Topic: Anyone using Arduino board with XBee shield? (Read 4812 times) previous topic - next topic
hzhang
#15
May 05, 2009, 06:25 pm Last Edit: May 05, 2009, 08:43 pm by hzhang Reason: 1
Hi etracer, i know what you mean. I tried all you mentioned above, but still failed.
I remove the xbee to try uploading
even remove both jumpers, but still failed uploading..
(unluckily, i lost one jumper when i removed them once and once again.)  :(
BTW,how do you identify your atmega chip? i even didn't see it there.
that's why i said i didn't have the chip on the board.
etracer
Well I was actually replying to crisfuga who seems to be ignoring the advice.
But if you don't have an ATMega chip installed, then I have 100% confidence that you're not going to be able to upload a sketch. Your image post didn't work so I can't tell you for sure what you have (or don't have).
The chip on a standard Arduino is located as indicated by the yellow box:
hzhang
#17
May 05, 2009, 08:31 pm Last Edit: May 05, 2009, 08:48 pm by hzhang Reason: 1
I'm pretty sure i don't have that part....
etracer:
under this situation, do you know how to control and program the arduino xbee moduel? how to connect arduino with c++?
etracer
#18
May 05, 2009, 08:50 pm Last Edit: May 05, 2009, 09:43 pm by etracer Reason: 1
Well where did it go? When you buy a Duemilanove it comes with an ATmega168 (or more recently a ATmega328).
Without it it's like taking the CPU out of your computer (and about as useful).
Good thing you can always buy another:
http://www.nkcelectronics.com/arduino-ready-avr-atmega328-microcontrol328.html
http://www.sparkfun.com/commerce/product_info.php?products_id=9217
http://www.adafruit.com/index.php?main_page=product_info&cPath=17&products_id=123
The picture you posted shows a XBee module, plugged into a XBee shield which is plugged into the Arduino. So if you want to see if a XTmega chip is installed (and which one), you'll have to remove the XBee shield (by pulling straight up).
hzhang
of course i did remove the two staff on the arduino.
but no Atmega.
crisfuga
Ok, I solved it!
thanks etracer and diya for your help. It was a stupid thing, part of the problem was that jumpers were not correctly connected, as etracer had said.
hzhang
yeah, got it.
i use another arduino board with Atmega168 and the blinking works..
Thanks everyone here, specially thanks etracer.
