Author Topic: Software serial in 04  (Read 294 times)
Bartlett University London
Physical Computing is the next Darts
Hi there I am trying to drive a motor with a Little Step-U
Unipolar Stepper Motor Controller http://www.tla.co.nz/lit_step.html
Can someone please explain how to use the new software serial in 04?
Rennes
Same question for me.
I've found some interesting files in Arduino libraries, like "uartsw.c" and "uartswconf.h". But no way to use them in my program for the moment.
Any idea?
Forum Administrator
Cambridge, MA
See this thread for some info:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1147888882
hdeweyh
Guest
I just got the following code working based on the examples in the FAQ. Only weird thing is it sends two bytes for every byte, one is the correct byte one is  dec 192. Consistently over and over!
#define BAUDRATE 9600
// the width of a single bit of serial data in microseconds
// in each second (1000000 microseconds) there are a number of bits equal
// to the baud rate (e.g. 9600), so each bit lasts for 1000000 / baudrate
// microseconds
int width = 1000000 / BAUDRATE;
int fudge = -25;
int TXfudge = -20;
int rx = 6;
int tx = 7;
  pinMode(rx,INPUT);
  pinMode(tx,OUTPUT);
  digitalWrite(tx,HIGH);
  digitalWrite(13,HIGH);
void SWprint(int data)
  int mask;
  //startbit
  digitalWrite(tx,LOW);
  delayMicroseconds(width + TXfudge);
  for (mask = 0x01; mask; mask <<= 1) {
    if (data & mask){ // choose bit
      digitalWrite(tx,HIGH); // send 1
    else{
      digitalWrite(tx,LOW); // send 1
  //stop bit
  digitalWrite(tx, HIGH);
int SWread()
  int val = 0;
  // one byte of serial data (LSB first)
  //      start  0   1   2   3   4   5   6   7 stop
  while (digitalRead(rx));
  // confirm that this is a real start bit, not line noise
  if (digitalRead(rx) == LOW) {
    // frame start indicated by a falling edge and low start bit
    // jump to the middle of the low start bit
    delayMicroseconds(width / 2);
    // offset of the bit in the byte: from 0 (LSB) to 7 (MSB)
    for (int offset = 0; offset < 8; offset++) {
      // jump to middle of next bit
      delayMicroseconds(width + fudge);
      // read bit
      val |= digitalRead(rx) << offset;
    val=0;
  return val;
    int SWval;
    SWval = SWread();
    SWprint(SWval);
-Heather
« Last Edit: August 08, 2006, 02:18:28 pm by hdeweyh » Logged
Forum Administrator
Cambridge, MA
Are you sending between two Arduino boards?  If so, you might try sending to something else with a hardware serial port (like a Wiring board) to see if the problem is in the sending or the receiving.
hdeweyh
Guest
I am sending between Arduino and a PC. I have tested the code using hardware serial on half (first HW TX with SW RX then HW RX with SW TX) and the problem is definitely in the sending.
-h
