Greetings All,
I was working on my Arduino Diecimila this evening and came across an error. The reason why I am emailing you directly is because I did a search of the forum and found a similar error message from another user to which you started to reply.
From Arduino Forum Software Troubleshooting
Error inside Serial.serialEvent()
27. Jan 2008 at 23:05
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1201489509 The error message I am receiving is:
java.io.IOException: Bad file descriptor in nativeavailable
at gnu.io.RXTXPort.nativeavailable(Native Method)
at gnu.io.RXTXPort$SerialInputStream.available(RXTXPort.java:1532)
at processing.app.Serial.serialEvent(Serial.java:206)
at gnu.io.RXTXPort.sendEvent(RXTXPort.java:732)
at gnu.io.RXTXPort.eventLoop(Native Method)
at gnu.io.RXTXPort$MonitorThread.run(RXTXPort.java:1575)
This message repeats.
What I am doing is trying to measure capacitance.
See code:
http://hmmtheresanidea.blogspot.com/2008/06/capacitance-measurer-v10.html First I looked over the hardware and it seems fine.
Then I tried the simple stuff like unpluging and repluging the Arduino.
Then starting and stopping the Serial Monitor, which i can do
Then restarting the IDE software.
The first person who came across this error said they got it 'occasionally' I get it consistently.
Any thoughts,
Oaxacamatt
