
Since it was already done, it would be nice to finish it.
pert
I don't know what "team support" means. Please provide more information. What do you mean by "it was already done"?
selevo
Let it clear the screen and move to position 0.0
As it is done in other terminals
Through Serial.print ("\ f");
I wrote in the first message and showed the difference in presentations in different terminals
Built-in firduino and windows
sorry for my English
pert
Ok, I understood what you meant in your original post, just not the part about team support. I've also thought it would be useful to be able to clear the screen in Serial Monitor.
I'm guessing if you submitted a pull request for this to the Arduino IDE GitHub repository the Arduino developers would give it serious consideration. You might first do some searching through the past issues and pull requests to see if the topic has already been discussed:
https://github.com/arduino/Arduino/issues?q=
sterretje
Serial monitor is a debugging aid; I doubt it was ever intended as a full fletched terminal program. Its only advantage over other terminal programs is that it's integrated in the IDE and therefore the IDE can control it during code uploads.
In real life you do not want to start the IDE just to view some serial data and you will use a different terminal program that supports ANSI escape codes and saving to file or sending a file to the Arduino.
And if you require that functionality during debugging, it's easy to use another terminal program. As said, only disadvantage is that the IDE can't control it and you have to close the the port manually before code upload. But that's something I can live with.
Just my thoughts.
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
ballscrewbob
I use the built in quite a bit and agree with sterretje.
If I need extended functions I use realterm or the others already mentioned.
The IDE is meant to be about as simple as you can get so as not to overwhelm new users to the Arduino.
Adding fancy functions and complexity by way of switches to it is not the way to go IMHO.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
