Topic: How to tell if booting from reset or powerup? (Read 1 time) previous topic - next topic
dcb
Problem is that there is external equipment (LCD in this case) that really doesn't like getting double initialized once it is powerd up.  So you reporgram the duino or reset it or open a comm connection to it and the lcd goes haywire.  I have a temporary fix by powering the LCD controller with an arduino pin, but I want my pin back.
So has anyone heard of a way to tell that a reset just occured and not a power up?
lilpunk1302
I'm pretty sure a Powerup and a Reset are the same thing as far as the ATMega's concerned.
Easiest solution I see would be to get a Programmer, and ditch the Arduino bootloader.
Then it won't pulse your pins when it powers up.
follower
According to the ATmega168 data sheet (page 54) there is a register that tracks this: MCUSR - MCU Status Register
The MCUSR can differentiate between Power-on Reset and External Reset (among others).
Here's an Arduino-related use of the MCUSR: http://www.ladyada.net/library/arduino/bootloader.html
A hardware thought, could you hook the reset line to also trigger a LCD reset?
--Phil.
adilson
Note that if you're using an Atmega8 instead of Atmega168, the register is MCUCSR (Atmega168 is MCUSR). And the page for the Atmega8 datasheet is 41.
dcb
SWEET!!! Thanks guys!!  I will definately give that MCUSR a shot.  I saw a lot of stuff in the data sheet and couldn't quite make sense of all of it.
dcb
Working good, thx again :)
void setup(){
 int po = MCUSR;
 MCUSR=0;
 pinMode (13,OUTPUT);
 if(po & 1)
   digitalWrite(13,HIGH); //or call lcd.init()
void loop(){}
follower
void setup(){
 int po = MCUSR;
 MCUSR=0;
 if(po & 1)
void loop(){}
Thanks for completing the circle and posting your code. :)
Ditto for the ATmega128 which I had noticed.
--Phil.
