Topic: IDE12 Auto Format on Ubuntu 8.04 crashes (Read 2279 times) previous topic - next topic
absolutum
whenever I call "Auto Format"
I got an Index out of BoundsExecption: String Index out of range:1022
mellis
What's the code that it happens on?  Can you post a minimal example with the same problem?
absolutum
The comment part at begin seems to be the problem,
without it Auto Format works
// panorobot program for Olympus E510 DZ Kit
// - with serial LCD
// - with Nunchuk
// - EasyDriver 3
// - opto coupled remote focus and shutter trigger
// - Arduino Nano
// - 4 Eckbrennweiten des Kits und drei BWs für 70-300mm
// - mehrreihig
// - BKT
// - optional Delay
// - Timelaps with FL 0
// - Nullpunkt setzen, Anzeige der Bildzahl ab Nullpunkt zur gewählten BW
// Timelaps funktion ohne Bewegung evtl. einfach ohne Motorstrom?
//  TODO: evtl. opt. kurze Erinnerung an AEL, AFL, RemoteSet, WB, no Liveview, Delay
#define VERSION "?fabso.lutum V16"
// set params for 7 certain focallengths FL / and 0 for timelapse without moving
#define MAX_INDEX 7
unsigned int FL_MM[] = {
 0, 14, 40, 42, 150, 70, 200, 300};
unsigned int MAX_ROW[] = {
 1, 4, 10, 10, 36, 17, 48, 72}; // max number of rows
long STEPS_FL_H[] = {
 0, 39996, 15383, 14813, 4166, 8888, 3100, 2072};
long STEPS_FL_V[] = {
 0, 49995, 19998, 19998, 5555, 11764, 4166, 2778};
unsigned int NPP[] ={
 0,350,155,350,250,0,0,0};
// Pins for shuttercontrol
#define FOCUS_PIN 6
#define SHUTTER_PIN 7
//LCD Pins (only D3)
#include <SoftwareSerial.h>
#define rxPin 4  // rxPin is immaterial - not used - just make this an unused Arduino pin number
#define txPin 3
#include <Wire.h>
SoftwareSerial mySerial =  SoftwareSerial(rxPin, txPin);
// NUNCHUK (Pins: A4 green, A5 yellow
static uint8_t nunchuck_buf[6];   // array to store nunchuck data
// nunchuck X Y
int NUN_X;
int NUN_Y;
// nunchuk buttons
int NUN_C;
int NUN_Z;
// Globals
byte LU_ZERO_SET = 0;
byte LU_FL_Index = 0;
byte LU_DONE;
byte LU_BKT = LOW;
unsigned int LU_Pics_to_do = 1; // change here init no of pics !!!
unsigned int LU_Pic_Delay = 1;   // delay between two pics = wait before move
unsigned int LU_Rows_to_do = 1;  // number of rows
// STEPPER (Pins: D9,D10,D11,D12)
// horizontal
int hsteppin = 9;
int hdirpin = 10;
long LU_STEPS_H = 0;
// vertikal
int vsteppin = 11;
int vdirpin = 12;
long LU_STEPS_V = 0;
// Cam data
int no_of_pics;
int row;
int CAM_position; // 0 at start, 1 if position is set
int CAM_hori_pics;// 0 at start, n if no of horizontal pics is set
int CAM_row_pics;// 1 at start, n if no of vertical pics is set
int CAM_MM = 0; // initial focal lenght
long CAM_STEPS = 0; // initial horizontal steps for 1 pic
long CAM_STEPS_ROW = 0; // initial vertical steps per row
int CAM_NPP; // cam NPP in tenth of mm
 // init LCD
 delay(5000); // give LCD Time to warm up
 pinMode(txPin, OUTPUT);
 mySerial.begin(9600);    // 9600 baud is LCD chip comm speed
 mySerial.print("?G420");
 delay(100);                 // pause to allow LCD EEPROM to program
 mySerial.print("?c0");   // turn cursor off
 delay(200);
 // init nunchuck
 Serial.begin(19200);
 nunchuck_init(); // send the initilization handshake
 delay(200);
 nunchuck_zero();
 nunchuck_get_data();
 delay(200);
 // cam pins
 pinMode(FOCUS_PIN, OUTPUT);
 pinMode(SHUTTER_PIN, OUTPUT);
 digitalWrite(FOCUS_PIN, LOW);
 digitalWrite(SHUTTER_PIN, LOW);
 // vertikal motor pins
 pinMode(vdirpin, OUTPUT);
 pinMode(vsteppin, OUTPUT);
 // horizontal motor pins
 pinMode(hdirpin, OUTPUT);
 pinMode(hsteppin, OUTPUT);
 // initial values
 LU_BKT = 0;         // no bracketing
 LU_Rows_to_do = 1;  // 1 row
mellis
Does the same thing happen if you delete most of the sketch?  Can you post a short example with the same problem?
absolutum
I deleted some more lines, the bug happens as long as the arrays are initialized.
// - with Nunchuk
// - EasyDriver 3
// - Arduino Nano
// - mehrreihig
// - BKT
// - optional Delay
 // init LCD
mellis
I had a problem with the space after the last closing curly brace.  Does deleting it fix things for you?
absolutum
#6
Oct 25, 2008, 05:39 pm Last Edit: Oct 25, 2008, 05:41 pm by absolutum Reason: 1
no, I deleted all trailing blanks, but Auto Format still crashes
java.lang.StringIndexOutOfBoundsException: String index out of range: 1022
     at java.lang.String.charAt(String.java:687)
     at processing.app.tools.AutoFormat.getchr(AutoFormat.java:313)
     at processing.app.tools.AutoFormat.cpp_comment(AutoFormat.java:243)
     at processing.app.tools.AutoFormat.getnl(AutoFormat.java:370)
     at processing.app.tools.AutoFormat.show(AutoFormat.java:675)
     at processing.app.Editor$15.actionPerformed(Editor.java:728)
     at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1995)
     at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2318)
     at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:387)
     at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:242)
     at javax.swing.AbstractButton.doClick(AbstractButton.java:357)
     at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:1220)
     at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:1261)
     at java.awt.Component.processMouseEvent(Component.java:6041)
     at javax.swing.JComponent.processMouseEvent(JComponent.java:3265)
     at java.awt.Component.processEvent(Component.java:5806)
     at java.awt.Container.processEvent(Container.java:2058)
     at java.awt.Component.dispatchEventImpl(Component.java:4413)
     at java.awt.Container.dispatchEventImpl(Container.java:2116)
     at java.awt.Component.dispatchEvent(Component.java:4243)
     at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4322)
     at java.awt.LightweightDispatcher.processMouseEvent(Container.java:3986)
     at java.awt.LightweightDispatcher.dispatchEvent(Container.java:3916)
     at java.awt.Container.dispatchEventImpl(Container.java:2102)
     at java.awt.EventQueue.dispatchEvent(EventQueue.java:599)
     at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:273)
     at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:183)
     at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:173)
     at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:168)
     at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:160)
     at java.awt.EventDispatchThread.run(EventDispatchThread.java:121)
absolutum
same bug with windows xp:
______________________________
java.lang.ArrayIndexOutOfBoundsException: 1024
     at processing.app.tools.AutoFormat.getnl(AutoFormat.java:343)
     at processing.app.tools.AutoFormat.show(AutoFormat.java:621)
     at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
     at javax.swing.AbstractButton$ForwardActionEvents.actionPerformed(Unknown Source)
     at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
     at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
     at javax.swing.AbstractButton.doClick(Unknown Source)
     at javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
     at javax.swing.plaf.basic.BasicMenuItemUI$MouseInputHandler.mouseReleased(Unknown Source)
     at java.awt.Component.processMouseEvent(Unknown Source)
     at java.awt.Component.processEvent(Unknown Source)
     at java.awt.Container.processEvent(Unknown Source)
     at java.awt.Component.dispatchEventImpl(Unknown Source)
     at java.awt.Container.dispatchEventImpl(Unknown Source)
     at java.awt.Component.dispatchEvent(Unknown Source)
     at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
     at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
     at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
     at java.awt.EventQueue.dispatchEvent(Unknown Source)
     at java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknown Source)
     at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
     at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
     at java.awt.EventDispatchThread.run(Unknown Source)
gnu_linux
It looks like the array in AutoFormat.java is overflowing
Seems interesting that it is occurring on multiple operating systems
mellis
Can you guys post an (even) shorter example with the problem?
absolutum
Short example WinXP:
// Auto Format bug
