Topic: Arduino 007 serial monitor problem on PPC Mac (Read 1 time) previous topic - next topic
eforman
Hello, first post here.  Trying to use a known-good Arduino NG board with 007 on a PPC Mac (10.4.8).  Searched forums and some have had similar error but none of the suggestions helped.  Uploading sketches works fine. Opening serial monitor gives error:
[font=Courier]Error inside Serial.<init>()
gnu.io.PortInUseException: Unknown Application
  at gnu.io.CommPortIdentifier.open(CommPortIdentifier.java:354)
  etc...[/font]
Serial ports shown in IDE are
  /dev/tty.usbserial-a4000q4n [this one selected]
  /dev/cu.usbserial-a4000q4n
like i said, uploading works so obviously port access is ok.  according to forums, this error happens when something else is using port but no other programs are running and i've shut down and restarted.  this machine also has a clean install of tiger on it, btw.  forum posts all suggest re-running macosx_setup.command file but 007 doesn't use that any more, having supposedly fixed the issue that required it right?  i tried downloading 006 and it anyway, which is probably a bad idea, and i got this:
[font=Courier]niutil: can't get property users in directory /groups/uucp: No such property
Finished making changes, you should be all set[/font]
TIA for any help,
- eric
mellis
Do you have any other versions of the RXTX library installed (e.g. in /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Home/lib/ext)?  Do you have a /var/lock or /var/spool/lock directory (you'll have to check using the Go > Folder menu in the Finder or from the Terminal)?  If so, and there's anything in those directories, you might try deleting them.  You could also try creating a uucp group using Netinfo Manager (in Applications > Utilities) and then rerunning the macosx_setup.command.  Do you have any other software that access the serial ports (e.g. other physical computing tools or PDA sync apps or a firewall)?
eforman
no other version of rxtx.  no /var directories.  no other software using serial ports.
but, i after running macosx_setup.command, it works!  so although 007 is supposed to take care of that, apparently sometimes it doesn't?
mellis
Hmm... maybe it's not as taken care of as I thought.
It worked despite the fact that macosx_setup.command gave you the error message about uucp?  Or did you run it again without an error?
eforman
it gives the error every time i run it.  but i believe it worked after first run.
mellis
Huh, weird.  Glad it's working for you now.  As I said, I don't think you need to run macosx_setup.command with Arduino 0007, but maybe I'll get more reports of people having similar issues.
