« on: June 07, 2007, 02:47:37 pm » |
Fellow Arduinians,
my Arduino NG worked fine yesterday when i uploading the LedBlink sketch with LedInt set to pin 0 / rx to check out if a transistor was hooked up correctly.
But now it keeps telling me the programmer is not responding. What could be the case? After an extensive search for several hours i could not figure out what it is.
Actions i have taken.
- changing boud rates. - checked for right serial port - changed usb cables, changed usb slots. - playing with reset button and upload time alot.
But again, at first it was running beautifully. So my basic question is: is there a way to go back to factory defaults?
Regards: Maarten, the enthousiastic newb.
« Last Edit: June 07, 2007, 03:54:18 pm by maartez »
Austin, TX
Shh! I am hunting wabbit. Killlll the wabbit!
« Reply #1 on: June 07, 2007, 05:39:47 pm » |
What do you have connected to pins 0/1? These pins are used for programming and may need to be temporarily disconnected from your circuit during programing.
« Reply #2 on: June 07, 2007, 06:27:59 pm » |
it was connected it with a buz 10 transistor.. then i noticed that it has to be used for serial traffic, and should be disconnected during transfer. So i did.
my concern is that the pins purpose now has changed ( ? ) and it is blocking traffic.
could this be the problem?
Austin, TX
« Reply #3 on: June 07, 2007, 08:30:04 pm » |
As long as there are no electrical circuits connected to pin 0/1 (with some exceptions) and you press the reset button just prior to uploading a new sketch (within a couple of seconds). The code of the prior sketch should not effect the uploading of a new sketch.
Given that, I have noticed that occasionally I can not upload a new sketch after some tests. This has always gone away for me with a power reset on the arduino (disconnect from the computer) although occasionally it has required a restart of the computer as well.
« Reply #4 on: June 08, 2007, 04:13:19 am » |
Power resets, different cables, different ports, it all doenst matter.. when i hit Upload, the orange lights shortly blinks once. and then comes the error.
I cannot image that i a the only one with this problem. There must be someone else assigning pin 0 to something.. if that is the cause.
now can somebody please tell me HOW TO CLEAN IT UP? Reset, Format, Clear, Flash, Delete, Refresh, Start all over again.
Forum Administrator
Cambridge, MA
« Reply #5 on: June 09, 2007, 07:03:18 pm » |
If there's nothing connected to pin 0, that shouldn't be the problem. At least, once you reset the board, the configuration of the pin is reset. I suppose it's possible you've blown the pin though. What was connected to it?
What error do you get when you upload now?
« Reply #6 on: June 10, 2007, 04:11:12 am » |
Ok, resetter than the reset button isnt possible..
There was a transistor connected to it with 12 volt going through. Ive measured that the pin keeps spitting out around 5 volts constantly. So it isnt completely dead either.
i get:
Programmer Not Responding, RESET the board right before exporting. Programmer is not responding. .
Ive experimented alot with combinations in timing with pressing reset and first it worked fine. so that should not be it.. . .
thx in advance!
« Last Edit: June 10, 2007, 04:12:38 pm by maartez »
« Reply #7 on: June 11, 2007, 04:46:17 am » |
Mellis was right...
I consulted my schools technical dude, we exchanged the microcontrollers, and guess what, mine is dead. His is alive,
i fried the microcontroller, however, the rest of the board is still operating properly, so im looking at buying a new chip. I used an electromagnet in my circuit, and the coil gives a big peak when turned on. his advice was to install a diode over the magnet.
always nasty to learn stuff the hard way,
anyway: Thank you all!
maarten
Austin, TX
« Reply #8 on: June 11, 2007, 10:07:59 am » |
I've always found the hard way to make the best lessons!  When selecting the diode be sure to pick one that can handle 500-1000V (low amperage), even small inductive loads can send voltage spikes that measure in the hundreds of volts!
Greenwood, Indiana
« Reply #9 on: June 24, 2007, 04:55:02 pm » |
Can you post a drawing of what you did? I'd be curious as to what killed the chip.
If it was designed by man it can be repaired by man.
