Topic: Arduino BT + SuperWaba (Read 378 times) previous topic - next topic
rosa_ally
Hello everybody!
I'm trying to connect an Arduino BT board to a SuperWaba app on a PocketPc. Everything seems to work fine: I can see the BT connection in the BT connections list in XP.
The problem comes when I try to send data (from the SW to ABT). The SW app consists of a group of buttons. I pretend to send some integers to the board everytime that a button is pressed. Seeing that it does not work, I've simplified it so all the buttons do the same task: send a 0 to the board. If the board receives data it is supposed to change the state of a LED (if turned on -> turns it off; if turned off -> turns it on).
The fact is that the board is receiving data, cause some times the LED changes. The main problem is that it NOT always happens. And I haven't noticed a pattern.
Does anybody know why can this be happening? Anything about problems between different protocol (SW - ABT) communications? Anything related to reliability of the BT communications in Arduino (I suppose it has to be reliable...)?
Here's the Arduino code:
int redPin   = 11;
int op=-2;
int X=0;
 pinMode(redPin,   OUTPUT);
 long time = millis();
 randomSeed(time);
 // Reset the bluetooth interface
 digitalWrite(RESET, HIGH);
 delay(10);
 digitalWrite(RESET, LOW);
 delay(2000);
 //configure the bluetooth module
 Serial.println("SET BT PAGEMODE 3 2000 1");
 Serial.println("SET BT NAME BTLAMP");
 Serial.println("SET BT ROLE 0 f 7d00");
 Serial.println("SET CONTROL ECHO 0");
 Serial.println("SET BT AUTH * 12345");
 Serial.println("SET CONTROL ESCAPE - 00 1");
void loop () {
 Serial.flush();
 op=Serial.read();
 if (op!=-1) {
   if(X==255) X=0;
   else X=255;
   analogWrite(11, X);
Thanks in advance!!!
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
