Topic: variables? (Read 991 times) previous topic - next topic
xhlin
Oct 25, 2006, 12:20 am Last Edit: Oct 25, 2006, 12:20 am by xhlin Reason: 1
hi!
is it possible to declare a variable in the arduinoCode and recieve it through flash?
i have tried the FlashConversation.fla, working fine but the code is to complex for me to clean up.
could someone offer me the most simple piece of code that can recieve a number from arduino to flash, please!
Eric
#1
Oct 25, 2006, 10:13 am Last Edit: Oct 25, 2006, 11:43 am by Eric Reason: 1
Hello,
I always use the 'Serial Server' created by Dan O'Sullivan.
Read the instructions, after installing, start the server with:
java -jar ss6.jar SerialPort:COM1 Baud:9600 SocketPort:9001 Sub0ForChar:10 SerialDriver:Sun
(maybe you have to change your serialport):
You can use the 'debug' checkbox to check if the 'serial server' receives any value.
If it works you can start Flash and use this code:
Code: [Select]
createSocket();
function createSocket() {
     serialServer = new XMLSocket();
     trace("new xmsocket");
     serialServer.connect("127.0.0.1", 9001);
     serialServer.onConnect = function(success) {
           trace("connected " + success);
     // when you close the serial port
     serialServer.onClose = function() {
           trace("closed");
     //receive some data from the arduino
     serialServer.onData = function(data) {
           trace("incoming = " + data);
// send data to the arduino
this.onMouseDown = function() {
     serialServer.send("A");
     trace("Mouse Down");
stop();
xhlin
does it work with ,  Serial Proxy?
and what code do you fill your arduino with, simpeMessageSysyem?
regards
xh|in
Eric
You can use this code to send data from Arduino to flash:
Code: [Select]
 Serial.println("Hello Flash, this is Arduino");
 delay(400);
Daniel Guse
#4
Oct 30, 2006, 11:01 pm Last Edit: Oct 30, 2006, 11:07 pm by Daniel_Guse Reason: 1
Hi!
I tried to connect Arduino (0005) and Flash 8. But there are two strange things happening:
- 1 -
When I read the Serial monitor in Arduino, there are only "0"s (zeros) when I press a pushbutton (connected to I/O Pin 5), but when I release this pushbutton, there are both, "0"s and "1"s (00011100000011111000111 and so on). Actually, there should be only "1"s, right?! Why does this happen?
Here's my Arduino-Code:
int ledPin = 13; // LED connected to digital pin 13
int inPin = 5;   // pushbutton connected to digital pin 5
int val = 0;     // variable to store the read value
 pinMode(ledPin, OUTPUT);      // sets the digital pin 13 as output
 pinMode(inPin, INPUT);      // sets the digital pin 7 as input
 Serial.begin(9600);      // opens serial port, sets data rate to 9600 bps
 val = digitalRead(inPin);   // read the input pin
  digitalWrite(ledPin, val);    // sets the LED to the button's value
 // Serial.print(val, DEC);  // send the buttons's value to serial port
   // say what you got:
   //Serial.print("I received: ");
   Serial.println(val, DEC);
- 2 -
Another problem occurs in Flash. I'm using a proxy by D.Mellis, that works fine so far. Flash can hear Arduino and trace the received values. But, when I use an "if"-loop, it seems to be ignored. Here's my Actionscript-Code:
     createSocket();
     trace("new xmlsocket");
     serialServer.connect("127.0.0.1", 5337);
           trace("closed");
           // begin if-loop
           if (data == "0") {
                 meinRechteck.start();
                 trace("VERTICAL");
           else {
                 meinRechteck.stop();
                 trace("HORIZONTAL");
stop();
And this is, what is traced:
incoming = 0
HORIZONTAL
incoming = 1
HORIZONTAL
So, there is always "HORIZONTAL" traced, but i want "VERTICAL" if data == "0" !
Maybe someone can help me?! Any ideas? Thanks a lot!
Daniel
Eric
1)
Did you use a resistor as you can see in this tutorial?
2)
I don't really know, but you could try this to find out and locate the problem:
trace("type = " + typeof(data));
trace("string length = " + data.length);
So the datatype should be a 'string' and the length should be '1'
I
Daniel Guse
Hej ya!
So, I set up the whole thing like in the tutorial and now the serial output is ok!  :) Thanks a lot, Eric!
But:
I traced the lenght and type of 'data' in Flash 8:
data is a string (ok) and the length is 2 (not 1)!
Does anyone know how to solve this problem?
Thanx a lot for your support...
Daniel.
Eric
I think you only want the first character,
the second is probably a 'space'.
The actionscript code for this is:
Code: [Select]
trace(data.substr(0,1));
It will only show the first character.
Eric
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
