Topic: can an arduino code be retreveid ? (Read 1 time) previous topic - next topic
Hamad
ok so heres the qustion if you upload the software to microcontroller,
can you possibly get the code back from the microcontroller if you lost it and if so what should i do ??
am a nooby in programing,  am only shooting in the dark here but isnt it possible to get the same code back from memory ? if so what should i do ?
madworm
Well, you can download the machine code and save it to a hexfile. It can be used to program other chips of the same kind.
But I assume you wanted to get the C-code back, can't be done.
Mr. Backup is your friend.
If you should be using linux or a mac, I suggest using some sort of version control tools. I personally use GIT to keep my code in order including a full history of changes.
Hamad
aww i was hoping theres was a way to get the code back.
you were right i didnt back up, i'll search for GIT. would you mind telling me how to get the hex files out of the chip.  :'(
madworm
You'll need to run something like this:
avrdude -b 19200 -c stk500 -p m168 -P /dev/ttyUSB0 -U flash:r:saved.hex:i -vvv
This assumes you at an ATmega168 chip (m168) and have it connected to /dev/ttyUSB0.
Most likely you'll need to make some adjustments.
MarkT
Google 'avr decompiler' - there seem to be some tools out there.
Osgeld
it still wont be C code, it will just be a dissembler listing
