I just got my arduino and was damn excited to use it but I can't seem to get anything to run. I installed 0007 as instructed, running the usb-to-serial driver installation, and then restarting. After restarting and plugging in the arduino, the bootloader showed that it was working (the led connected pin 13 to gnd quickly flashed and then started to slowly flash. After a few minutes of figuring out the proper timing between hitting the reset button and upload (hitting reset about 3 seconds after clicking the upload button) the led stopped it's slow flashing. So basically according to the IDE everything is working fine, but the led is not flashing like the led_blink example should. I know it's not the led because it flashes rapidly whenever I unplug and replug the usb cable.
As a side note I tried all the suggestions mentioned the prior post
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1169010083/0#0. I also changed the upload.verbose to true to check for any interesting error messages but there wasn't anything. For reference for anyone who knows if this should be correct or not, the last two lines are:
Firmware Version: 1.15
I should also mention that the window for pressing the reset button and getting a successful upload is tiny, I basically have to hit the reset button just at the right time. If I time it perfectly both the TX & RX leds flash right after. Then they pulse while the upload is happening. If I miss the timing, the RX led flashes once and then I get "Programmer is not responding.". Sorry for such a long post but I just wanted to make sure all the angles were covered.
thanks to anyone that takes the time to read this and I'm looking forward to becoming a long time member of this community once I get this thing to upload. I'm getting tired of overpriced & under powered basic stamps, or the overpriced/crazy 8 core/partial assembly code propeller. I've been a long time processing user so I'm really looking forward to getting this thing working.
thanks!
