Topic: i2c causing board to reset (Read 2272 times) previous topic - next topic
nick
Hi
I'm trying to get i2c working on an arduino Diecimila.
The board keeps reseting at the point where the code calls Wire.begin
I've stripped out all the code apart from this-
#include <Wire.h>
 Serial.println("coming out of reset");
 Wire.begin();
Serial.println("in loop");
if I comment out the Wire.begin line then the code gets tot the "in loop" print and continues looping, if Wire.begin is in the code then it prints "coming out of resetb" to the serial port (with an extra b in every time) and restarts printing that out every 7 seconds.
Whether the i2c device is connected or not makes no difference, it still behaves the same.
Will try setting it up with another board, but if anyone has any pointers that would be great.
Cheers
Nick
mellis
I know people have had problems with the wire library in the past.  You might try deleting all the .o files in the lib/targets/libraries/Wire subdirectory of the Arduino application directory (including its subdirectories).
When you comment out Wire.begin() do you leave the #include <Wire.h>?
nick
Yes the include is still in.
Will try deleting those and report back.
Cheers
Nick
nick
Deleting the .o files has worked.
It now goes through to the main loop, and has with other sketches too from the forum too.
Thanks for that.
Now to get the i2c communication actually communicating.
Cheers
Nick
mellis
Hmm, which version of the Arduino software are you using?
nick
This machine is still on 007 - I will try 008 and see if that works straight out of the box.
mellis
Awesome, thanks.  I think the problem should be fixed in 0008.
nick
yep its fine in 008 with no tweaking.
Sorry hadn't realised I hadn't updated the machine I was working on, I would have tried that straight away if i had.
mellis
Cool, thanks for trying it out.
Mark Holmes
Thanks!
This was happening to me as well.
I was totally stumped - until i read this post.
Thanks guys,
Mark
faquin
Finally, were you able, both of you, to drive some I2C devices?
I am very interrested in Arduino, but I use I2C quite often for sensors, EEPROMs, devices...
I'd really like to know that I can use it.
Thanks
nick
faquin
How could you managed sending some ACK and NotACK "commands" ? Is this automatically done using the Wire Library?
I want to use a MCP9803 temperature sensor.
