Pages: [1]   Go Down
Author Topic: Arduino IDE (0014) for Win. won't open.  (Read 764 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
I've been trying to get the software to work properly for a few days now. I downloaded the latest version for Windows, extracted the folder to my desktop for the time being. I opened it, clicked the Arduino icon but it dosen't' open. However, it does open if I click the run.bat file. I want to be able to open it normally without having the cmd window open. I'm running XP SP2 and have the latest versions of Java. Anyone know why this isn't working?
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
I was told somewhere else that I had to change some things around in the batch file to get it to work. Here's what the file says:
@echo off
REM --- if you're running out of memory, change the 128m
REM --- (which means 128 megabytes) to something higher.
set SAVEDCP=%CLASSPATH%
set SAVEDPATH=%PATH%
set JAVA_HOME="java/bin"
if %JAVA_HOME% == "" GOTO Error
set CLASSPATH=java\lib\rt.jar;lib;lib\build;lib\pde.jar;lib\antlr.jar;lib\RXTXcomm.jar;lib\oro.jar;lib\registry.jar;lib\mrj.jar
set PATH=java\bin;lib;%PATH%
REM start javaw -ms128m -mx128m processing.app.Base
%JAVA_HOME%\java processing.app.Base
set CLASSPATH=%SAVEDCP%
set PATH=%SAVEDPATH%
GOTO End
:Error
echo *** Error: cannot execute Arduino
echo *** Reason: lacking the directory where to find Java in your computer
echo ***
echo *** Fix: Edit run.bat and add the JAVA_HOME directory
echo ***      at the 'set JAVA_HOME=""' line
echo ***
echo *** then call the batch file run.bat in order to execute Arduino
:End
Pause
echo Bye.
I don't know what I would have to fix because I'm not familiar with Java or manipulating batch files. Anyone know what I can do to fix this? It doesn't install like a regular program, if it did I would just uninstall and then re-install it.
Logged
Chile
Offline Offline
Edison Member
Arduino rocks?
View Profile
WWW
Delete the "java" folder and try again.
Logged
My website: http://ried.cl
Pages: [1]   Go Up
Jump to:
